mounts vs. member poll
MOB240
Car: 1995 nissan 240sx
just to get an idea of what works best.....
Sil240
Car: Nissan S13 "The One Cam Wonder"
Totally Custom would be best.It would make sure that everything is correct for YOUR car. Not just a generic S chassis.
But with the Skyline X-member you can rock the HKS cas bottom mount mani that I want soooo much.
Because I have top hat mounts.And NO turbo outlet fits my car.
Take a look at what I did:
SStrunks
Car: 1994 Honda Accord & Soon to be a RB25DET S14
so where is the syko performance kit option? i'm going with that one...still uses skyline x-member...
nvm I see theres a link to write in my own choice...hehe
Joe
dude just have one made, thats what i did.
that indent is HELL on your exhaust flow.
Sil240
Oh yeah not running stock turbo anymore.
I'm running a t3/t4 with a Vband adapter and custom DP. That DP was just to get me going.I spent LOTS of time beating the shyt outta that thing lol.
wawazat8402
Car: 89 Sil80- RB25DET
i voted custom. I started with a set of cheap Ebay Top Hat knockoffs so I would have a better idea of how everyone else was doing it. Used them to make my own for different placement of the engine and a much more solid mount. Theyre 3/8" steel and use the stock R33 dampeners.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Tophat, no problems, no complaints. /Thread for me
Carl H
xmember is the only route to go imho, solid and safe.my engine doesnt move when i rev it ive had stock rb20's try and torque their way out of the engine bay using mount kits.
rustbucket
Car: '90 s13 RB25DET SII
top hat mounts are ok if you put a solid polyurethane transmission mount in, exhaust fitting is an issue all the way back in the s13
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
R33 X-member + NISMO isolators FTW!
Stock turbo has about 1/2" clearance from the steering shaft. No complaints.
Modified by l0nestar at 4:55 PM 9/13/2007
benjamin725
Car: 96 240 se 92 240
I agree with Carl H, By the way awesome job on the wiring. Everything works great, i even used the DLC on my scanner to dial in the tach.
Sil240
oh yeah I can squish the rubber isolater with my bare hand too. FYI
blurrbosi
Car: 240's
JGY YAY!!!
Sil240
jgy is Top hat or at least copies.
rbosacco
Car: 97 discovery1, 99 yukon, 97 240 rb26 in progress, 72 280se benz 4.5, 03 gti, 98 vr jetta chump car, 91 straight axle 2500 suburban, 00 f350 super duty crew cab 4wd, v70 volvo wagon and a built warrior
i have mckinney's mounts and am very unimpressed. i had to modify them to get my engine into the right position. installing them the way they told me to the hood just touched the engine. i fixed the problem. but for the money that you pay, it should bolt in, line up and properly position the engine. whenever my car is on my lift in front of someone new, i am always asked "those mounts were how much? and they didn't just work?" if i could go back i'd go new crossmember all the way. not a single doubt in my mind.
eh?
Sil240 wrote:Totally Custom would be best.It would make sure that everything is correct for YOUR car. Not just a generic S chassis.
Stop being cheap and get one made.
I've had "unstable hybrids" aka top hats for about 5 yrs now.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
I have had Mckinney mounts for several years and they have worked well. under hard cornering my dp would touch the steering shaft so I ground it slightly and it works fine. The only issue I seem to have now is that my front sway bar isn't clearing in my new chassis. I am just going to build some mounts to lower it a little for clearance.
Sil240
Reading is Fundamental.....
Check 2 posts down.
eh?
I thought that was your custom dp
s14_girl
Car: Nissan 240sx ('96 s14 w/ SR20DET RIP) '95 s14 w/ RB26 current
I'm not impressed with the Top Hat ones. Unfortunately they are now welded in.
Sil240
Hahaha well I guess it is pretty "Custom" haha.I'm ghetto but not THAT ghetto. lol
DETurbine
Car: Nissan S13 RB25
I kept the stock R33 crossmember and had no problem with it. Only problem that I ever ran into was the steering shaft, but that was a 10min fix and if you wanted complete clearance it is as simple as just taking off the o2 housing and making a custom down pipe to fit up to the back of the turbo and welding a o2 bung on it.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Had the tophats at 1st then switched to the thicker Mckinney. Didn't have to bash my firewall with the tophats but the Mckinneys I had too. Motor went back more in the engine bay.
Reaper
Car: 96 & 91 240sx
I'm rocking the top hats with a modified McKinney DP. works perfect for me.
300Plus
Car: 1995 S14 w/ Rb25det Series II
wait... who is the 3rd person who voted for NateCo mounts? lol I thought there were only the 2 of us?
Sil240
Why are there two Skyline X-members???
thenillaz
Car: 92 240sx Hatch
<noob Do you have to weld the skyline x-member in?
Sil240
Nope bolt on.
Check out the Stickys on the top of the page.
LOTS of good info up there.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
r32 x member
rotorimp
Car: 02 Xterra, 60 IH Metro
Mine cost 2015$
2000 for the Tig and 15$ for the metal
came with free Custom intercooler piping, complete one off exhaust and anything else I want--Ha ha
