 Dyno SheetsFirst  1 2 >  Last
rexhunta
Sniffing Laundry Powder
Subaru Impreza Wagon
Bunbury, Western Australia
2-2-2005
  Dyno Sheets
Hey guys, just a thought, i think we should have a sticky of dyno runs with CA's.. just so we know how all are going and things.. so, post up your sheet, and give a few details
I'll start.. stock CA, stock ca turbo, gtr injectors, frontmount, walbro fuel pump, safc, full 3 inch and hks dump pipe and a really dodgy boost controller as you can see
So guys, please, post your sheets up !!
Pete.
Attachment: 170.JPG (69786 bytes, downloaded 16175 times)
boost_boy
Supporting Member
Online
B12 sentra w/built CA18DET, B12 sentra w/fully built CA18DET, b13 sentra w/CA18DET
Miami Fl
11-14-2002
 « Re: Dyno Sheets (rexhunta)
Mods include:
1 internally stock CA18DET
SDS EM-3F engine management system
4 MSD 72lb/hr injectors
Walbro 255lph fuel pump
Custom turbo manifold
T3/T04E stage III turbo .60 A/R and .48 exhaust housing
Custom bar and plate intercooler
Greddy Type R BOV
Blitz dual SBC boost controller and turbo timer
Oil, boost and A/F gauges
Custom axles
Complete NX2000 brake system
Nissan Maxima brake booster
Custom gear box
This run was done in January of this year.
This run was done on the same day, with the same mods, but with 20 pounds of steady boost.
This run was in January of 2004 and done with the same mods above except for the fact that the turbo was smoking, a different turbo manifold, 2 bovs, the car was run a bit hot along with the intake temps being a bit too high for me, and a set HKS 264 cams with 8.5mm lift, and boost was set at or around 13-14psi. I'll post more when I get a chance.
Dee
Dee
tineira
4-10-2005
 « Re: Dyno Sheets (boost_boy)
this is mine.
100% stock everything , base map.
NON JAP spec engine (Chile)
Attachment: 200sxstock.jpg (208399 bytes, downloaded 17992 times)
Not_a_sr
90 ca18 pwrd 240sx FB
dayton oh
12-19-2004
 « Re: Dyno Sheets (tineira)
mods so far
stock injectors
Ka24e Maf
Cp pistons
264 cams
tomei valve springs
log manifold
Evo III big16G
custom open dump 2.5" 02housing 1.5" dump tube.
3" exhaust no cat or test pipe.
walbro 255 not hardwired (will be doin so ASAP)
this computer is acting up so ill post the videos and dyno sheets later...
but give me some of your guess's of what i made power wise!!!
blitz SDC-id boost controller (not hooked up correctly tonight ) so i couldnt dial in boost like i wanted too... 13.6psi, and a 14.1psi run, i also have a nasty leak between the manifold and head so i think im loosing some spool up time .
http://www.ForcedFabllc.com
Spectre23
AE86 BBQ, S13 CA
West Jordan Utah
11-10-2003
 « Re: Dyno Sheets
Well, I posted mine on a thread a few months ago, but now that there is a sticky, I will repost it.
Base run on this chart is 11 psi aka "Low Boost". The Test run is at 15 psi aka "High Boost".
Mods include: 440cc injectors, Nismo FPR, 3" Megan Racing turbo-back exhaust, ARC side mount intercooler, GT28R turbo, Walbro 255 lph fuel pump, Greddy Profec B spec II, custom tune ECU (yaaay romulator), crappy spark plugs for tuning, Q45 MAF (stick to Z32 if you are smart), oh yeah, an AFE cone filter too. The engine internals top and bottom are completely stock.
Attachment: dyno2Nissan.jpg (129154 bytes, downloaded 16370 times)
http://www.team-arg.com/cars/benson/benson.html
boost_boy
Supporting Member
Online
Miami Fl
11-14-2002
Quote, originally posted by SLIPIN »
hey people im all the way from NEW ZEALAND and just found your web site i own a s13 200sx with a CA18DET in it. its great to have a forum all about CA's heres a couple of pics of my car and my CA_POWER!!!!!!! motor
and my dyno
hi thanks for the warm welcome hahaha the spec of my motor well her it goes
Custom made turbo rated up to 600hp same size as a T66
Port and polished (flow bench tested) head done buy leading edge cylinder heads
Heavy duty valve springs and new valves in the head
Cam’s inlet 278’ Exhaust HKS 256’
Tomei adjustable cam gears IN/EX
Ross forged pistons
Shot penned rods
A polished and balanced crank and all new race bearings
500hp walbro fuel pump
710cc injectors
mallipassi fuel pressure regulator
Z32 airflow meter
Trust type R blow off valve
All aluminum custom intercooler piping
Custom FMIC
Custom top mount headers
Custom 1.5mm steel head gasket
Custom made 5 puk heavy duty clutch made buy exedy race clutches in OZ
Custom made steel lightened flywheel
Custom made 3 inch dump pipe straight off turbo
Custom made 3 inch exhaust all the way through
38mm delta gate mark 2 wastegate
60mm Enlarged throttle body
Apex’i AVC-R electronic boost controller
Apex’I AP Engineered CA18DET Power FC
Samco sport blue intercooler joiners and 3 inch into 4inch turbo joiner
Radiator has been cleaned and new top hats put on
New water pump
New battery
All new belts
Brand new DBA slotted and cross drilled brakes
Brand new up graded brake pads
Adjustable coilover shocks - hot bits (this is the brand name there not stolen)
17in x 7.5in TE37 Replicas with 215’s on them
This is all I can remember of the top of my head but I know I’ve missed a few things
the tune that its in at the moment is only a half tune it was tuned on 96octane pump gas and it had only 10km "6miles" on the motor when we put it on the dyno so we only took it up to 7000rpm and 18psi when i take her back im hopeing for 300rwkw @ 8500rpm and 25-26psi of boost
nismoplsr
connecticut
10-19-2003
Mods:
~GT28RS (Disco Potato)
~Lucas 550cc injectors
~NISMO adjustable fuel pressure regulator
~Z32 TT fuel pump
~TurboXS Type-H BOV
~Unorthodox lightweight underdrive crank pulley
~Spearco 26x6x3 interooler
~2.5" intercooler piping
~2.5" exhaust
~Haltech E6K
~Greddy TT
~Greddy Profec-B specII
Project Johny 5 - 1988 Nissan PulsarNX SE sportbak ~ too much to list
Daily Driver - 2008 Nissan Sentra SE-R Spec V ~ MR coilovers, Wedsports
Kicky-Fast
RPS13
PDX OR
10-19-2005
 « Re: (float_6969)
Well my friend told me to post...had my Ca for over a year and on my 2nd 240 in 3 years LOL so heres what i put down...with following mods :
Stock Turbo
Stock ECU
Stock Injectors
Stock single cam fuel filter
Plugs gapped to 35
Custom DP 2.5"- 3"
Custom 3"inch exhaust
Hi-Flow Cat
FMIC with 2.25" piping
HDR ( home depot racing ) boost controller at 1.0bar spikes at 1.2bar
92 octane pump gas
Walbro Supra TT fuel pump
capwred
attalla al
7-28-2005
i got my ca running ok after all the trouble i have been having with it in the last week.still not running just right.but i had a ok dyno run.i put down 159 at 10psi and 189.5 at 13.5 psi.the air/ fuel was 12 straight across.i think it will hit 200 after getting it running better.i was running old plugs and that was on 93 octane pump gas.maybe next month i will get to go back and do some more dyno runs before i get the new turbo.i will get the sheet on here later
mods on the car
sr t25
blitz boost controller
greedy 3inch down pipe
3inch high flow cat
3inch trust cat back
elec. fan
safc2
ca18det powered 240sx
http://www.alabamagz.com
silvia_ca18det
350whp ca18det drift silvia
Lethbridge alberta
8-12-2005
 « Re: (Kicky-Fast)
here is my dyno sheet from spring time, i have recently dissasembled motor to make way for 400+hp here is a dyno sheet done in japan!
Modified by silvia_ca18det at 10:15 PM 12/8/2005
Bugatti
200SX -92
Pori
3-14-2006
 « Re: (WYT R1CE)
Mods:
-Accralite forged pistons 0,50oversized
-Sten Parner motors h-profile steelrods(4340)
-Jun intake/exhaust cam 264/9,3mm
-Adjustable cam gears
-Gt3076r-wg
-1,2mm Trust headgasket
-Stainless steel manifold
-550cc Denso injectors
-Front mounted intercooler
-Megan racing fuel pressure regulator
-3" system from turbo
-Rpc-x Stage 2 Cluth
-Apexí avc-r
-PLX m-250 + 52mm gauge
257hp@6500rpm 0,79bar/11,45psi More to come
Modified by Bugatti at 4:14 AM 5/24/2006
Attachment: 0,79bar@257hv(pieni)copy.jpg (44209 bytes, downloaded 13089 times)
JDMSIL80
7-17-2005
Here's my mod list:
Bone stock motor
Garrett GT28R
444cc GT-R injectors
Horsham stage 3 chip or Apexi Power FC
Blitz I-D color EBC
FET coil pack
XS Power FMIC
XS Power turbo manifold
XS Power down pipe
Megan Racing exhaust
HKS SSQV recirculated
HKS Power filter
Z32 MAF
Walboro 255 fuel pump
The first run I pulled with 11psi netted me with 222whp & 176wtq
Then we did a couple more runs by increasing the boost level.
And finally, I made with 289.7whp @ 6500, 258wtq @ 5800 @ 18 psi
Modified by JDMSIL80 at 7:25 AM 7/18/2006
mikesim
Winnipeg, Canada
4-25-2004
 « before and after
Before: cat back exhaust, stock boost, 80F day.
After: GT2530 turbo, 3" turbo back, DSM injectors, walbro 255, s-afc 2, greddy 10x10x4 FMIC (stock pipes), greddy vvc, and WG actuator had no pre-load, so boost came in really late. 88 F day. AFR's 10.5:1 in full boost. ecu was enriching the afr's to compensate for high IATs due to hot and humid day.
I'm taking it back after figuring out the boost problem the other day.
1989 Silvia K's|HKS GT2530|HKS 256/264 cams
rexhunta
2-2-2005
225.8rwhp.
t25g, emanage blue, 444 injectors, rb20 afm, stainless mani, full 3 inch, fmic. 1 bar.
f s t caz
rhd CA18DET s13/stock s14
Va Beach VA
12-2-2003
GTiR T28
SSAuto equal length manifold
ssauto elbow
full 3" exhaust - no cat
hallman boost controller - ~13psi
Z maf
450cc injectors
tuned on s-afc
OverBoosted180
89' 240sx
Miami Fl
1-17-2006
Here's the results from last week's dyno session that Dee and I did. The car was tuned pretty much to perfection with the car revving out at 6800 rpms due to a malfunction with the MSD and the SDS's limiter.. Imagine 8000+ RPM's.....Stay Tuned..This was the car's first dyno session EVER!
Dyno Session Pt. 2 Coming Soon..........
/<*Growing Slowly, But SURELY!*>\
OfficialJFyre@yahoo.com
float_6969
1995 Nissan 240sx
Topeka Kansas
8-26-2002
197RWHP @ 15psi
CA18DET
stock cams
port and polish
SSAC mani
CA T25
3" turbo back exhaust
Forged aluminum pistons
bored .020"
10:1 compression
balanced bottom end
lightweight flywheel
SDS EM4-F
There are no torque curves on this chart. This is a comparion of the CA's T25 at 10 psi vs about 15psi
Resident CA Parts Hoarder #2 I think we all know who #1 is...
Quote, originally posted by themadscientist »
Ask for directions to soapland, bring about Y50000 and don't take your mom.
NeedCAforS13
Supporting Member
E46 M3 and SR S14
Oldsmar/Tampa FL
1-13-2003
 « Re: Dyno Sheets (float_6969)
finally got to a dyno with my new turbo. 268whp at 15psi.
internally stock motor, stock cams, stock headgasket
stock exhaust manifold and o2 housing
s14 bb turbo (gt28r)
dsm turbo injectors (460cc)
maxima n60 maf
r33 gtr intercooler
3 inch downpipe, 3.25 inch exhaust
horsham developments stage 2 rom tune
safc2or injector and maf correction
hallman manual boost controller
car feels really good this was a 4th gear pull by the way.
1SlowCA18DET
Flower Mound TX
4-27-2005
t3t04e 60 trim @16 PSI
Using rom editor and a pocket romulator
z32 maf
750cc injectors
sard fuel pressure regulator
z32tt fuel pump
cp pistons
sideways danny
s13, CA18DET
UK
7-27-2005
wiseco forged pistons,
lightened balanced bottom end
std flywheel lightened 4.5kg
re-worked cylinder head, quench removed, extensive porting (4 port head)
1.3mm ACL MLS head gasket
CA18DE inlet cam
port matched inlet manifold
KA24 Throttle body, plenum opening enlarged
mild steel tubular exhaust manifold,
GT2860RS 0.86a/r @0.9bar
standard O2 housing
2.5 inch scorpion exhaust (twin exit)
large FMIC painted matt black
RPS Max Street clutch
370cc injectors
s13 ca18det standard AFM
Modified by sideways danny at 7:06 PM 1/3/2007
50-50
Sick Swapper
1992 240sx coupe
rex ga
2-10-2007
235whp, 211ft/lbs @ 10psi
299whp, 247ft/lbs @ 15psi
EDIT: MODS
Stock ca18det
Ported Intake TB Opening
stanza Ka24e Throttle Body
GM Coil packs, Waste Spark Ignition, Custom Dwell Map in ECU
3" O2 Pipe, Full 3" Exhaust with Testpipe
Precision GT3071R dual BB Turbo
Stock airbox with K&N highflow filter
Socketed ECU with custom tune
FMIC 31x4x6
Custom Oil Catch Can
PS & AC Belts removed
N60 MAFS
Nismo FPR @ 55psi
Modified by 50-50 at 2:10 PM 5/15/2007
Sick Swapp eR
Nunook
nowhere FL
9-16-2004
 « Re: (50-50)
I just got back from the dyno alittle while ago, and it was pretty good. In my stupidity, I forgot about my cam gears and couldve tuned for alittle more.
This is:
stock ca18det w/
s14 nonBB t28 w/ hks adj. wastegate actuator
10lbs of boost
ebay aluminum pulleys, NO A/C
altima fans
JohnnyRaceCar Intercooler 2.25 hot side, 2.5 cold side piping
Self Tuned ECU
s14sr AFM w/ K&N cone filter.
3" Dump, DP, exhaust
stock injectors Sard FPR raised to 42psi
stock throttle body, stock exhaust manifold
about 145cylinder compression and metal shavings in oil
Nunook
nowhere FL
9-16-2004
 « Re: (Nunook)
These were when I just got my engine installed and broken in.
The first is stock boost, stock KAE fuelpump, T25g, crimp bend steel intercooler pipes with no BOV. on a 7mgte stock intercooler YES clutch fan, A/C, 3" downpipe and exhaust. Air filter.
The 5th run is same setup, same day but 12lbs of boost, Home depot MBC.
I love MBC.
jrtuning_ben
s13 200sx
hull
2-12-2007
 « Re: (Nunook)
Car
1989. 200SX RS13; CA18DET
Power-related mods
k&n air filter
apex group buy fmic
xspower manifold and elbow
3 inch exhaust system
ca16 inlet cam
ka24 60mm tb
440cc injectors
.86 gt28rs
wiesco +1mm forged pistons
1.6mm metal head gasket
rb20 afm
ocho map
walbro fuel pump
z32 fuel filter
Boost
1.3 bar on avcr but averaged at 1.2 on rr
RR Results
363.3bhp @flywheel
330 lbs/ft
all with a dodgy overfuelling issue
BigTone
guess!!!
CARDIFF
8-23-2004
heres mine...
project phoenix
sydwayz
1992 nissan 240sx
union grove wi
10-3-2007
 « Re: (BigTone)
over 600 hp is baller but that has to be on an engine dyno
Rookieca18det
93 hatchback (ca18det)
ft.lauderdale fl
10-20-2005
I dont know man ND builds some sick cars...not sure if that is who built the car.
I WOULD CUT OFF MY LEFT PINKY TOE TO SLEEP WITH ROSARIO DAWSON!!!
"Chance favors the prepared mind." - Louis Pasteur
float_6969
1995 Nissan 240sx
Topeka Kansas
8-26-2002
 « Re: (Rookieca18det)
http://www.norrisdesigns.com/demo-s13.asp
Nuff said...
ca18silvia_n.a
s13 silvia
Sydney NSW
11-2-2007
Hi guys, this is my first post on this forum so please let me introduce myself real quick, my names Daniel and I drive an s13 Silvia. I live in Sydney, Australia.
My car has a 100% stock CA18DE engine. Because of new laws here in NSW I cant drive a turbo/supercharged car until I have my full license which is another 3 years away. So my aim is to build up a non turbo CA that everyone will admire.
The cars first dyno run was very dissapointing even for a stock non turbo, but this gives a lot of room for improvement as long as the engine isn't completely stuffed
Here are my dyno results:
sideways danny
s13, CA18DET
UK
7-27-2005
same mods as before but with adition of RB20 AFM, 460cc injectors (RX7) Tomei 256/8.5 cams and some more boost
Two-Fortee
180sx.
Whitby Ontario
11-7-2007
 « Re: (sideways danny)
Any idea what I would likely hit with thes mods?
Internally stock ca
Garrett GT28r turbo off an s14
Front Mount Intercooler
Greddy RS BOV
K&N Intake
3" turbo back exhuast with testpipe
Walbro 255 Fuel Pump
HKS EVC IV Boost Controller
I'm figuring about 210whp on stock boost....
Noz
1991 200SX S13
Leicester, UK
11-4-2006
Stock CA18DET engine, well almost! Just running 2 x standard headgasket:
382.8bhp & 326.2lbft @ HUBS or
285.45kW & 441.77Nm @ HUBS
1.7 bar on an SSA T70 (=Garrett T61 copy I believe)
Is this the highest power non-forged CA? Please let me know cos I've got more boost to spare
Modified by Noz at 6:12 PM 2/28/2008
chausaster
1990 Nissan 240SX Fastback CA18DET
Logan Utah
5-24-2005
Well here's my dyno chart from a 2 years ago when I was learning how to use megasquirt. I was running 15 psi on a t28 turbo, megasquirt I v2.2 fuel only, stock ignition, 2.5" exhaust, 460cc injectors, FMIC, yada yada
Hillkill
s12
Briisbane CA
7-13-2005
s14 t-28~1.1bar
550 injectors
z32 Maf
FMIC
Chipped Ecu
Safc2
Hks Pod Filter
Greddy Type S BOV
Circuit Sports Dump/Downpipe
Stupid Manual boost controller
Coated and heat wrapped tubular exhaust manifold
Os Giken twin plate and flywheel
Copper plugs for a honda???
Ka throttle body and bored intake manifold
All IAC stuff is gone
Reused Greddy headgasket and Arp head studs
Stock Head and internals
And the Best Part is it's in a S12
Giallo spyder met
Nissan 200sx -92 Euromodel
Jonkoping
2-15-2007
More to come...
Had a break down.
On regular fuel.
21FOX21
Las Vegas NV
9-16-2005
401whp 342tq CA18DET
11.700@119.59
Built and tuned by TREVTEC MOTORSPORTS using Nistune
Trevtec.com
Giallo spyder met
Jonkoping
2-15-2007
 « Whp on 2bar and E85.
New Swedish record.
And now its mine..
Its 514hp at the hubs and 330hp/L and no racefuel or nos.
n13scb
Glasgow East kilbride
8-13-2008
Ca18det:
Top mount t34 turbo
Stainless system
Apexi filter
omex 500 ECU
Gtr injectors
Rx7 fmic
magnus in aus
89 nissan silvia
brisbane qld
1-30-2008
I made 204 kw @ 16 psi
makes full boost at 16psi at 3800rpm and peak power at 6500
I have a boost leak atm, so it goes to 20 psi and leaks back to 16psi.
will sort it out and go back and tune for 20 psi
Ca18det
forged bottom end
rebuilt head
HKS 264* with 8.8mm lift in and out
Trust Td05 16g with external gate low mount
Gtr injectors
microtech ecu
walbro lift pump & 044 feed pump
straight pipes
fmic
heres a bad video, doses like a VL
http://au.youtube.com/watch?v=C-PVvtb4XGA
[img]http://g.imageshack.us/img296/dsc00098ej9.jpg/1/[img]
jrsink
tampa fl
3-16-2005
 « Re: (magnus in aus)
here's mine.223 WHP
ca18det with t28 pulsar turbo running with megasquirt and ford escort EDIS ignition, FRONT MOUNT,FULL EXHAUST. thaTS IT!
WHAT DO U THINK?
TUNED BY MARTIN AT ZFEVER IN TAMPA.
Team Race Bread- RB26dett. The best thing since sliced bread! <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/images/smilies/evil_laughter.gif" BORDER="0">
Image exceeds 600 x 200 sig size limit.
 First  1 2 >  Last
» Return to CA18DE / CA18DET Forum
