Chris@AMS »
https://forums.nicoclub.com/chris-ams-u39428.html
Thu Jan 11, 2007 2:40 pm
After over 100 hours of development time and more than 8 manifold revisions our turbo kit is ready to release to the public!
Our manifold incorporates stainless 1 ¼” schedule 10 weld-els, and all stainless CNC cut flanges which are meticulously TIG welded in-house by our top notch fabricators.
The newest development in our manifold production is the incorporation of the 44mm V-band wastegate which allows you to run a minimum of 6lbs of boost with absolutely NO BOOST CREEP (on 50 trim sized turbo), so that you are able to maximize your current setup.
The Manifold is guaranteed to be free from defects for the period of two years after the purchase date.
Because of this manifold’s unique, bottom mount design it will gain you several specific benefits:
Flow through the manifold will be in the same direction as the scroll of the turbo. Lower center of gravity than top mount manifolds which is a big plus for all of the drifter/road racing/ auto-x cars that wish to go turbo.Un-matched quality and product support before during and after your turbo kit installation. As an added bonus the manifold also includes
Our turbo kit will include:Bottom mount manifold, guaranteed for 2 yearsStainless steel downpipe, with stainless steel flanges, and two O2 bungs, which will bolt up to any factory CAT or Factory style HFC / test pipe. Stainless steel dump tube, with stainless v-band flange, atmospheric dump-3 Oil feed line-8 Oil return line kit TiAL 44mm wastegate for years of reliable, gasket less, useA choice of one of two great turbos, which can be tailored specifically to your setup. All hardware, (nuts, bolts, washers), and gaskets needed for a clean installMr. Gasket Copper exhaust gasket to complete you manifold to head sealing needs.
Our special introductory price for the first 5 turbo kits will be $2995
Modified by Chris@AMS at 1:54 PM 1/22/2007
