drksolest
NICO's Crazy Cat Lady
91 240sx coupe
Knoxville TN
12-18-2007
tear in a hose? that's what mine was doin... too much O2
| Quote, originally posted by Hid-hq » | | Dear,Dattebayo,dusred,93coupe,drifterxrps13,G_whizz,Marlin29311,dITTOZ7DRKSOLEST, NUMBNUTS240,I really appreciate all the consideration and maturity in regards to my questions.... |
| Quote, originally posted by Dittoz7 » | | I'd Be Sideways With Flowers Pouring Out My Exhaust! Bishes Love Teh Flowers y0. |
| Quote, originally posted by snwbrdr435 » | | He has horrible aim for that thing, instead of tito getting the money shot it hit dittoz.... who was standing behind faizian. |
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (drksolest) | 9:25 AM 11/6/2008 |
| Quote, originally posted by drksolest » | | tear in a hose? that's what mine was doin... too much O2 |
The hose off the top of the valve cover has a small tear in it.........I wanted to replace it and the guy at the parts place told me not to worry about it right now........LOL! It'd be great if that's why......which hose was torn on yours?
drksolest
91 240sx coupe
Knoxville TN
12-18-2007
| « Re: (EastTN240) | 10:41 AM 11/6/2008 |
HAHAHAHA THAT WAS SAME AS MINE! i changed it up n' it solved the problem
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (drksolest) | 10:45 AM 11/6/2008 |
| Quote, originally posted by drksolest » | HAHAHAHA THAT WAS SAME AS MINE! i changed it up n' it solved the problem |
LMAO!!! I'm gonna go do that then...........and then drive over and smack that guy at the parts store Thx! I'll let you know if that gets it
drksolest
91 240sx coupe
Knoxville TN
12-18-2007
if not maybe the idle control valve... that's what i thought was wrong with my car till i found the tear.
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (drksolest) | 1:17 PM 11/6/2008 |
| Quote, originally posted by drksolest » | | if not maybe the idle control valve... that's what i thought was wrong with my car till i found the tear. |
I thought IAC personally since I had that issue with my old VW, but we'll see. I replaced the hose and drove it home with no issues.......if this solves it I owe you a beer sometime
drksolest
91 240sx coupe
Knoxville TN
12-18-2007
| « Re: (EastTN240) | 1:57 PM 11/6/2008 |
let me know!!
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (drksolest) | 4:53 PM 11/6/2008 |
| Quote, originally posted by drksolest » | let me know!! |
Well..........that wasn't it.......we made it home fine, got some stuff done around the house for like half an hour.........go out to the car and turn the key and it won't start. Turns over fine again, but doesn't fire up. Hmmmmmmmm....anyone?
qat727
catching's before hanging
Oak Ridge TN
7-21-2006
| « Re: (EastTN240) | 5:51 PM 11/6/2008 |
I know you said you replaced the fuel pump, but have you checked to see if it's actually running? Lately, my car has developed a problem that the fuel pump doesn't prime when I try to start the car. Hondas are notorious for losing the main relay that controls the fuel pump. I wouldn't put it past Nissan to have a similar problem.
- MatthewNot all who wander are lost. FAQ/Write-up: S13 HVAC/climate control and dash switch light bulb replacement. One Helluva deal: 2 S13 240SX hatches and huge parts cache for $1500
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (qat727) | 6:56 PM 11/6/2008 |
| Quote, originally posted by qat727 » | | I know you said you replaced the fuel pump, but have you checked to see if it's actually running? Lately, my car has developed a problem that the fuel pump doesn't prime when I try to start the car. Hondas are notorious for losing the main relay that controls the fuel pump. I wouldn't put it past Nissan to have a similar problem. |
I can hear it priming, but maybe I should pull the line and see if it's spraying.....like I said though, sometimes it runs fine and other times it just dies or won't start for no apparent reason.
qat727
Oak Ridge TN
7-21-2006
| « Re: (EastTN240) | 7:19 PM 11/6/2008 |
| Quote, originally posted by EastTN240 » | | I can hear it priming, but maybe I should pull the line and see if it's spraying.....like I said though, sometimes it runs fine and other times it just dies or won't start for no apparent reason. |
I tried IM'ing you about it, but it looks like you aren't signed on. It sounds stupid, but if it won't start, then it's either not getting air, fuel, spark, compression, or timing. If it normally runs fine, but randomly dies and won't restart, you can pretty safely eliminate compression. I had a KA that liked to jump time and ultimately blew up on me. However, I had to manually reset the timing before it would restart. If the timing hasn't jumped, then you can eliminate that. If you can pull the fuel rail away from the manifold, you can check for fuel spray when it isn't starting. Christina brought up an interesting point. It could be your IACV. However, if it is, it should still start right up if you press on the accelerator to let some air go in. Air coming in from behind the MAF will screw with the sensors and might make it die. That's not too hard to check for though. You might want to check your spark. It's possible you've got a coil that is crapping out. Personally, my bet would be on fuel or spark. Either it's something simple (dying coil, fuel pump relay, etc.) or there might be some sensor causing the computer to cut the signal to the injectors or the coil. P.S. Although there aren't a huge number of us, it looks like only the TN people have touched on this thread.
ShaunakaRichard
92' 240sx sr20det Redtop
Redding California
7-10-2006
| « Re: (qat727) | 8:08 PM 11/6/2008 |
In my experience the easiest way to tell if its spark or fuel is the manner in which the car dies. If your driving or the motor is running, if it does instantly, rpms instantly drop its spark. If its fuel the rpms would slowly drop as it looses more and more fuel pressure. Or when your cranking it over and it won't start. Do that then take a spark plug out and see if its wet, if it is your getting fuel. Another way is to take a spark plug out. Hook the wire to it, then touch the threads on the spark plug to a ground and have a friend crank the car. You should be able to see the spark plug spark. I've ran into many fuel and spark problems on a number of cars and normally doing these things will point you in the right direction.
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (ShaunakaRichard) | 8:19 PM 11/6/2008 |
| Quote, originally posted by ShaunakaRichard » | | In my experience the easiest way to tell if its spark or fuel is the manner in which the car dies. If your driving or the motor is running, if it does instantly, rpms instantly drop its spark. If its fuel the rpms would slowly drop as it looses more and more fuel pressure. Or when your cranking it over and it won't start. Do that then take a spark plug out and see if its wet, if it is your getting fuel. Another way is to take a spark plug out. Hook the wire to it, then touch the threads on the spark plug to a ground and have a friend crank the car. You should be able to see the spark plug spark. I've ran into many fuel and spark problems on a number of cars and normally doing these things will point you in the right direction. |
Just by that, it's spark...........it dies instantly and the revs drop extremely quick to 0..........no warning and it's already dead. I was assuming I wasn't getting spark since you hear it prime and can smell gas when it floods and it turns over and over but won't fire..........
ShaunakaRichard
Redding California
7-10-2006
| « Re: (EastTN240) | 8:39 PM 11/6/2008 |
Then I'd replace/check the basics: cap, rotor, wires and coil.
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (ShaunakaRichard) | 8:48 PM 11/6/2008 |
| Quote, originally posted by ShaunakaRichard » | | Then I'd replace/check the basics: cap, rotor, wires and coil. |
I've got a new cap, new dizzy, and new wires already...........I'm guessing coil then.......
drksolest
91 240sx coupe
Knoxville TN
12-18-2007
Well damn, no beer fo me. Hope you figure it out!Hey Mathew, hope you r doing k... I haven't called cause i lost my phone last weekend (ya again) so call me when u get a chance. (new phone, no numbers)
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (drksolest) | 7:56 AM 11/7/2008 |
| Quote, originally posted by drksolest » | | Well damn, no beer fo me. Hope you figure it out! Hey Mathew, hope you r doing k... I haven't called cause i lost my phone last weekend (ya again) so call me when u get a chance. (new phone, no numbers) |
I'll still get ya one next time I'm in Knoxville or if you are ever in the JC area...........just cus you motivated me to change that damn hose I just went and got a new coil.............and let me be the first to say "DAMN THAT'S EXPENSIVE" along with all the other little parts that add up fast as hell.......another $100+ out the door.........had I not gotten the car for such a bargain I'd already be in buyer's remorse, but alas.......I love her, everytime I get behind the wheel(and she doesn't shut off) I get excited like I did the first time I ever drove a car that could actually handle fairly decent
omgjacki
I have a few 240s
Philadelphia PA
7-1-2008
Here's an obvious question... is there any gas in the tank?
1989 240SX coupe project 1989 240SX hatch shell 1990 240SX hatch daily 1993 240SX coupe sold
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (omgjacki) | 11:06 AM 11/7/2008 |
| Quote, originally posted by omgjacki » | | Here's an obvious question... is there any gas in the tank? |
Yup, full tank.
qat727
Oak Ridge TN
7-21-2006
| « Re: (EastTN240) | 5:54 PM 11/7/2008 |
| Quote, originally posted by EastTN240 » | I'll still get ya one next time I'm in Knoxville or if you are ever in the JC area...........just cus you motivated me to change that damn hose I just went and got a new coil.............and let me be the first to say "DAMN THAT'S EXPENSIVE" along with all the other little parts that add up fast as hell.......another $100+ out the door.........had I not gotten the car for such a bargain I'd already be in buyer's remorse, but alas.......I love her, everytime I get behind the wheel(and she doesn't shut off) I get excited like I did the first time I ever drove a car that could actually handle fairly decent |
If you make it down to Knox, I'd like to drive out and see that vert. Then again, I might be headed toward JC/Boone after a while. I kinda feel bad for you about the cost. If you were closer, I've got some extra parts I could have slapped on to check it.
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (qat727) | 8:01 PM 11/7/2008 |
| Quote, originally posted by qat727 » | If you make it down to Knox, I'd like to drive out and see that vert. Then again, I might be headed toward JC/Boone after a while. I kinda feel bad for you about the cost. If you were closer, I've got some extra parts I could have slapped on to check it. |
I appreciate that! I swapped out the coil and guess what.............a day so far of trouble free driving Let's see if it holds true! I think she may be better off now If it fully checks out, I'm road tripping to Memphis and back next week maybe to get the 5spd conversion I picked up. If so, maybe I can bring it down to Knoxville and get some help at someone's place doing the swap...........it would be a first for me
qat727
Oak Ridge TN
7-21-2006
| « Re: (EastTN240) | 11:40 PM 11/7/2008 |
I'm glad to hear it's working thus far. Hopefully that took care of it. Memphis is one hell of a drive for a S13 5 speed swap unless you got a killer deal. Either way, I'd probably be down for helping out with the swap, depending on when you'd be doing it. Might even be able to use my driveway if I can get a car or two fixed and moving
Zoom45
Terry MS
7-21-2008
| « Re: (EastTN240) | 8:07 AM 11/8/2008 |
I have a 92 vert with the same problem. Mine may run perfect for 1000 miles then quit. Usually it will start up after letting it sit a day or two. It may run rough but will clear out and be ok. The last time it quit it won't start now. Turns over fine. Have good spark, fuel pumps out the line, injectors ohm out and click when it does run. I found a good computer and tried that but no change. Any ideas? Zoom45
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (qat727) | 3:35 PM 11/8/2008 |
| Quote, originally posted by qat727 » | I'm glad to hear it's working thus far. Hopefully that took care of it. Memphis is one hell of a drive for a S13 5 speed swap unless you got a killer deal. Either way, I'd probably be down for helping out with the swap, depending on when you'd be doing it. Might even be able to use my driveway if I can get a car or two fixed and moving |
I'll probably take you up on that bro! BUT.......it crapped out again........and left me stranded AGAIN! Some guy stopped and helped me with it, but he was under the impression it was the coil.......which I replaced yesterday......and still that brings me back to the question of why it's fine when I let it sit.......we have narrowed it down to the coil or anything before the coil on the harness.......could it be a bad ground? If so, pics of where I should check if you have 'em. Thanks for all the help guys/gals, this is just killin me though
Zoom45
Terry MS
7-21-2008
| « Re: (EastTN240) | 4:53 PM 11/8/2008 |
Sounds like yours is doing exactly what mine is. I have been asking questions on here about it for months but no one seems to have the right answer. I took it to a dealer and they said they would just start replacing parts (computer and all the sensors). I put another computer off a running car and it didn't help. If anyone wants it I'll take $2,000 for it. It might crank and run fine for a month and it may not crank. Never can tell. When it does run it runs like new. It must be an electronic sensor or something but I can't go keep buying $100 or more for parts you don't know will fix it. It's a 92 240SX SE limited edition, automatic convertible, white with black top and gray interior. Great shape just has this weird problem. Zoom45
qat727
Oak Ridge TN
7-21-2006
| « Re: (EastTN240) | 6:10 PM 11/8/2008 |
Honestly, if my car were doing this, I wouldn't keep replacing parts. I'd check the grounds next. I looked all through my service manual and the wiring diagrams. It looks like all the stuff for the ignition system goes through 2 grounds, F10 and F20. F10 is toward the back of the engine, and it looks like it comes out of the same loom as the EGR and SCV solenoid plugs. FYI, those both are bolted to a vacuum manifold on the back of the head next to the firewall. F20 is near the injectors. It looks like it comes out of the injector harness loom and bolts to the intake. For what it's worth, I'd take both those loose and clean them really well. If you feel like digging the ECU out, I can get the pin #'s for everything in the ignition system so you can do a continuity check on the wires. With as intermittent as the problem is, I'd lean toward wiring issues. If you're good with a multimeter, there are ways of checking just about everything on the car. As an aside request for either of you with the problem if you're able to do it: The next time the car won't start back up, pull the distributor out and put the ignition in the run position. Disconnect the coil harness and spin the drive gear on the distributor and see if the injectors click. If they do, then plug the coil back in and pull the 10A fuel pump relay fuse. (I think it's the middle one in the bank of 3 in the underhood box.) Either use a neon tube spark checker (If you've got on) or an old plug grounded to the engine and see if it sparks while you're spinning the distributor.
If you're able to do the electrical checking, I'll provide any of the pinouts and locations my FSM's have. If you were closer, I'd throw in a hand.
Modified by qat727 at 6:48 PM 11/8/2008
Zoom45
Terry MS
7-21-2008
| « Re: (qat727) | 7:48 AM 11/9/2008 |
This is the best reply I have had on this subject. Thanks I'll try those things. My ECU number is A11-C03 G61 2417 and it has a big green number 81 on it. I bought another one that came from a running 1993 with an automatic that has a big green EQ on it. It didn't make a difference. My car usually would crank the next day after it quit. It usually would try to run (spit and sputter bad) then it would clear up. Now it just spins over and doesn't sound like it wants to crank. It is getting spark. I stuck a screwdriver in the end of the wire and had my wife spin it over. It sparks bright blue but only if you almost touch a ground. It doesn't jump far. All plugs are getting spark. It is getting fuel pressure. I pulled the line off to the injectors and it will fill a bottle quick when you turn the ignition on. Thanks, Zoom45
Zoom45
Terry MS
7-21-2008
| « Re: (Zoom45) | 8:05 AM 11/9/2008 |
I just noticed something new. If I turn the ignition on and push the gas pedal I hear a buzzing noise from behind the head. If I push the pedal toward wide open the sound eases up and quits at wide open. What is making this noise? It sounds like it's coming from behind the head but I can't get my hand back there to feel for it. There are two ground wires on the back drivers side of the head. They are good shape and tight. I did not see another ground by the injector harness on the intake. Zoom45
qat727
Oak Ridge TN
7-21-2006
| « Re: (Zoom45) | 10:08 AM 11/9/2008 |
I wish I still had my coupe around here so I could try to look at it and see what might be the problem. All I've got left is my hatch that I bypassed and removed A LOT of this stuff on. Regardless, let me take a look around my car and see what might be causing the noise.
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (qat727) | 2:49 PM 11/13/2008 |
Well hell..........I don't know why I didn't trust my gut in the first place......but......I had at one point (before doing the new coil anyways) thought that the Viper alarm installed before i got it (but told it didn't work) could possibly somehow be using the ignition disable thing to kill the car........I mean hell it would explain the sudden loss of power to the coil and why it would work later after sitting, so today......and excuse the phone pics, but I decided to pull all this crap outta the car: I still have to finish hooking up the wires and such, but I had to head to work (where I am now) and didn't want to rush anything. It's been an eventful day though and I'm feeling confident that this WILL fix it
qat727
Oak Ridge TN
7-21-2006
| « Re: (qat727) | 8:49 PM 11/13/2008 |
I'm glad to see you found it and got it out. Let me know how it goes. To Zoom45: I'm sorry I haven't had a chance to get out and check my car yet. Things have been really hectic and it's been raining on and off for the past 3 or 4 days. I did get to thinking about what you'd said, though. The noise you're describing could be coming from one of the vacuum solenoids, or it could be transferring from the IACV solenoid. If you can, use an extension or something to act as a hearing rod of sorts to see if you can identify what the sound is coming from. There are two solenoids behind the head, one for the SCV the other for the EGR. The IACV solenoid is on top of the bottom intake runner at the back. As for the grounds, just because they're tight doesn't mean they're clean. It can't hurt to make sure they aren't corroded underneath. It's unlikely, but not unheard of. BTW... You don't have an alarm, do you? LOL
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (qat727) | 11:57 AM 11/14/2008 |
So I finished the wiring and it fired right up..........rode down the street fine, but unfortunately........(not my day) I picked up a nail in the tire. I took the wheel/tire down to a shop to get patched and now it's back on the car. I'm driving it to work tonight (about a 35 mile round trip) and that will be the test. I have faith this fixed it
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (EastTN240) | 1:52 PM 11/18/2008 |
So after a tad over 100 worry free miles..........I was at a wheel/tire place getting my tires balanced today and when they went to take it off the lift it cut off again as soon as he put it in reverse.......same problem as before, the coil was getting NO POWER..........any ideas on why my coil would lose power? New coil btw. I would really NOT like to redo the whole wiring harness.
qat727
Oak Ridge TN
7-21-2006
| « Re: (EastTN240) | 2:21 PM 11/18/2008 |
That sucks, man. The first thing that came to mind was a problem my car has been giving me that if you turn the ignition on but do not start the car, the idiot lights stay on until you put the car to reverse. I never could figure out why it does it, but my car is a 5 speed. I looked back over all the diagrams again. The only thing I can find that might cause it would be loose wiring in the coil circuit or the ECU. I'm not sure if the ECU has some sort of programming to kill voltage to the coil under certain circumstances. I know there are fuel pump shutdown circuits. I haven't seen any documentation of an ignition shutdown circuit on these cars, but it's possible the ECU is causing the problem. Another possibility is a partially broken wire in the ignition circuit. If it was in contact most of the time, but under certain vibrations came loose, it could cause it. The only problem with these ideas is that they're difficult if not impossible to test for. I hate to say it, but you might have to rip the car apart and start working on the harness.
EastTN240
'93 S13 Vert
Johnson City TN
10-20-2008
| « Re: (qat727) | 2:24 PM 11/18/2008 |
Well hell.........I guess I should start looking for a wiring harness.........
qat727
Oak Ridge TN
7-21-2006
| « Re: (EastTN240) | 2:26 PM 11/18/2008 |
Let me know if you find a good one. I've yet to meet a Nissan without some kind of wiring problem.
EastTennBimmin
94 BMW 325is, 93 BMW 325is, 92 Nissan 240sx Coupe
Blountville TN
9-9-2008
| « Re: (qat727) | 7:05 AM 11/20/2008 |
Hey I'm in Blountville and just last night had this same problem...Cleaned up some wiring did the hot cam swap and hooked up my CD player car made it outta the garage and about a tenth a mile down the road and just quit...haven't gotten to look at it 2day but let me know if you figure anything out and I'll do the same...PS-I'd like to see this clean vert
Modified by EastTennBimmin at 2:18 PM 11/20/2008
Zoom45
Terry MS
7-21-2008
| « Re: (EastTennBimmin) | 1:47 PM 11/21/2008 |
Mine still won't crank. My plugs are real wet with fuel and it's getting good blue spark. Could it be getting too much fuel and if so why? It's all stock S-13 with automatic. Runs like a new one when it does crank. Zoom45
qat727
Oak Ridge TN
7-21-2006
| « Re: (Zoom45) | 4:33 PM 11/21/2008 |
It's possible that it's flooding out and fouling the plugs. Then again, that's usually a function of a lack of ignition more than too much fuel. What you can do is disconnect the wires from the injectors once the plugs are wet to see if it fires at all. Have you verified that the engine is in time? Have you tried ether?
| First 1 2 > Last |
