I have been workin on this thing like a freight train man, if i can get the head studs and fel-pro HG in it will be done(haha) by this weekend!
So today i spent the whole day re-doing my intake manifold. Making sure there was no possible way i could have a vacuum leak, and polishing the runner ports so they will resist carbon buildup from the fuel. Also polished the runners up themselves. Im going to find some type of metal-sealant-spray-paint type stuff to coat them with. Sandblasted aluminum just soaks up grease like none other. It looks bad real quick.
I found a pretty simple way to run coolant to my turbo, so i will be doing that. Heres the writeup i did on that.. --->
zerothread/300407
I had to do some crazy stuff to get my Nismo FPR to fit(80 bucks, brand new, another STEAL from Nico classifieds).. I thought that the nismo for the ess arr worked with the Ka. However this isnt really the case. The bolt that allows you to change your fuel pressure runs directly into the heads, making it so your intake manifold wont bolt up. After staring at it for a little bit, i figured out a practical solution. Went inside, and checked that thread with the cross section of the Ka's head. Made sure there was no water/oil galleys in the area that the bolt was hitting first, to see if my idea was feasible. When i checked, there was nothing but solid metal there, so i got the idea to drill some of the head out to make the FPR bolt fit.
First though, i took the bolt out of the FPR and took it to the bench grinder and ground off the head of the bolt, so i was just left with a threaded rod. Then, i took some paint and dabbed a bunch of it on the end of the bolt. After that, i put my intake manifold on and let the bolt touch the head, so i could get exactly where i needed to drill on the head marked. Started with a small drill bit, and drilled about a 3/8ths inch deep hole at a downward angle into the head. Then i used three other bits to expand the hole to the size of the threaded rod/bolt from the FPR. Worked like a charm. First try, the manifold lined up, the FPR fit, and we are in business.
Only catch is, is that i have to adjust the FPR with a pair of needle nose plyers now, which really isnt that big of a deal. Ill toss up some pics tomorrow of what i did.
