He'll actually need the ADP schematic and WD starting on EL-190. Since the ADP on that MY only controls the seat and not the mirrors, etc, it lacks an external controller with a bit-bang serial link like most later models. So I'm fairly certain it will work if the OP just hooks up power and ground. The Pathy power seat supply should work as-is to power the ADP. However, the heaters use their own separate fuse and a new supply with a 15A inline should be routed in order to use them. The switches are 3PDT and not very easy to duplicate, so if he didn't swipe them from the JY along with the seats he should go back and get them, as well as cutting off the ends of all the QX harness connectors to use as pigtails. That will make the job much easier.mdmellott wrote: ↑Fri Mar 04, 2022 11:12 pmHere are the schematics for the power seats and heaters for the '01 QX4, starting on page EL-181 >>> https://www.nicoclub.com/service-manual ... System.pdf
Well, what I said above also assumes your Pathy doesn't have heated seats. If it does then you can use the existing heater circuit on the Pathy. The only reason the QX4 uses a bigger fuse is because of the rear seat heaters, which the Pathy doesn't have. So the 10A circuit on the Pathy should work fine for the QX seats.PATHFINDER99NI wrote: ↑Fri Mar 04, 2022 8:14 amI’m thinking that if I just power up the seat, the heated and adjustable portion will work. The only problem is, the new seat has ADP (auto seat adjustment).
Thanks for the reply. I have the ADP diagram, I’ll study it a bit more, later today. I’ll see if I can post some pics of what I come up with. Thanks again.mdmellott wrote: ↑Fri Mar 04, 2022 11:12 pmHere are the schematics for the power seats and heaters for the '01 QX4, starting on page EL-181 >>> https://www.nicoclub.com/service-manual ... System.pdf and the '99 Pathfinder, starting on page EL-160 >>> https://www.nicoclub.com/service-manual ... 9%2Fel.pdf
Looks like a tedious project to sort out and match up common power supply wiring and what controls and wiring to ignore or bypass. At first glance, it looks like it can be done. At least there is no CAN Bus in either model to deal with. Good luck.
Good, this is what I was hoping. I think power is the large yellow wire and the large black wire. By looking at the diagram, is this correct? I appreciate your help.VStar650CL wrote: ↑Sat Mar 05, 2022 6:11 amHe'll actually need the ADP schematic and WD starting on EL-190. Since the ADP on that MY only controls the seat and not the mirrors, etc, it lacks an external controller with a bit-bang serial link like most later models. So I'm fairly certain it will work if the OP just hooks up power and ground. The Pathy power seat supply should work as-is to power the ADP. However, the heaters use their own separate fuse and a new supply with a 15A inline should be routed in order to use them. The switches are 3PDT and not very easy to duplicate, so if he didn't swipe them from the JY along with the seats he should go back and get them, as well as cutting off the ends of all the QX harness connectors to use as pigtails. That will make the job much easier.mdmellott wrote: ↑Fri Mar 04, 2022 11:12 pmHere are the schematics for the power seats and heaters for the '01 QX4, starting on page EL-181 >>> https://www.nicoclub.com/service-manual ... System.pdf
If you provide a little more info I can tell you exactly what should hook to what:PATHFINDER99NI wrote: ↑Sat Mar 05, 2022 7:17 amI think power is the large yellow wire and the large black wire. By looking at the diagram, is this correct? I appreciate your help.
Thanks for the help.VStar650CL wrote: ↑Sat Mar 05, 2022 7:36 amIf you provide a little more info I can tell you exactly what should hook to what:PATHFINDER99NI wrote: ↑Sat Mar 05, 2022 7:17 amI think power is the large yellow wire and the large black wire. By looking at the diagram, is this correct? I appreciate your help.
1) Did you grab the QX harness connectors for pigtails?
2) Does the Pathy already have heated seats?
No, the ‘99 LE & ‘01 QX4 are completely different. Even the pins are different. Included is a pic of the connectors. ‘99 is on the bottom, ‘01 is at the top. The seat heaters had a different two pin connector. That isn’t shown.VStar650CL wrote: ↑Sat Mar 05, 2022 10:34 amYour heated seats should be real simple. The drive circuit and connectors have exactly the same layout for both vehicles, so you just need to swap the white Pathy connectors for the gray QX connectors. The wire positions and colors on the pigtails will match the Pathy. I think the connectors will be the same style, just with different polarizers, so if you have picks to unpin the shells, you can probably just swap the white shells for the gray ones.
The heater connector on passenger seat was the same, it required no modification. Not sure if it was two or three pin.VStar650CL wrote: ↑Sat Mar 05, 2022 1:04 pmThen something's wrong in the description of the donor QX. The FSM shows the heaters on both seats using a separate 3-pin connector that's apart from the main seat connector.
Yes, provided the frame gives a good ground. It's hard to be certain about that. Nissan usually grounds the seats through the harness on later models because there are nylon sliders in the tracks and the frame may provide a dicey ground connection. Your best bet would be to string a new wire along the flex coupling and ground both of the wires someplace on the floor.PATHFINDER99NI wrote: ↑Sat Mar 05, 2022 1:05 pmOne of my questions was if I can combine the two grounds and the diagram says yes, it was done that way from the factory. The other question is, can’t I just place these grounds on the seat frame? Also, B16 is the seat connector.
Ok, so I’m out of the meeting. I took a look under the front passenger and got this. The white is the motor, grey is seat heater. It is like this as well on the drivers side, of course, with exception to the ADP connector.VStar650CL wrote: ↑Sat Mar 05, 2022 1:11 pmI just checked the manual for the '01.5 and it shows no changes from the early '01. So one of us is missing something.
Does the picture I posted solve the confusion?VStar650CL wrote: ↑Sat Mar 05, 2022 1:04 pmThen something's wrong in the description of the donor QX. The FSM shows the heaters on both seats using a separate 3-pin connector that's apart from the main seat connector.
Yes, there is an identical plug under the driver seat.VStar650CL wrote: ↑Sat Mar 05, 2022 5:20 pmShould be an identical gray one underneath the driver's seat according to the FSM. Try looking for the leads coming out of the seat cushions and trace the wires. Unless somebody uninstalled the heater, it has to be there someplace.
Ok, I see where the confusion is coming from. The original seats had heaters, so the three pin connector was there. I wasn’t looking to add heaters to a non heater vehicle.VStar650CL wrote: ↑Sat Mar 05, 2022 10:34 amYour heated seats should be real simple. The drive circuit and connectors have exactly the same layout for both vehicles, so you just need to swap the white Pathy connectors for the gray QX connectors. The wire positions and colors on the pigtails will match the Pathy. I think the connectors will be the same style, just with different polarizers, so if you have picks to unpin the shells, you can probably just swap the white shells for the gray ones.
Ok, so I connected the w/r to the red coming from seat power and the pin 10 & 4 to the black from seat power, no dice. I tested w a voltmeter and there is 12.5+v coming from seat power. So that is is good as getting power from the fuse box, right? Now, why would I run a pair of wires from the fuse box, when I already have battery voltage at the seat power connector? And why would I connect that to different wires in the pig tail?VStar650CL wrote: ↑Sat Mar 05, 2022 11:31 amCorrect. See if the seat works that way. If it doesn't then you'll need to route a pair of wires from the fusebox. Those will be logic battery power on pin 8 (the BRown wire in the corner going to G/R in the pigtail) and an ignition signal on pin 11 (the W wire next to 10 also going to G/R in the pigtail). Neither one should draw much power, so you can tap anything handy in the fusebox at 7.5~10A.
One wire (11) needs to be ignition and not battery, and the main power circuit will be noisy as a block party whenever a motor is running. So you want a separate battery supply on 8 for the logic circuitry. The connections are already there in the seat harness.PATHFINDER99NI wrote: ↑Mon Mar 07, 2022 4:31 pmOk, so I connected the w/r to the red coming from seat power and the pin 10 & 4 to the black from seat power, no dice. I tested w a voltmeter and there is 12.5+v coming from seat power. So that is is good as getting power from the fuse box, right? Now, why would I run a pair of wires from the fuse box, when I already have battery voltage at the seat power connector? And why would I connect that to different wires in the pig tail?
So the wire that goes to 11, that’s coming from the fuse box, but from which part? So these two connections are in addition to the seat power?VStar650CL wrote: ↑Mon Mar 07, 2022 5:15 pmOne wire (11) needs to be ignition and not battery, and the main power circuit will be noisy as a block party whenever a motor is running. So you want a separate battery supply on 8 for the logic circuitry. The connections are already there in the seat harness.PATHFINDER99NI wrote: ↑Mon Mar 07, 2022 4:31 pmOk, so I connected the w/r to the red coming from seat power and the pin 10 & 4 to the black from seat power, no dice. I tested w a voltmeter and there is 12.5+v coming from seat power. So that is is good as getting power from the fuse box, right? Now, why would I run a pair of wires from the fuse box, when I already have battery voltage at the seat power connector? And why would I connect that to different wires in the pig tail?
Im back, I got really busy and dropped the ball on this.VStar650CL wrote: ↑Mon Mar 07, 2022 9:31 pmYes, in addition. If you have any condensers laying around (as in points-and-condenser), you can probably get away with using the same power and logic supply by putting one on the power line under the seat to absorb the electrical racket from the seat motors. Otherwise, the logic supply should come from a separate fuse, preferably one with other digital circuits on it like the radio or HVAC. The ignition line can come from any ignition fuse. It won't draw any power so the source is irrelevant, but the signal is necessary to put the seat controller in low-power hibernation when the car is off.
