they werent numbered right and two are not numbered so when you tighten them the motor doesnt hand spin. so i cranked it over a few times with the cam caps loose then tighten them down but then notice that my fuel pressure is out of the world and will not go down so now im getting all new fuel lines from n to the rail with new pumps.Shocker wrote:Looks good man, what do you mean the caps arnt fitting right do you have the ex and in lined up right 1-7? If its causing the motor to be partially bond that's no good.
oh my fuel system is out right now but hopefully we can get the fuel pressure to go down cuz it would not go lower than 90psi and shooting gas out the tale pipe. but ill keep it running when ever i get finish with the fuel for about 30 min. that should be long enough you think?Carl H wrote:try to limit starting unless you're gonna break it in...worst thing you can do is start and stop a motor and not let the rings seat.
im trying to fix my power fc boost controller but if not then ill buy a manual one then try to hit the dyno next weekend.RRRRB wrote:when are you going to put it on a dyno and get it tuned?
yea i know i just bought that pos like last year.... i think i have a manual one somewhere ill play with that n see if that helps out get it to about 22psi or where ever it takes to hit the 700whp mark...Carl H wrote:or buy a proper ebc...pfc based one kinda sucks.
74260zt wrote:Sounds nice at the rear. Was your starter stuck on?
It took about 2months to do the fire wall, and about 2 1/2 months to the rest. I get looks everywhere I go so if u like attention deff do it.twinspoool wrote:sweet build, how long it take you to finish the rhd conversion? I am almost done with my rhd conversion but I have rb25 and moved the motor back about 8", waiting to get an intake manifold to see what clearance I will have around the clutch master cylinder area. I can't wait to see some rolling footage of your car!
so i went to dyno yesterday and im pretty happy with results i made 775 whp 636ft/tq on 27 psi, (im not done yet tho) here is a lil video of the runtwinspoool wrote:damn! that sounds crazy! let see vido ftw!
I think it's the radiator cap. Cuz it's only under higher boost....Yellow4g63 wrote:Did u hurt the headgasket? if ur pushing coolant out might mean your super heating it.
Is that a good wow r bad wowmeet07 wrote:Wow!
Shocker wrote:Nice numbers , what fuel are you using. Post up your graph vs. Rpm
