Could be your fuel pump. You can test it several ways as mentioned above. Carefully take the gas hose off the intake and test it. Depressurize the fuel system first. Unplug fuel pump/fuse and start car until pressure goes down! Use a container that will hold gas preferably a gas can. Put the hose in the gas can. You may need someone to help you turn the key in on position only. Do not try to start the car. Is the gas coming out hardcore or is it trickling?
I've gone thru 4 Walbros since 2003. (Showing my Age
) At one time they had a bad batch of them around 2003-2006?
Everything is wired up right, I made sure 1/4 tank was in the gas tank at all times AFTER the 1st one.
They have a newer one that has a bigger Strainer Sock. You might have to modify it a little, the rubber on the canister doesn't line up perfect. I slowly shaved some of it off until it fit snug.
Be sure to get that one and NOT the one with the small sock. Those are the ones people have been having problems with. Or get a 300TT/Supra one much more efficient and they seem to last a lot longer. Hope this helps.
