Sentra Recalls
NissanXEPIlot
Car: 95 NIssan Hardbody , 06 Nissan Sentra
Location: Crystal Springs, Ms. 50 miles south from hell.
This is the most current list of known Sentra recalls I can get from work. For older model years you'll have to you your own research at http://www.nhtsa.dot.gov
RECALL: 2009 Nissan Sentra
NHTSA Campaign Number: 09V431000 http://www.nhtsa.dot.gov
Manufacturer NISSAN NORTH AMERICA, INC.
Recall Date: OCT 27, 2009
Potential Number Of Units Affected: 10586
Description SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:MASTER CYLINDER
Summary NISSAN IS RECALLING CERTAIN MODEL YEAR 2009 PASSENGER VEHICLES EQUIPPED WITH BOSCH MASTER CYLINDERS. BRAKE FLUID MAY LEAK FROM THE MASTER CYLINDER. IF THE AMOUNT OF BRAKE FLUID IN THE MASTER CYLINDER RESERVOIR DECREASES TO BELOW THE MINIMUM LEVEL, THE BRAKE SYSTEM WARNING INDICATOR WILL ILLUMINATE AS DESIGNED AND THE BRAKES WILL NOT FUNCTION PROPERLY.
Consequence IF THE WARNING LAMP IS CONTINUOUSLY IGNORED, ONE OF THE BRAKE CIRCUITS ON THE VEHICLE MAY FAIL INCREASING STOPPING DISTANCES AND INCREASING THE RISK OF A CRASH.
Remedy DEALERS WILL INSPECT AND REPLACE THE MASTER CYLINDER BRAKE BOOSTER ASSEMBLY FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING DECEMBER 2009.
RECALL: 2007-2008 Nissan Sentra
NHTSA Campaign Number: 08V311000 http://www.nhtsa.dot.gov
Recall Date: JUL 02, 2008
Potential Number Of Units Affected: 169202
Summary NISSAN IS RECALLING 169,202 MY 2007-2008 SENTRA PASSENGER VEHICLES EQUIPPED ROBERT BOSCH MASTER CYLINDER. DUE TO THE MACHINING IRREGULARITY BY THE SUPPLIER, THE INTERNAL SEAL GROOVE IN THE BODY OF SOME BRAKE MASTER CYLINDERS MAY ALLOW FOR A GAP IN THE GROOVE CONTACT AREA OF THE SEAL. THIS MAY RESULT IN BRAKE FLUID SLOWLY LEAKING FROM THE MASTER CYLINDER INTO THE BRAKE BOOSTER ASSEMBLY, CAUSING THE BRAKE WARNING LIGHT TO ILLUMINATE.
Consequence IF THE WARNING LAMP IS IGNORED, ONE OF THE BRAKE CIRCUITS ON THE VEHICLE MAY NOT OPERATE AS DESIGNED INCREASING THE RISK OF A CRASH.
Remedy DEALERS WILL INSPECT THE MASTER CYLINDER/BRAKE BOOSTER ASSEMBLY AND IF BRAKE FLUID LEAKAGE IS DETECTED, THE MASTER CYLINDER WILL BE REPLACED WITH A NEW ONE FREE OF CHARGE. THE RECALL BEGAN ON AUGUST 20, 2008.
RECALL: 2002, 2005-2006 Nissan Sentra
NHTSA Campaign Number: 07V527000 http://www.nhtsa.dot.gov
Recall Date: NOV 08, 2007
Potential Number Of Units Affected: 653910
Description ENGINE AND ENGINE COOLING
Summary ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH A 2.5L ENGINE, THE CRANKSHAFT POSITION SENSOR CAN OVERHEAT CAUSING A BRIEF INTERRUPTION IN THE SIGNAL OUTPUT FROM THE SENSOR.
Consequence IF THE INTERRUPTION IN THE SIGNAL FROM THE CRANKSHAFT POSITION SENSOR IS SO BRIEF THAT THE ELECTRONIC CONTROL MODULE (ECM) LOGIC DOES NOT HAVE TIME TO DIAGNOSE THE CONDITION, THE ENGINE MAY STOP RUNNING WITHOUT WARNING WHILE THE VEHICLE IS DRIVEN AT A LOW SPEED INCREASING THE RISK OF A CRASH
Remedy DEALERS WILL REPROGRAM THE ECM FREE OF CHARGE. CERTAIN MY 2006 ALTIMAS WHICH HAVE BEEN PREVIOUSLY REMEDIED UNDER RECALL CAMPAIGN 06V223 (NISSAN R0606) ARE NOT INCLUDED IN THIS RECALL SINCE THE REPROGRAMMING FOR 06V223 ALSO INCLUDED THIS REPROGRAMMING. THE RECALL BEGAN ON DECEMBER 31, 2007
RECALL: 2006 Nissan Sentra
NHTSA Campaign Number: 06V223000 http://www.nhtsa.dot.gov
Recall Date: JUN 20, 2006
Potential Number Of Units Affected: 85000
Summary CERTAIN PASSENGER VEHICLES EQUIPPED WITH 2.5L ENGINES MAY EXPERIENCE EXCESSIVE ENGINE OIL CONSUMPTION AS A RESULT OF IMPROPER PERFORMANCE OF THE PISTON RINGS.
Consequence IF THE OIL IS NOT MAINTAINED AT LEAST AT THE MINIMUM LEVEL, ENGINE DAMAGE CAN OCCUR AND IN EXTREME CASES RESULT IN AN ENGINE FIRE.
Remedy DEALERS WILL REPROGRAM THE ELECTRONIC CONTROL MODULE (ECM OR ENGINE COMPUTER). YOUR VEHICLE WILL ALSO BE INSPECTED TO DETERMINE IF IT HAS BEEN CONSUMING ENGINE OIL AT A HIGHER THAN NORMAL RATE. IN A SMALL PERCENTAGE OF VEHICLES, ENGINE REPLACEMENT WILL BE NEEDED. ON JUNE 9, 2006, NISSAN NOTIFIED OWNERS OF THE POSSIBILITY OF EXCESSIVE OIL CONSUMPTION AND THE IMPORTANCE OF MAINTAINING THE OIL AT A PROPER LEVEL. FOLLOW-UP LETTER TO OWNERS ADVISING THEM OF THE STATUS OF THE RECALL WAS SENT DURING AUGUST 2006. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261
RECALL: 2005 Nissan Sentra
NHTSA Campaign Number: 05V269000 http://www.nhtsa.dot.gov
Recall Date: 06/07/2005
Potential Number Of Units Affected: 44000
Description FUEL SYSTEM, GASOLINE:STORAGE
Summary ON CERTAIN PASSENGER VEHICLES, A VAPOR HOSE LOCATED IN THE FUEL TANK MAY NOT HAVE BEEN FORMED CORRECTLY DURING THE MANUFACTURING PROCESS. WHEN THE VEHICLE IS PARKED WITH A FULL FUEL TANK, FUEL MAY FLOW INTO THE VAPOR HOSE, WHICH IS CONNECTED TO A VAPOR CANISTER.
Consequence THE VAPOR CANISTER COULD BECOME FULL, AND EXCESS FUEL COULD SPILL OUT ONTO THE GROUND. FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE.
Remedy DEALERS WILL CHECK THE VAPOR HOSE CONNECTIONS IN THE FUEL TANK TO DETERMINE IF A POOR SEAL EXISTS. IF A POOR SEAL IS IDENTIFIED, A NEW FUEL TANK WILL BE INSTALLED. THE RECALL BEGAN ON AUGUST 15, 2005. OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261.
RECALL: 2003 - 2004 Nissan Sentra
NHTSA Campaign Number: 06V242000 http://www.nhtsa.dot.gov
Recall Date: JUN 28, 2006
Potential Number Of Units Affected: 294166
Summary ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH A 2.5L ENGINE, A VARIATION IN TEMPERATURE OCCURS DUE TO THE UNIQUE LOCATION OF THE SENSOR IN THE ENGINE. UNDER CERTAIN DRIVING CONDITIONS, THESE VARIATIONS IN TEMPERATURE CAN BE LARGE ENOUGH TO CAUSE A BRIEF INTERRUPTION IN THE SIGNAL OUTPUT FROM THE SENSOR.
Consequence IF THE INTERRUPTION IN THE SIGNAL FROM THE SENSOR IS SO BRIEF THAT THE ELECTRONIC CONTROL MODULE (ECM) LOGIC DOES NOT HAVE TIME TO DIAGNOSE THE CONDITION, THE ENGINE MAY STOP RUNNING WITHOUT WARNING WHILE THE VEHICLE IS DRIVEN AT A LOW SPEED INCREASING THE RISK OF A CRASH.
Remedy DEALERS WILL REPROGRAM THE ECM FREE OF CHARGE. THE RECALL BEGAN ON SEPTEMBER 20, 2006. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
RECALL: 2000 - 2003 Nissan Sentra
NHTSA Campaign Number: 03V455000 http://www.nhtsa.dot.gov
Recall Date: 11/17/2003
Potential Number Of Units Affected: 630000
Summary ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS.
Consequence THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH.
Remedy DEALERS WILL REPLACE THE CRANK POSITION SENSORS. VEHICLES INVOLVED IN A PREVIOUS RECALL CAMPAIGN, 01V357, ARE ALSO INCLUDED IN THIS NEW CAMPAIGN. THE REPLACEMENT SENSORS USED IN THAT CAMPAIGN ARE ALSO AFFECTED. OWNER NOTIFICATION BEGAN ON DECEMBER 22, 2003. OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200.
PapaSmurf2k3
Site Admin
Thanks for posting this, I'm going to add it to the recall list in the sticky at the top of the forum.
NissanXEPIlot
No problem, I'm hoping to have my hands on a list of warranty claims too. These are issues that pop up that are often supplier related but still has to be covered by the manufacture and on occasion lead up to a official recall.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Nice work!
NissanXEPIlot
Sorry I havnt posted the warranty claims yet. I've been slammed at work and just have not had the free time to follow up on this. :frown:
