The hose off the top of the valve cover has a small tear in it.........I wanted to replace it and the guy at the parts place told me not to worry about it right now........LOL! It'd be great if that's why......which hose was torn on yours?drksolest wrote:tear in a hose? that's what mine was doin... too much O2
LMAO!!! I'm gonna go do that then...........and then drive over and smack that guy at the parts storedrksolest wrote:HAHAHAHA THAT WAS SAME AS MINE! i changed it up n' it solved the problem
I thought IAC personally since I had that issue with my old VW, but we'll see. I replaced the hose and drove it home with no issues.......if this solves it I owe you a beer sometimedrksolest wrote:if not maybe the idle control valve... that's what i thought was wrong with my car till i found the tear.
Well..........that wasn't it.......we made it home fine, got some stuff done around the house for like half an hour.........go out to the car and turn the key and it won't start. Turns over fine again, but doesn't fire up. Hmmmmmmmm....anyone?drksolest wrote: let me know!!
I can hear it priming, but maybe I should pull the line and see if it's spraying.....like I said though, sometimes it runs fine and other times it just dies or won't start for no apparent reason.qat727 wrote:I know you said you replaced the fuel pump, but have you checked to see if it's actually running? Lately, my car has developed a problem that the fuel pump doesn't prime when I try to start the car. Hondas are notorious for losing the main relay that controls the fuel pump. I wouldn't put it past Nissan to have a similar problem.
I tried IM'ing you about it, but it looks like you aren't signed on. It sounds stupid, but if it won't start, then it's either not getting air, fuel, spark, compression, or timing.EastTN240 wrote:I can hear it priming, but maybe I should pull the line and see if it's spraying.....like I said though, sometimes it runs fine and other times it just dies or won't start for no apparent reason.
Just by that, it's spark...........it dies instantly and the revs drop extremely quick to 0..........no warning and it's already dead. I was assuming I wasn't getting spark since you hear it prime and can smell gas when it floods and it turns over and over but won't fire..........ShaunakaRichard wrote:In my experience the easiest way to tell if its spark or fuel is the manner in which the car dies. If your driving or the motor is running, if it does instantly, rpms instantly drop its spark. If its fuel the rpms would slowly drop as it looses more and more fuel pressure. Or when your cranking it over and it won't start. Do that then take a spark plug out and see if its wet, if it is your getting fuel. Another way is to take a spark plug out. Hook the wire to it, then touch the threads on the spark plug to a ground and have a friend crank the car. You should be able to see the spark plug spark. I've ran into many fuel and spark problems on a number of cars and normally doing these things will point you in the right direction.
I've got a new cap, new dizzy, and new wires already...........I'm guessing coil then.......ShaunakaRichard wrote:Then I'd replace/check the basics: cap, rotor, wires and coil.
I'll still get ya one next time I'm in Knoxville or if you are ever in the JC area...........just cus you motivated me to change that damn hosedrksolest wrote:Well damn, no beer fo me. Hope you figure it out!
Hey Mathew, hope you r doing k... I haven't called cause i lost my phone last weekend (ya again) so call me when u get a chance. (new phone, no numbers)
Yup, full tank.omgjacki wrote:Here's an obvious question... is there any gas in the tank?
If you make it down to Knox, I'd like to drive out and see that vert. Then again, I might be headed toward JC/Boone after a while.EastTN240 wrote:
I just went and got a new coil.............and let me be the first to say "DAMN THAT'S EXPENSIVE" along with all the other little parts that add up fast as hell.......another $100+ out the door.........had I not gotten the car for such a bargain I'd already be in buyer's remorse, but alas.......I love her, everytime I get behind the wheel(and she doesn't shut off) I get excited like I did the first time I ever drove a car that could actually handle fairly decent
I appreciate that! I swapped out the coil and guess what.............a day so far of trouble free drivingqat727 wrote:
I kinda feel bad for you about the cost. If you were closer, I've got some extra parts I could have slapped on to check it.
I'm glad to hear it's working thus far. Hopefully that took care of it.EastTN240 wrote:I appreciate that! I swapped out the coil and guess what.............a day so far of trouble free driving
Let's see if it holds true! I think she may be better off now If it fully checks out, I'm road tripping to Memphis and back next week maybe to get the 5spd conversion I picked up. If so, maybe I can bring it down to Knoxville and get some help at someone's place doing the swap...........it would be a first for me
I'll probably take you up on that bro! BUT.......it crapped out again........and left me stranded AGAIN! Some guy stopped and helped me with it, but he was under the impression it was the coil.......which I replaced yesterday......and still that brings me back to the question of why it's fine when I let it sit.......we have narrowed it down to the coil or anything before the coil on the harness.......could it be a bad ground? If so, pics of where I should check if you have 'em. Thanks for all the help guys/gals, this is just killin me thoughqat727 wrote:
Memphis is one hell of a drive for a S13 5 speed swap unless you got a killer deal. Either way, I'd probably be down for helping out with the swap, depending on when you'd be doing it. Might even be able to use my driveway if I can get a car or two fixed and moving
