 RB20DET swap into D21
jmd
86 D21 & 79 280zx
Baton Rouge La
8-21-2008
I have a 89 d21, I just ordered a RB20Det swap to go into it. I have searched this and many other websites and googled about this swap, only to find nothing. Has anyone heard of or know of this swap being done in a hardbody? I have found plenty sr20 swaps but not the first rb swap.
Modified by jmd at 11:26 PM 9/14/2008
nismopu
1987 300zx, 1997 Max, and 1976 Turbo Z
VANCOUVER WA
6-24-2005
 « Re: RB20DET swap into D21 (jmd)
Its been done in a frontier before but the pics are hard to find. There was a vid floating around of it on youtube for a while but I havent seen that either in a while. lol! The engine bays are virtually the same size maybe slightly wider but deffinately not much longer. peace.
jmd
86 D21 & 79 280zx
Baton Rouge La
8-21-2008
Got the engine swap in tuesday, installed it wednesday, wired it today and got it running.
Reverend D
Altima Moderator
1995 Nissan D21 Hardbody KA24E
Western NY
1-12-2003
You seriously had to shoehorn that thing in.
hessianben
2002 Nissan Frontier ka24de
huntington beach ca
10-26-2006
 « Re: (Reverend D)
Wow! Lets see some more pics!!! I honestly have never seen or thought of that swap before!!! There're so few SR20 (edit: RB haha oops!) swaps.... Nice work on goin out on a limb!
Lets see it run!
Modified by hessianben at 10:52 AM 9/21/2008
jmd
86 D21 & 79 280zx
Baton Rouge La
8-21-2008
 « Re: (hessianben)
I could have got it in without an problems. I did cut out the very center of the upper radiator support, welded 1/8 plate metal to it, matched it and drilled holes to match the existing radiator mount holes, so now the whole center section is now removable, to make working on the front of the engine very easy. I am getting the driveshaft shortened Tuesday, so it should be driveable by next thursday or friday. Not too bad to have swap like this in and completed in a week or less. Motor sounds very good and strong, I need to order a turbo gasket and a MAF. But first I am going to try wiring a Ford Ranger MAF the size matches and the specs. So in theory if wired correctly it should work and priced way less. I have some much better pics with my camera I will post up later, all those pics were from my phone.
jmd
86 D21 & 79 280zx
Baton Rouge La
8-21-2008
 « Re: (jmd)
Here are some better pics
nismopu
VANCOUVER WA
6-24-2005
 « Re: (jmd)
It doesn't look like any firewall mods, and did you just flip the shifter plate around or did you do a front transmission case swap? I think its cool that its like the VG's and that it just bolts into the front crossmember. peace.
jmd
86 D21 & 79 280zx
Baton Rouge La
8-21-2008
 « Re: (nismopu)
Quote, originally posted by nismopu »
Yes I just flippped the shifter plate 180 degrees. As far as bolting into the crossmember, it does not. I had to cut the engine mounts of the frames and move them forward 6-7"s then reconfigure and reweld them to the frames. Match the tail section for the tranny mount, make sure the engine is centered and high enough to clear the front sump oil pan so it does not hit the steering centerlink and the turbo clears the steering shaft. The Z24 engine is a rear sump, so it makes it a little tricky. The trans mount went straight in with no problems.
Not sure about how long it will be now before I can get the driveshaft cut down, because I live in Baton Rouge and we are about to be nailed by hurricane Gustav. But when it gets done I will post up some more pics.
nismopu
VANCOUVER WA
6-24-2005
 « Re: (jmd)
WOW! It looks like factory mounts from the pics so, good job on the fab skills! I didn't realize the RB20 was a front sump design. Anyway, yeah keep things bolted down man and come back to us when that **** b lows over. peace.
hessianben
huntington beach ca
10-26-2006
 « Re: (jmd)
MMmmmmm....
.....spaghetti.....
have fun with the wiring!
jmd
86 D21 & 79 280zx
Baton Rouge La
8-21-2008
 « Re: (hessianben)
Quote, originally posted by hessianben »
MMmmmmm....
.....spaghetti.....
it really is not as bad as it looks. that pic is of the new harness mixed in with some the old harness to be remov ed. not sure how long it will take to finish now. hurricane done some major damage here locally and to my shop.we haven't had power for 3 days. i am posting from my cell which just got working today.
hessianben
huntington beach ca
10-26-2006
 « Re: (jmd)
Wow- Hope everyone's ok! Keep us posted. Good luck!
sr20gt30r
Nissan Skyline GTR 1990
Monteregie QC
9-6-2008
Does someone know if it's harder to fit an RB20 in a D21 4WD?
TeamGuam
Cheyenne Wyoming
9-6-2008
 « Re: RB20DET swap into D21 (sr20gt30r)
nice job
jmd
86 D21 & 79 280zx
Baton Rouge La
8-21-2008
Quote, originally posted by sr20gt30r »
should be the same exact swap as mine other than trans issues and possibly the front sump oil pan possibly interfering with the front axle.but anything is possible, it time time, thought & money
jmd
86 D21 & 79 280zx
Baton Rouge La
8-21-2008
Wiring done and 97 dash installed.
AL1222
hardbody
ANAHEIM ca
7-6-2008
does the 97 dash fit right or do you have to modify it to make it work...i want to put that dash in my hardbody..i have a sr20det in mine...but great work man!!! let me know about that dash thanks
Quote, originally posted by jmd »
jmd
86 D21 & 79 280zx
Baton Rouge La
8-21-2008
 « Re: RB20DET swap into D21 (AL1222)
Quote, originally posted by AL1222 »
there are a couple mods, the defrost duct and the two side ducts are different, the steering column mount it different and needs modding, the center support and driver side brace is different, and the lower mount on the left and right sides are different. the ac panel from the old d21 fits back into the 97 dash, all you do is swap the face plates. the instrument panel has to be completely rewired, and you will need a 97 speed sensor because it is electronic not cable.
SO basically if you have a 97 truck that has the complete dash and can get the speed sensor, your good to go. It sounds like a lot but it's really not bad.
If you decide to do it, email or pm me and I will email you both IP panel wire diagrams to rewire it.
ANYHOW..... I cut and shortened the driveshaft, it's in and the truck drove out the shop and back in on it's own power for the first time. I just ordered the AFM yesterday. I put the carpet and 79 280zx center console, getting ready to install the 280zx seats. only things left now are the intercooler and radiator and it's ready for the road........well actually for it's first drift comp in 3 more weeks.
Modified by jmd at 11:05 PM 10/10/2008
poopoobutter
95 Pathfinder, 92 Hardbody
Franklin North Carolina
12-26-2007
lol bad A$$ swap A+++. Say good bye to traction on the rear tires, defiantly don't use a open diff.
95hb
1995 nissan hardbody
mesa az
1-20-2008
 « Re: (jmd)
what did you do for motor mounts. cause i am thinking of doing an rb25
jmd
86 D21 & 79 280zx
Baton Rouge La
8-21-2008
 « Re: (95hb)
i
Quote, originally posted by 95hb »
I used the motor mounts that came on the rb20
mitch
S14a, S14, S13 Sil80
Oxford U.K.
8-26-2005
 « Re: (jmd)
Did you take any pics of the engine mount work you did, and did you say that the transmission crossmember bolts straight up?
nismopu
VANCOUVER WA
6-24-2005
 « Re: (mitch)
Thats an fs5w71c tranny pictured above so it most deffinately will bolt up to the stock crossmember.
mitch
Oxford U.K.
8-26-2005
 « Re: (nismopu)
I'm not sure if I was too clear. I meant does the RB mount fit straight onto the D21 body or do you use the D21 crossmember?
nismopu
VANCOUVER WA
6-24-2005
 « Re: (mitch)
the HB has a fs5w71c transmission so there fore the fs5 used on the rb20 in the pics will bolt up to the HB crossmember. If your talking about an engine crossmember there is none. peace.
» Return to Nissan Trucks Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
