Shocks, springs, sway bars, coliovers, bushings, brakes, rims, tires - You name it, this is the spot to discuss Altima suspension modifications!
WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub?
Postby LongBeachCoupe » Sun Jun 22, 2008 7:16 am
Ok guys i get a decent amount of emails asking me basic fitment questions on what wheel sizes will fit our Altimas.
First, the bolt pattern is 5x114.3 (some places may call it 5x114, dont get nervous)
Lug Nut size is 12 x 1.25 (make sure to pick up a thin wall socket)
Something that is very important is staying close to the stock diameter of the entire tire/wheel combination.
Check this site out. http://www.miata.net/garage/tirecalc.html Once you find the wheel you like, use that to find the right tire size.
3.5 Stock Information
17x7.5 26.3" Diameter +45 offset ---> 215 / 55/ 17. This means, the tire is 215mm wide, the side wall is 55% of the width of the tire (215 x .55 = 11.825cm) ... 11.825cm / 2.54cm per inch = 4.655 inches for each side wall. 4.655 x 2 (two sidewalls)= 9.31 inches + 17 inches (size of wheel) is 26.31 inches. (incase you wanted the math)
So for a 20" rim, you could get a 225, 235, 245, or 255 cm wide tire, however, note that when you go wider with the tire, the smaller the sidewall is gonna be in order to fit close to factory specs. And the smaller the sidewall, the more uncomfortable the ride will be.
For 20" rims, here are some possible tires to stay close to factory specs
225/30/20 = 25.31
225/35/20 = 26.2
225/40/20 = 27.08
235/30/20 = 25.55
235/35/20 = 26.47
235/40/20 = 27.4
245/30/20 = 25.78
245/35/20 = 26.75
245/40/20 = 27.71
The ones in bold are the closest to factory specs. You can do the same equation above for 18 and 19" rims
Some specs on 19s
19x8:
225/40/19 = 26.1"
235/40/19 = 26.4"
19x8.5:
235/40/19 = 26.4"
And some on 18s
18x8 on 235/45/18 will get you to EXACT factory specs (26.3")
but 225/45/18 (26.0") is damn close enough and tires are a lot cheaper.
This info is for the 08 Altima Coupe and is a work in progress... Chime in with your fitment/offset/drop
ALL Stock Infiniti G wheels will fit.
Ovrbst had NO RUBS with a staggered 19x9x5 fronts and 19x10.5 rear setup (no drop, that would cause issues)
I will be "sweeping up" the thread to make it very easy to understand.
LBC Overlays are HERE! INSTOCK & $32 DELIVERED!
20" ADR Propulsions-SurmanM Custom Dash Cluster -Racingline Front Strut Tower Bar-SBD Grounding Kit-Stillen Lightweight Pulley-Stillen RSB-Xentec Heads n Fogs- Chrome Signals -Fiberglass Eyelids - Eibach Pro-Kit- Fujita WAI - Nismo CatBack - 15/5% tint - Red LED Interior
LongBeachCoupe
Car: 08 Altima Coupe
Re: WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub? (LongBeachCoupe)
Postby mcheddadi » Sun Jun 22, 2008 5:25 pm
here's the calculator I use:
http://www.powerdog.com/tiresize.cgi
here's how it works
you copy paste this (if you are a 3.5SE):
215/55/17
as the first line, you hit "ENTER" on your keyboard to go to the line below, and then you type the tire size you want to check .
eg:
245/40/19
it will tell you all you need to know
a good guideline is to try to stay plus (+) or minus (-) 3% from factory specs
Peoples have been able to run anything up to 9.5 inch wide rims with an offset from +45 to +25 without rubbing on the 3.5SE's firm suspension.
for the tire size, just check the calculator to see that your "Diameter" isn't more than one inch taller than stock (again if you have 3.5SEs) and it will not rub.
Hope that helps
Modified by mcheddadi at 12:28 AM 6/23/2008
mcheddadi
Car: Porsche Cayman S
Re: WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub? (mcheddadi)
Postby adidas2go » Sun Jun 22, 2008 6:21 pm
Noice find Mehdi! Works very well
PHILADELPHIA EAGLES
BOSTON RED SOX
VIRGINIA TECH HOKIES
DETROIT RED WINGS
adidas2go
Car: 08 Frontier SE 6SPD Crew Cab 08 Honda cbr600rr
Postby maxentropy » Tue Jun 24, 2008 11:14 am
For those looking at 19"s--
The stock radius of the 3.5 is 215/55/17s which equals a radius of 334.01 mm. (like LBC mentioned in inches)
New Tire Size / Radius in mm / mm difference in height off the ground from stock
235/35R19 / 323.34 mm / -10.67 mm difference / -3.2%
235/40R19 / 335.28 mm / +1.27 mm difference / +0.3%
245/35R19 / 326.89 mm / -7.12 mm difference / -2.1%
245/40R19 / 339.09 mm / +5.08 mm difference / +1.5%
Like mcheddadi mentioned, you dont want anything + or - 3% over factory specs. This is due not only to fitment issues, but also the effectiveness of your factory brakes.
My question to the experts here is the following:
I am getting 19x8 5x114.3 wheels. I have the Eibach drop.
If I buy 245/40/19, I will gain +5.08 mm of height off the pavement correct?
Is this a good size that you all would recommend? Seems the most logical as it raises my car a few mm, is 1.5% close to stock size and fills my wheel wells a bit more.
The stock 3.5 tires have a +45 offset. That should not affect my new tires correct? My new ones are the Konig ET30, so that is the +30 offset? Would the change in offset affect my handling or would I need anything special for the wheels?
maxentropy
Car: '08 Altima Coupe 3.5SE
Re: WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub? (maxentropy)
Postby mcheddadi » Tue Jun 24, 2008 4:35 pm
you won't rub, don't worry. LBC has less firm suspentions and 20s with a worst offset and he doesn't rub after the drop.
I have 245/40/19 on +40 with hubcentric spacers and I don't rub with the drop
mcheddadi
Postby gucio69 » Wed Jun 25, 2008 6:51 am
http://www.discounttiredirect....h.jsp
this calculator does the computation to one more decimal point and also will show how far off your speed readings will be at different speeds.
I like how mcheddadis one shows how far off your odometer will be.
Maxxim Wonder 18x8.5 & Kumho Ecsta SPT 225/45<>Xentec Slim HID 5000K<>Eibach springs
gucio69
Car: 2008 Nissan Altima Coupe 2.5S 6MT
Postby maxentropy » Wed Jun 25, 2008 8:49 am
So a 3.5 Coupe with new 19x8 5x114.3 wheels (offset of 30), 245/40/19 tires, and the Eibach drop won't have any issues? Good deal.
My last question before I buy my tires is will I need any spacers or new bolts to attach my new wheels or can I use the bolts that came with my 3.5 coupe? (I also bought a set of the special bolts (4 total, 1 per wheel) so noone steals my wheels).
maxentropy
Postby mcheddadi » Wed Jun 25, 2008 11:34 am
get hubcentric spacers if you can
mcheddadi
Postby maxentropy » Thu Jun 26, 2008 7:53 am
mcheddadi wrote:get hubcentric spacers if you can
Why's that? And can you explain what they are and do? Thanks.
maxentropy
Postby Loop » Thu Jun 26, 2008 10:13 pm
No reason to get one unless he wants push out wheel even farther from the hub. Which in this case is not a good idea as hes already aggressive.
You don't need it. They are spacers with a built in hub support. The more important one is getting hubcentric rings if the inner hub bore of your wheel doesn't match to OEM spec, which is 66.1 mm. In your case, the Konig wheels hub bore size is 73mm, which means you will need hubcentric rings. Whoever you bought the wheels from should of supplied you with them.
Tein SS | Stillen | Rotora BBK | Forgestar | Kumho MX
Injen | Borla | Sun Auto | Rays | Ichiba | Kics Project
Loop
Car: 08 Altima Coupe SE
Postby Loop » Thu Jun 26, 2008 10:21 pm
maxentropy wrote:So a 3.5 Coupe with new 19x8 5x114.3 wheels (offset of 30), 245/40/19 tires, and the Eibach drop won't have any issues? Good deal.
Your pushing the limit, but your wheels will be flushed.
No you don't need any new spacers. I am assuming your talking about lugnuts when your saying bolts. The stock 3.5 lugnuts should work with your new wheels.
Loop
Re: WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub? (Loop)
Postby maxentropy » Fri Jun 27, 2008 5:27 am
Loop wrote:I am assuming your talking about lugnuts when your saying bolts.
Yep that'd be it. Forgive my "noobness".
Cheers for the info Loop!
Does a purchase of new wheels usually include the hubcentric rings? If not, where do you recommend to pick them up from and how much should I be looking to spend boss?
maxentropy
Postby mcheddadi » Fri Jun 27, 2008 8:34 am
I meant, hubcentric rings not spacer...doh!
mcheddadi
Postby packerjd04 » Sat Jun 28, 2008 1:32 pm
Most of what you guys are talking about is on the 3.5, but i imagine its the same for the 2.5? Correct me if i'm wrong please. Also would 245/35/19s have any problem on a 2.5?
packerjd04
Car: 2008 Altima Coupe 2.5S
Postby Midian » Sat Jun 28, 2008 9:49 pm
Hey mcheddadi what is the lowest offset i can go with having the eibach springs installed on my 3.5 Coupe im thinking about getting new wheels.
2008 Nissan altima coupe 3.5 Dark Slate
Xentex 6000k, M35 wheels 19X8.5 245/40/19 bridgestone potenzas
Midian
Car: 2008 Nissan Altima Coupe 3.5se
Re: WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub? (Midian)
Postby mcheddadi » Sun Jun 29, 2008 5:49 am
I've seen 245/40/19 with +38 having no probs and 245/35/20 with +35 also not rubbing with a drop
mcheddadi
Postby Midian » Fri Jul 04, 2008 1:03 pm
Hey Mehdi do you think i can fit 19X10 or 18X9.5 offset +37 on both or do you think i will have problems? I found the wheels that i really want They have a deep dish look That i LOVE!
Thanks
Midian
Postby mcheddadi » Fri Jul 04, 2008 1:22 pm
with 10inch width you'd be pushing new boundaries lol.
I don't know for sure, it depends on the tire size and the width of the inner fender well. I know some did 9.5 without a drop. but i'm not so sure about 10 with a drop
mcheddadi
Postby Midian » Fri Jul 04, 2008 1:38 pm
Aww damn What about 19X9 with a +42 offset and 245/40/19 tires You think this will work with a drop
Midian
Postby mcheddadi » Fri Jul 04, 2008 3:04 pm
yep it will!
mcheddadi
Postby KLRSAN » Tue Jul 08, 2008 9:23 am
What is the smallest offset i can have in the rear in an 18in? Im trying to get a good size lip.
KLRSAN
Car: 2008 ALTIMA COUPE
Postby shain_tsung » Tue Jul 08, 2008 1:37 pm
whats up guys! im new to this forum and was hoping you guys could help me out.
I don't know much about upgrading wheels. I have an 08 Altima coupe 2.5 and everything i see on upgrading them is for the 3.5 is there any difference in the wheel sizes? before I buy new rims I wanted to know what i'm doing first
it has factory hubs on it which are terrible the sizes are p215/60 60r/16
i am looking at these
they are 18 inch rims will they fit my car? and what tire size would i need to get?
http://www.discountedwheelware...=True
or since i am running on 16s now shuld i stay around 16-17 instead of going for 18s? anyhelp is greatly appreciated thanks in advance
shain_tsung
Car: 08 altima coupe 2.5 s
Re: WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub? (shain_tsung)
Postby LongBeachCoupe » Tue Jul 08, 2008 7:13 pm
welcome man... i dont know what you are talking about hub sizes... im a 2.5! Dig my wheels? 5x114.3
LongBeachCoupe
Postby maxentropy » Wed Jul 09, 2008 9:53 am
Premium 3.5SE AC Wheels will fit on a 2.5 right? I figure since the cars are the same dimensions mostly and the bolt patterns are the same...
maxentropy
Postby LongBeachCoupe » Wed Jul 09, 2008 9:57 am
i assume this is a joke....
but if not, yes they fit... as do 90% of 5x114.3 wheels including the G wheels, Z wheels and other factory rims.
LongBeachCoupe
Postby maxentropy » Wed Jul 09, 2008 10:38 am
LongBeachCoupe wrote:i assume this is a joke....
Nope, just clarifying. I'm still new to this tire stuff. Too many things to consider when purchasing new wheels-- especially tires anyway...
Thanks for all the help folks!
maxentropy
Postby shain_tsung » Wed Jul 09, 2008 1:49 pm
I meant hubcap sizes. My Altima is the base price 08 coupe. It came with hubcaps with those ugly plastic wanna be rim placements over them lol I think ima get those I posted earlier, just waiting for finance to get back to me.
Thanks for explaining the size thing to me tho, I had no clue what any of it meant. New to cars I guess you could say.
shain_tsung
Postby Colton92 » Wed Jul 09, 2008 4:42 pm
The 08 maxima 18"s will fit right?
Mods: Injen WAI, Debadged, 18" MB Weapon Wheels, Falken Ziex ZE-912 225/45/18 Tires, Pioneer AVIC-F700BT InDash Navigation, 10" Alpine Type-R 4ohms Subwoofer, Alpine MRP-M500 Mono Amplifier, Chrome Turn Signal Bulbs, Blue Reverse Bulbs
Colton92
Car: 2008 Nissan Altima Coupe 2.5S - WinterFrost
Re: WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub? (Colton92)
Postby mcheddadi » Wed Jul 09, 2008 4:45 pm
Colton92 wrote:The 08 maxima 18"s will fit right?
OK, ill make it REAL SIMPLE. YOU CAN FIT ANYTHING UP TO 24 INCHES.
k?
the only factor you need to worry about is OFFSET, RIM WIDTH and TIRE SIZE
mcheddadi
Postby marlin29311 » Thu Jul 17, 2008 9:55 am
I have a quick question about offset...
Tire Rack shows that basically every wheel they offer will fit on the a/c, all with varying offsets. I wanted to get a 18" wheel with either an 8 or 8.5" width, but i don't really know what offset i should be getting with that - and they way everything on the 'net reads about offsets, it sounds like if you get the wrong one you will screw up the way the tire tread wears, the car drives, etc....
what kind of offset should you get for an 8" or 8.5" wheel?
marlin29311
Car: 2008 Nissan Altima Coupe 3.5 CVT w/ Prem, Tech, VDC
Re: WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub? (marlin29311)
Postby mcheddadi » Thu Jul 17, 2008 11:26 am
I've seen up to +38 , mine is +40 and stock is +45
mcheddadi
Postby maxentropy » Tue Jul 22, 2008 8:12 am
So my final setup will be Konig Troubles 19x8 5x114.3 with an offset of 30 and Kuhmo Ecsta Lx Platinum All Seasons in 245/40R19.
Tire Size:
Wheel offset: Clearance from stut housing to the inside of the wheel will be 9mm more but the outside edge of the wheel will extend an extra 21mm...
Does anyone have a setup like this? Is a +30 offset with 19x8s going to have any issues (rubbing/performance/etc)?
I will be calling Stillen today to ask for my hubcentric rings. I called Konig and they told me to definitely get them if I want a smoother ride at high speeds. OEM spec is 66.1 mm and the Konig wheels hub bore size is 73mm, so like Loop stated, I will need a hubcentric ring. Konig assured me they do not make, nor ship hubcentric rings with their wheels- it is the sellers part to do so (tirerack.com, Stillen, etc). So, I'm off to call Stillen. They only cost like $10.
Any info or insight on my setup would be much appreciated fellas!
Modified by maxentropy at 2:25 PM 7/22/2008
maxentropy
Postby mcheddadi » Tue Jul 22, 2008 9:19 am
It's going to rock! make sure to get the correct lug size and hubrings!
and don't forget to get pics
mcheddadi
Postby maxentropy » Tue Jul 22, 2008 9:57 am
mcheddadi wrote:It's going to rock! make sure to get the correct lug size and hubrings!
Will do-- my OEM lugs should be good if my new wheels are 5x114.3 right?
maxentropy
Postby mcheddadi » Tue Jul 22, 2008 3:05 pm
depends if the lug base is flat or if its like a bullet on your new rim. I had to change my lugs.
mcheddadi
Postby beeristasty » Tue Jul 22, 2008 4:28 pm
I'd recommend getting some locking tuner lugs. Won't prevent theft, but will help deter it. Protect the investment!
beeristasty
Car: 07 Altima 3.5 SE
Postby felv8 » Wed Jul 23, 2008 11:29 am
Is 19x8.5 with a 35mm offset on an eibach drop too much, in terms of rubbing/fitment? based the original post, I would go with either P235/40/19 or P245/40/19 (which tire would provide most comfort?)
thanks!!
felv8
Car: Altima Coupe 3.5se Code Red Metallic
Re: WHAT WHEELS WILL FIT MY ALTIMA?! Will it fit? Rub? (beeristasty)
Postby maxentropy » Wed Jul 23, 2008 12:33 pm
beeristasty wrote:I'd recommend getting some locking tuner lugs. Won't prevent theft, but will help deter it. Protect the investment!
Hell yeah. I have one on each wheel-- will transfer from my current stockers to the new wheels as soon as my tires come! (If the lugs will fit anyway) -- Everything is a learning experience!
Just ordered Hubcentric Rings (Inside Diameter 66.1mm Outside Diameter 73mm) instead of screwing around with Stillen-- I'm sure they don't have the rings due to the fact this was a special deal. Anyway here is where I got my hubcentric rings:
http://www.sfxperformance.com/parts/TOPC736610.htm
Cost me $15 plus shipping - total came to $22.
maxentropy
Postby ESP » Wed Jul 23, 2008 7:01 pm
Max,
Aren't you getting the Troubles? I didn't think hubcentric rings were needed with them (or the Coupe)... Perhaps I'm wrong...I've been drinky-drinky tonight so I could be off my rocker...
ESP
Car: 2008 SexyBlack A/C
Next
Return to Altima Suspension, Brakes, Rims and Tires
