Would it only die while in Park or neutral because that's what mine does. While under load it'll drop but not completely cut out.nnorton44 wrote:Just throwing this out there, my car would die and have rough idle when stopped when the engine was warm. If it was cold it wouldn't die. Replaced MAF which fixed the problem.
I spoke with the dude diagnosing it and he says that they found an issue with a "wire harness" and his electrical guy is soldering it back together. To be perfectly honest I have no idea what that means and I'm somewhat scared that he's stripping wires and soldering them back together. He said he'll call me tomorrow with an update but I doubt that'll happen. Unfortunately I'm so slammed at work I don't have time to try anything myself. He did rule out the MAF as it "tested" okay. I'm flying out to DC next week and I'd really like to have this month long chapter closed before I leave.Pwnin O’Brien wrote:Have you figured out the P1320 yet? I'm curious to see what is causing this code.
I doubt it since the P1320 is strictly an electrical issue somewhere between the spark plugs and the ECU (or between the spark plugs and ground). Did they tell you specifically what wire harness they were working on? It's pretty random that this would happen all by itself.Empty V wrote:I just thought of something, could it be a leak from an old vacuum hose? They're all original (200,000+ miles)
I just got off the phone with him and he said they were working on the main harness. Is there a main harness? I asked him if he found voltage on the ground and he didn't know. How many things are there between the coils and the ECU? It's just wires right? He swapped out the ECU and had it flashed at the dealer and that didn't resolve the issue. He said he'd call me at 5PM PST, with a prognosis. I've got a feeling it'll be another "we still don't know what's going on" conversation.Pwnin O’Brien wrote:
The first thing I did in attempting to fix the problem was change out all of the coils and plugs but the issue persists. So right now I'm at a loss, figuratively and literally.Pwnin O’Brien wrote:Hahahaha damn right! You can all call me Mr. Mod herein.
Assuming the ECU power circuit and the coil ground is good (also assuming your coils and spark plugs are all operating properly), then the issue is with the primary circuit (or the coil output signal) which is the wires which the ECU uses to turn each coil transistor on and off; it's also the wire used to detect proper functionality of the coils (and each coil transistor). I just don't understand how there could be a problem with the primary circuit signal out of the blue when it's not related to the coils or spark plugs.
Well I had to head out to DC for a week and was hoping that dude would have the problem diagnosed and fixed by the time I returned home. Not a chance! So last Thursday he said he had good news. He reported that the #3 engine coil(which was just replaced) had blown again which pointed @ the main harness and they found a short. Apparently a wire had worn out due to rubbing and bare wire was exposed. So I called yesterday and he said that the infiniti dealer and his electrical guy suggested replacing 2 of the 4 crank sensors. One in the engine compartment and the one at the transmission. What do the crank sensors do and how on earth would they contribute to burning up an ignition coil? Ohh yeah and he said that he was datalogging the coils but if he was I think he would have seen that #3 blew immediately.Pwnin O'Brien wrote:Did they at least datalog each coil output to see which one is not working?
Empty V wrote: Well I had to head out to DC for a week and was hoping that dude would have the problem diagnosed and fixed by the time I returned home. Not a chance! So last Thursday he said he had good news. He reported that the #3 engine coil(which was just replaced) had blown again which pointed @ the main harness and they found a short. Apparently a wire had worn out due to rubbing and bare wire was exposed. So I called yesterday and he said that the infiniti dealer and his electrical guy suggested replacing 2 of the 4 crank sensors. One in the engine compartment and the one at the transmission. What do the crank sensors do and how on earth would they contribute to burning up an ignition coil? Ohh yeah and he said that he was datalogging the coils but if he was I think he would have seen that #3 blew immediately.
Thanks!
No dude I was never thinking about replacing or trading it and I don't intend on ever running it into the ground.Innovazn wrote:your truck really likes to be a bad b****..... werent you considering replacing or trading it? or are you going to run her to the ground?
Pwnin O'Brien wrote:There is no way that any of crankshaft sensors could have caused the failure of your #3 ignition coil. I'm assuming that your mechanic tested the crankshaft sensors while trying to troubleshoot the DTC and they tested out of spec or something. If the crankshaft sensors aren't throwing a DTC, I would recommend just having them finish with the coil harness and get the car back. The sensors aren't super difficult to replace but they won't be cheap (about $80 per sensor). In the following picture you can see the locations for the various cam/crankshaft sensors. Numbers 4, 5 and 7 are your crankshaft sensors (whereas the two #2's are your camshaft sensors).
So you should ask your mechanic why he thinks the sensors should be replaced. Ask if they are actually throwing DTC's or if he thinks you should replace them because they could fail soon or are damaged. If you took the vehicle in there without a DTC for any crankshaft sensors and now there are crankshaft DTC's then your mechanic has some explaining to do.
Empty V wrote:Thanks guys for the info! It doesn't drop at first startup when cold, only after running for 10min or so. I drove it to work and it cut out while in park and neutral, it's not just when at load. So does this mean the IACV is okay or can that still be a factor?
Billy
Well I'm pretty sure it's not a sensor because the only code I'm getting from a sensor is after the cat. Speaking of O2 sensors, I've got more to the story.fleurys wrote:If this can be any help for you troubleshooting.... This 10 minutes thing behavior is typical of an o2 sensor... When you first start your engine, the o2 sensor signal is ignored while the sensor heats up. While this is going, your ecu will mix fuel and air at a predetermined amount considered as safe. It is usually richer just to be on the safe side.... They when the 5 or 10 minutes has elapsed, it will start adjusting the mixture according to your pre-cat o2 sensors... One easy way of knowing if the o2 sensors have anything to do with it is simply unplug them... This will bring a code, but it will also force your ecu to run in safe mode (rich mixture)... if the problem goes away, you'll know it is related...
Again, if everything goes well for the first 10 minutes, I don't see why it will start going ruff afterward with the rpm apart these sensors... These are the only ones that are not taken into account by the ecu when first started (cold).... It's worth a shot and it takes 2 minutes to try.
Good luck.
asnorton44 wrote:^ He is probably buying a Maxima MAF which is 100% compatible for a fraction of the price, that's the route I went.
I did order a brand new maxima MAF from Victory Nissan in Chesapeake, VA off of ebay Ebay Auction for 2001 Maxima MAF Super cheap and already on it's way. They've got tons of good feedback, seem to be an excellent seller, and are a legit Nissan dealer. Man I hope this works because if ti doesn't I'll be at a serious loss.fleurys wrote:asnorton44 wrote:^ He is probably buying a Maxima MAF which is 100% compatible for a fraction of the price, that's the route I went.
Yeah I know, but even the maxima one is usually 200$....not 89 .... That's quite a saving.... we need to know about this...
