nametakennow
Sentra Moderator
Online
'01 Sentra SE w/pp
Atlanta GA
8-24-2002
Here we've lumped Sentras together. The same engines were used throughout the 90's and the chassis are very similar all the way to 2006.We have several very nice B13s. One of the other Mods has a turbo'd SE-R with ~280whp. Take a look around and you should find any info you need. If not, post up and ask.
The DD - '01 Sentra SE (RR SR20DE) w/pp (VLSD, FSTB), a few mods Sentra Table of Contents *Read it BEFORE posting!* Get your Nissan/Infiniti's FSM FREE here. Need parts? Look here!
matt147
Pittsburgh
1-5-2003
| « Re: (nametakennow) | 6:57 AM 5/3/2008 |
I have a B13 SE-R with a DET swap pushing about 270-300whp (I haven't been on a dyno since I upgraded turbo setups over the winter). Its a pretty fun ride although its not very pretty right now (needs paint badly).
Matt 91 SE-R w/DET 99 G20 daily ride 02 G20 Sport 5spd 93 240SX Family Project
RED_DET
Super Moderator
2004 6 speed G35 Sedan, 2002 Sentra SE-R Spec V, 1992 Nissan Sentra SE-R SR20DET
Louisville, KY
5-13-2003
<------------- http://www.nicoclub.com/ROTM/rotmmar08.shtml
 Factory Service Manuals can be found here
Heavy_D
Worcester MA
6-4-2007
| « Re: (RED_DET) | 11:47 PM 5/3/2008 |
yea i seen that, looks good, i seen some more cars on youtube, and street fire, right now im trying to pass the emissions, i think my timing went off, what do you guys think? the car has a little hesitation when giving a little bit of gas, and im not burning all the fuel, thats what they told me, hope fully i can put the mani back together tomorrow, right now i have to cars that im trying to fix which is my toyota and this nissan, the toyota i did alot on, and now im doing a motor swap soon to it also, and i would love to hook this sentra up, i always loved nissans and toyotas, my two favorite cars.
Heavy_D
Worcester MA
6-4-2007
| « Re: (Heavy_D) | 12:28 AM 5/4/2008 |
also one more thing, i would like to get a cluster that has the rpm tach on it, the SER models only has that for the b13? i remember reading somewhere that the 91-92 where diff from the 93-94, dont remember. would i be able to get this at a junk yard?
Heavy_D
Worcester MA
6-4-2007
| « Re: (Heavy_D) | 6:55 PM 5/4/2008 |
well a little update, i changed the egr pcv valve, clean the hoses out, and still does the little hesitation, i tried playing with the timing and still does any one know if it can be the coil pack on the distributor?
RED_DET
Super Moderator
Louisville, KY
5-13-2003
Have you checked the TPS voltages along with the MAF voltages to make sure they are in spec? http://forums.nicoclub.com/zerothread/298476The 91-92 cluster are a little different in appearance from the 93-94. The SE model also came with a Tachometer. The 91-92 cluster are mechanical speedometers and the 93-94 are electronic. They all can be found in junkyards.
Heavy_D
Worcester MA
6-4-2007
| « Re: (RED_DET) | 10:38 AM 5/5/2008 |
i dont have a volt meter but i would be looking into that,i change that coil pack and still does it, also is it good for that when i disconnect the MAF the car still run but when i give gas i get fuel cut, but im going to buy a volt meter to see what i get, whats the rating volts suppose to be?
RED_DET
Super Moderator
Louisville, KY
5-13-2003
| « Re: (Heavy_D) | 4:07 PM 5/5/2008 |
look in the link above
wildfilly
1991 Nissan Sentra SER
Eldersburg MD
2-14-2008
| « Re: b13 sentra (Heavy_D) | 4:56 PM 5/12/2008 |
I have a 1991 SER, white, 2-door, 5 speed that recently blew a headgasket. I'm selling it for $500. It was in pretty good shape for being 16. 5 yrs old and you could probably use lots of parts off it. But, sadly, I dont have the skills to fix it myself--and paying the mechanic is getting too expensive. It was a blast to drive--I'm the original owner. Car is located in Central Maryland. Tranny is working just fine--no 5th gear pop out!
Heavy_D
Worcester MA
6-4-2007
| « Re: b13 sentra (wildfilly) | 10:48 AM 6/8/2008 |
ok i did some work today after i just got some free time, well i read some more yesterday night and i checked the EGR and i read where it said to plug up the bottem hose from the egr and the other valve well i disconnect it and pluged it up and drove around and it stoped my hesitation, so i took it out a little cause the screws was too rusted and i sprayed some carb cleaner but still does the problem, do you guys think i should just get a new one or just to keep trying to clean it
subiebui
old 1995 Nissan 240sx new 2006 Subaru Impreza WRX
williamsport pa
6-15-2008
| « Re: b13 sentra (Heavy_D) | 7:19 PM 6/15/2008 |
i hope you figured out your problem. but if you're not going to jump on that offer from above i will
500dolla
1993 G20 Infiniti
Chelmsford MA
3-5-2007
| « Re: b13 sentra (Heavy_D) | 9:52 PM 6/15/2008 |
Not mine, but clearly something to drool over:D
dwlf89
1995 Nissan 200sx SE-R, 1993 Sentra (SE-R swap)
lakeland fl
7-20-2007
| « Re: b13 sentra (500dolla) | 9:38 AM 6/17/2008 |
| Quote, originally posted by 500dolla » | Not mine, but clearly something to drool over:D |
clearly.
zoneoneoni
Nissan 240SX SR20DET
Claremont CA
3-23-2007
| « Re: b13 sentra (500dolla) | 3:49 PM 6/25/2008 |
What the hell engine is that? Hahahaha.
 I'm generally in the 23% area.
ishkabibble
1993 NX Coupe
moving to Portland, OR
11-5-2006
| « Re: b13 sentra (zoneoneoni) | 11:22 AM 6/28/2008 |
| Quote, originally posted by zoneoneoni » | | What the hell engine is that? Hahahaha. |
Looks like a 20V SR20VE with a turbo added on to it. Obviously very modified.
"I am prepared. I am prepared. I need no on-the-job training. I wasn’t a mayor for a short period of time. I wasn’t a governor for a short period of time." - John McCain in 2007
crams_A_problem
Queens village new york
3-9-2007
| « Re: b13 sentra (Heavy_D) | 11:46 AM 6/28/2008 |
i got one but its not nice....yet lol
Heavy_D
Worcester MA
6-4-2007
| « Re: b13 sentra (crams_A_problem) | 8:21 AM 7/4/2008 |
well i found out what was the problem, its the egr valve solenoid, it was not letting it get air thro to lift the egr, does any one know how much that cost? autozone said they dont sell that, im planning on going to the junk yard buthave to wait till moday
magoo1
91 se-r /94 infiniti g20/91 corolla/87 mazda b2000
festus mo
8-8-2008
heres my old girl:
 Pretty much stock but thats the way i like it.
StealthWhiteB13
1993 Sentra SE-R
Palo Alto California
8-15-2008
| « Re: b13 sentra (Heavy_D) | 2:41 AM 8/15/2008 |
Everyone's SE-R are so nice compared to mine dammm lol but guys i'm trying to decide what should i do first i got alot of options just not alot of money so i can first go and do suspension have the car dropped inch inch and a 1/2 stiffen it up a bunch do alot of suspension work or... go and buy my new engine first cuz mines going on 200k (it still has like 50k in it if i baby it) or... do i save up a #$% load and go way up to the SR20DET???? and keep stock suspension and stuff for another year or so till i have that upgraded (problem is if i do that i gurentee i'm going to have to do a brake kit to slow it down because brakes are more forgiving than trees are.... also scrd if i go to the DET then i'm going to have tooo much power and it wont handle as well which is about all its good for right now) or.... just do bolts ons then get rid of it when the engine dies http://forums.nicoclub.com/zer...14475# i honestly have no clue what to do because the car functions PERFECT but its been beaten up and barely passes smog and both front fenders have been hit and dented and the paint is not very nice. not bad but its got alot of scratches and scrapes
but its stealth as heck and no one ever suspects its fast and i can easily avoid tickets cuz they don't even give me a second look guys help seriously need it thanks
johnnyboy91
91 sentra se-r
tolleson az
9-6-2008
| « Re: (matt147) | 7:08 PM 9/6/2008 |
i was wondering if you went the GTi-r or the blue bird sr20 cuz thats alot of power your pushing
