underground »
https://forums.nicoclub.com/underground-u11170.html
Tue Feb 13, 2007 2:40 pm
Hey Guys,
As I mentioned in a thread a few months ago, I am (with the help of about 20 sponsors) agressively working to finish our car in time for the NOPI 2007 Tour.
As it has been since 2004, the car will once again be featured in the BF Goodrich Tires Booth at select locations nationwide.
I'm going to make this the official thread, and will be updating the thread while we finish up the car.
Here is the current mod list, and the latest pictures/videos will be posted soon.
1998 RB26DETT 240SXWeight: 2950 lb. (w/o driver)Redline: 9000 RPM Motor: R33 RB26DETT w/ Ford C4 transmission w/ Transbrake and GearVendors OverDrive SetupCams: Tomei Poncams 260/260 Duration 9.15 Lift w/ Adjustable Cam Gears, Ferrea Springs, Retainers, Locks, and LocatorsPistons: JE 86.5 w/ Hi Performance Upgraded Rings, coated by Calico CoatingsTurbo Setup: Garrett GT4088R (.95 A/R) with Greddy T4 Divided ManifoldWastegate: Tial 60mmIntake: CustomLSD: Cusco RS 1.5 way LSDRods: Eagle Rods w/ ARP Rod BoltsInjectors: Precision 1000cc x6, Greddy 11.0 mm fuel railOil Pump: TomeiWater Pump: NismoTiming Belt: GreddyHeadgasket: Tomei 1.2mm Headstuds: ARPMain Studs: ARPBearings: CalicoDamper: ATI Super Damper (600-1000 HP Model)Downpipe: CustomMount Kit: McKinney Motor and Transmission Mounts, Custom DriveshaftStrut Bar: Cusco 40D 40mm Aluminum Strut Bar Gauges: Autometer Cobalt Series (Boost, Water Temp, Oil Pressure, EGT, Trans Temp, Air/Fuel, 5" Tachometer)Exhaust: Apexi Ex Mag 3.75" ExhaustCooling fans: Permacool (2) 12" High Perf. Electric Pull Fans, 3000 CFMIntercooler: XS Engineering 24x12x3 core with 3� pipingBlow off Valve: Apexi Racing Max PowerFuel system: Aeromotive FPR, Walbro 255/lph Intank Fuel Pumps x2, -8 feed line, -6 return lineEngine Management: AEM with 3.5 Bar Map Sensor and AEM Wideband SensorBoost Control: Apexi AVC-RSuspension: Apexi N1 V-Spec Drag Coilovers, Battle Version Rear Upper Control Arms, Rear Toe Links, Rear Traction Links, Front Tension RodsAxles: Mazworx Drag AxlesBrakes: Underground 300ZX Calipers/ Supra TT Rotors Brake Upgrade (Front)Stillen Supra TT Rotors (Front), Stillen 300ZX TT Rotors (Rear)Stillen 300ZX Racing Brake Pads (Front and Rear)PDM Racing Conversion Brake Lines (Front and Rear)Wheels: Motegi Prototypes 18x9 (3" lip) , 18x10 (3.5"lip) Gunmetal w/polished lipTires: BF Goodrich (Front) 225-40-18 KD, (Rear) 285-30-18 KDPaint: House of Kolor PBC-36 TruBlue PearlAero Kit: Cwings Carbon Fiber Body, OEM S15 Headlights/ Inner Cirlce S15 Front End Conversion
Modified by underground at 10:37 PM 5/1/2007
