I like the idea of the blade tap. I’ll order a few, get them installed and post the results.VStar650CL wrote: ↑Mon Mar 21, 2022 5:35 amThat looks right. Neither one of the circuits from the fusebox will draw any meaningful power, probably 10~15 milliamps for the logic supply and microamps for the ignition wire. So while there's nothing wrong with using a splitter-type fuse tap to provide a separate fused output, it isn't really necessary. You can use a blade type to tap the output side of the two existing fuses:
https://www.amazon.com/19043-0007-Quick ... B08Z82SG2C
Just make sure to put the blade on the side of the fuse that's "cold" with the fuse removed.
Is 18ga fine, or should I go to 22ga?
Thanks again!
