Autozone i am guessing i should get this from?maxhopper97 wrote:You should be able to reuse your factory hardware. You may want to go ahead and replace the front strut bearings while you have everything out.
I called the dealership and those stupid things are 37 dollars a piece.maxhopper97 wrote:You should be able to reuse your factory hardware. You may want to go ahead and replace the front strut bearings while you have everything out.
Edit: You also need to check if your new struts/shocks come with boots.
Why did you get Blues for the front? Funds?lightsout wrote:take pix as you work on your car! BEFORE AND AFTER PIX Rock on with the Illumina's, ive got them in the back and LOVE them!! the Blues reside under the front end
The bearings are a little expensive. But i guess if you can only get them from dealer than your F'ed in the A.maxhopper97 wrote:Check post #3 in this thread. zerothread/56283 I got mine at PB's, can't remember what they cost.
