Carl H wrote:remember kids pressure != flow.larger id pipe will flow more oil but at less pressure, converse holds true.
The holes going in and out of the filter housing are 16mm diameter. If you reduce the diameter at this point, you're creating a bottleneck before the oil is even pushed through to the main oil gallery.
I get what you're saying about pressure vs flow, but riddle me this... if the bottleneck is reducing flow, then even if you are able to get it up to the same pressure, wouldn't the reduced flow prevent it maintaining peak pressure under high load?
I'm by no means a hydraulics expert... but I imagine keeping the same internal diameters throughout the system is a step in the right direction for avoiding oiling problems.
My problem with -12 fittings is that oil coolers that have -12 inlet & outlets are massive and bloody expensive. Of course, these are usually outright race application stuff for V8 touring cars and the like. You guys in the states probably have cheaper access to gear like that... here in NZ I'd be looking at around a thousand bucks JUST for the cooler!!
My easy solution was to split the lines and run two -
10 coolers in parallel, but that's just complicating matters and adding additional stuff to potentially go wrong, etc.
Either way, keen to see the outcome on this Make one for the VH41DE too
