Nissan Forums / Infiniti Forums - NICOclub > Sentra Forum / Infiniti G20 Forum / NX Forum > 2.5l recall information (Printable Version)
Post Title: 2.5l recall information
Posted by: NISTECH at 12:54 PM 8/2/2003
Nissan Sentra Recalls
July 19, 2008
Make / Models : Model/Build Years:
NISSAN / SENTRA 2007-2008
Manufacturer : NISSAN NORTH AMERICA, INC. Mfr’s Report Date : JUL 02, 2008
NHTSA CAMPAIGN ID Number : 08V311000 N/A NHTSA Action Number: N/A
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:MASTER CYLINDER
Potential Number Of Units Affected : 169202
Summary: NISSAN IS RECALLING 169,202 MY 2007-2008 SENTRA PASSENGER VEHICLES EQUIPPED ROBERT BOSCH MASTER CYLINDER. DUE TO THE MACHINING IRREGULARITY BY THE SUPPLIER, THE INTERNAL SEAL GROOVE IN THE BODY OF SOME BRAKE MASTER CYLINDERS MAY ALLOW FOR A GAP IN THE GROOVE CONTACT AREA OF THE SEAL. THIS MAY RESULT IN BRAKE FLUID SLOWLY LEAKING FROM THE MASTER CYLINDER INTO THE BRAKE BOOSTER ASSEMBLY, CAUSING THE BRAKE WARNING LIGHT TO ILLUMINATE.
Consequence: IF THE WARNING LAMP IS IGNORED, ONE OF THE BRAKE CIRCUITS ON THE VEHICLE MAY NOT OPERATE AS DESIGNED INCREASING THE RISK OF A CRASH.
Remedy: DEALERS WILL INSPECT THE MASTER CYLINDER/BRAKE BOOSTER ASSEMBLY AND IF BRAKE FLUID LEAKAGE IS DETECTED, THE MASTER CYLINDER WILL BE REPLACED WITH A NEW ONE FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON JULY 23, 2008. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Notes: CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Post Title: Re: (nametakennow)
Posted by: deswood at 6:35 AM 4/14/2009
Hello,
I am new to this site. So you're saying that if I have pre-cat failure on 05 sentra se-r, I can get a free engine replacement?
Post Title: Re: (deswood)
Posted by: bendrummin at 3:53 PM 6/14/2009
my engine "failed" but Nissan replaced it! i'm back in the game with a new header and loctite on the butterflies..
Post Title: Re: 02 SE-R
Posted by: prprince at 7:11 PM 6/15/2009
My sentra is burning oil like crazy. Now its knocking >Nissan said there is only a recall on my ecu.. They cant do anything. I need to rebuild my engine so i guess im gonna go all out.
Post Title:
Posted by: Mike, Spec-V at 7:42 AM 6/16/2009
I have a 2002 spec-v that has just today (6/16/09) ruined it's second engine due to oil consumption.
I purchased the car new in 2002 and with in the first 20k miles had to replace the engine. I completely footed the bill, as the reason given for the failure was lack of oil. I assumed the shop that did the oil change did not put oil back in, I was pissed, but chalked it up to lesson learned. Now, at 140k miles the engine has failed this morning. It has been burning a quart a week for sometime, and apparently just gone beyond that..
I see some comments in the thread about "Nissan owing a new engine" and "02 - 03 can get new engine for pre-cat failure", but after contacting my dealer and Nissan North America I'm told there are no recalls for my vehicle in regards to the engine, other than reprogramming the ECU. And, I'm told that only applies to the ECU, not any repairs / replacement of the engine.
So, I'm very curious, where do I find the suggested recall information. What course of action have you guys had luck with?
Also, the first engine replacement cost 3.5k, this was in 2k3 or 2k4.
Post Title: Re: (Mike, Spec-V)
Posted by: prprince at 3:08 PM 6/16/2009
I've heard alot of stories pertaining to engine problems in the 02 SE-R. I think its a manufacturer issue and some thing needs to be done. They have a recall on the Altima 2.5 engines. Thats the same engine in the Se-R
Post Title: Re: (prprince)
Posted by: OrangeUaVol at 5:44 PM 7/29/2009
I have a 2004 Spec, besides the butterfly valves and pre-cat...are there any other open recalls?
Post Title: Car dies while driving
Posted by: Cilos02 at 1:42 AM 9/3/2009
I have a 04 sentra spec v, i been having problems with it for a while i would be driving and the car would just die on me, before it dies it would jurk then it would just die and i could usually just start it up again. The last time it did that to me it wouldnt start at all, I have gone to the dealership and they just say its the throtle sensor, it has been replace but the problem still exist. Has this happen to anyone else also and if it has how did you fix it, or if there are any suggestions it would be appreciated.
Post Title: Re: Car dies while driving (Cilos02)
Posted by: whiteblack04specv at 10:19 PM 10/16/2009
i have an 04 spec v and i would be driving and it would randomly cut off then back on and if i drove it for about 30 mins then turned it off an tried to start it again it wouldnt start and it was the crankshaft sensor . hope that helps.ps its under the back side and hard to get to if you have to change it.you have to kinda feel around for it .
Post Title: Re: 2.5l recall information (NISTECH)
Posted by: jesfusco at 9:54 AM 11/2/2009
i have a 2002 ser spec v and it burns oil you think that would be covered?
