Front suspension work done!
For now..
So the problem with overlowering a car is that the roll center gets messed up, among other things.
I wanted to get rid of some body roll so I decided to work on that.
The lower control arm is a Godspeed arm, lots of guys over in the NissanRoadRacing forum did this mod and had no problems, but the bearings are absolutely horrible on the Godspeeds, so I replaced them with quality QA1 rod ends.
The outer bearing is still Godspeed though, and it's pretty stiff, hopefully it'll work itself smooth as I drive it.
Also, despite telling Godspeed, they told me the arms are definetely universal for S13 or S14, I (among other NRR members) told Godspeed that the taper inside the S14 and S13 knuckles are different and that they won't be universal.
Proof:
Godspeed's "S13/S14" rod with my S14 knuckle.
That's almost a centimeter of the rod sticking out of my knuckle.
Ken from Godspeed, if you're listening, please make cleaner welds and make FLCA sets that have properly tapered rods for the S14!
Thanks!
My dad had to grind the heck out of the rod to give it the proper taper so it fits inside the S14 knuckle.
Like so:
Now, the stock Godspeed lower control arm won't properly adjust your roll center, to do this you need to space the arm down lower.
This is what we're trying to achieve:
Spacing the arm down with some washers so our arm sits parallel to the ground.
We had to cut the lower nut down so it lines up properly with the cotter pin hole after it gets spaced down with the washer.
After a bit of struggling, we installed the arms!
Another shot of the arms:
Final product:
It's not as parallel to the ground as I'd like.
I would've liked to put in 1 more washer to space it down a tiny bit more, but I can't cut the bottom nut any more.
Later I'll do what Def's write-up says and use a bolt instead of that tapered Godspeed bolt.
Def's write-up:
http://www.nissanroadracing.com/showthread.php?t=1407
AceInHole's write-up that inspired me to cut the nut instead of using a bolt:
http://www.nissanroadracing.com/showthread.php?t=1990
My car has less body roll now, I'm pretty happy I did this.
I'm gonna get an alignment tomorrow!
