01 LE, misfire when it warmed up
ray-peg
Car: 2001 Pathfinder LE
2001 nissan pathfinder 3.5 Le, got a p1320 about half month ago, and randomly misfire. But, from last week, it seems like pretty bad, temperature dropped to -20. Car starts ok, drives ok when the car is cold, every time when I drove the car over half hour, it started misfire, shaked like hell.Or after 20 mins driving, shut the car down for anywhere 5 min to an hour, start again, misfire for sure, shakes like hell.
My questions are,
1 Is that for sure ignition coil went bad? or any other possible reason(s)? If I do all 6, the problem can be solved for sure? I really don;t have the time to spend on dealership.
2 someone told me might be something wrong with my MAF sensor, if so, is that suppose to be misfire all the time, instead of just when the car warmed up?
3 how long do I looking for get all 6 coils done? for a licensed nissan mechanic.
Really appreciate for the helps.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
What's the manufacturing date of your Pathfinder? I believe with the 2001.5, ignition coil issues were changed, solving some issues. Dates 01/01/2000-08/31/2000 are 2001s and 09/01/2000-06/30/2001 are 2001.5s. This topic may be of use to you.
asnorton44
Car: 2001 Infiniti QX4
ray-peg wrote:2 someone told me might be something wrong with my MAF sensor, if so, is that suppose to be misfire all the time, instead of just when the car warmed up?
I had P1320 and a bad misfire, replacing the coils and plugs fixed that code but the car was still dying after it warmed up. It was my MAF. I eventually found this out when I unplugged the MAF and the car didn't die when it was warm.
I am far from a mechanic but I was able to do the coils/plugs by myself. I purchased them from Partsgeek.com.
EsotericImage
Car: 99 Civic on 10lbs boost
02 Pathy as DD
Jeez, i really need to educate myself with OBD-II cars. Image
ray-peg
update:
Drove back from work, after about 35 mins, car started shaking, about 5 mins later, everything went well, car was like new, stopped by red light, could not feel any shake, i mean any, just like turned off the car, it never performer this good before, except ses light still on.
any clues ?
EsotericImage
02 Pathy as DD
im just taking a stab in the dark of what happens when a fuel pump takes a s***.. same symptoms.
