J2fast »
https://forums.nicoclub.com/j2fast-u142985.html
Fri Oct 05, 2012 7:25 am
Sorry Guys i been away for a while trying to sort out some issues i was having with car. so where do i begin. well first i would like to say that although i was kinda happy with the 775hp, it wasnt running right, and i didnt know it until i actually ran my car. but before that i was having fuel pump issues. so my first set of pump which were the walbro 400 lph twin, burned up (due to lack of gas in the tank, my gas hand was not working) so then i replaced them and could not get the car to hit and boost over 15psi with out leaning out. so that took a few months of thinking everything but the pumps then walbro came out with the e85 version of that pump so i bought those and what do you know, problem fixed. so i had to retune the on high boost again, an started noticing that my catch can was always full of oil when i was finish running the car, but didnt really put much thought into at the time. then i came across my first race, which was a fully built gtr r35 pushing 700whp, and after i gave a nice whooping i look back in my mirror not just see how far he was but notice smoke was coming from my car. so i pulled over and notice that i had almost no oil in the car and some of it was on the side of my car and on the outside of the motor where it should not be. so now im at lost in thinking what the he** is wrong. i go and buy better catch can, no fix, i buy this nice piece of personally made crafted oil caps that seat on top of the cam caps to prevent oil from splashing up (i forgot what the actual name is right now), still no oil in the engine. so then i do buy of research and do some heavy emailing to new Zealand and australia and to find out that it is 98% going to be my oil restrictors. on the rb30 and rb25 block they are both open with 2.0 mm restrictors. on the rb26 block one is closed and the other is 2.0mm. so tomei makes one that is 1.5 and you can get that here in the states but the problem is i need one that closes the rear than another one that is smaller. it is also recommended that for the power im making and poss more, i should go with a smaller than 1.5 so i got the 1.3 and closed one which took 3 weeks and $75 ago. so lastnight i had to pull the head off an install these which once the head is off takes all of 5 seconds. but i notice some things were not looking good. like i was having the head either lifted very slightly or is not sealed very good but lucky we found out why, the rb30 block uses rb25 size head bolts but i have an rb26 head and the rb26 bolts are bigger in diameters and small in lenght. so i put another spacer to make sure it doesnt go to the last thread anymore. so i will be keeping you guys on up to date on how this should be working for me. but for those that trying to make well over 700hp and/or boost you may want to invest in some oil restrictors.
btw my turbo is spooling ALOT spooner, didnt get to look at the full detail when i was trying it out before the pipe popped off.
