Part Numbers / Crossover Parts between USDM and JDM CA18's
NeedCAforS13
Car: CA swapped S13 coupe
If you are looking for parts, tell the autoparts store that you have an 88' Nissan Pulsar NX SE. It will be the correct part 99% of the time!
Please note: Nissan NA is no longer making many of the gaskets,pumps, ect, for the CA18DE that was in the Pulsar. They should all still be able to be purchased from a parts store though (Advance Auto, O'Reilly,ect)
Clevite Bearings
Clevite Main Bearings - MS-1565P
Clevite Rod Bearings - CB-1287P
ARP part numbers
The Intake manifold and Rod Bolts are available through Erics Performance Parts on eBay. He doesn't list part numbers and I can't find any. I believe he has found hardware for different applications and is just re-boxing them for the CA.
202-6001 Rod Bolts - They're listed for an L20 engine, but they fit just fine.
400-8012 Exhaust Studs
165-5402 Main Stud Kit
151-2801 Flywheel Bolts - Same as a pinto. 6 in a package (The CA needs 8, so you'll have to buy 2 packages and you'll have 4 extra)
202-4702 - UK CA18DET Head Stud Kit
202-4302 - US/JDM CA18DE(T) Head Stud Kit
Head Studs
-Tightening Procedure;Torque in THREE stages: 30 ft-lbs, then 55 ft-lbs, then 80 ft-lbs (using their moly grease).loosen and re-torque THREE MORE times!Heat cycle the studs (start and run to NOT).Let the engine cool down, thoroughly check torque on studs, and tighten as necessary
-NOTE! The head stud above the water pump will sit higher than the other studs. The hole isn't as deep due to clearance issues with the pump housing in the block. How much seems to vary from motor to motor. Because of this you need to add an extra washer to this stud so the nut will not bottom out on the stud. Simpy re-use one of the stock washers.
Part numbers for belts
Alternator belt "4pk855"
- 5040340 "Advance Auto Parts"
- 4040340 "Goodyear Gatorback"
- 340k4 "Autozone"
- 040340 "NAPA"
AC belt "4pk845"
- 5040333 "Advance Auto Parts" 4 rib / 5030333 "3 rib"
- 4040333 "Goodyear Gatorback" 4 rib / 4030333 "3 rib"
- 333k4 "Autozone" 4 rib / 333k3 "3 rib"
- 0403303 "NAPA" 4 rib / 030333 "3 rib"
*the 3 rib parts numbers are for those of you who are running the AC with a staggered belt setup.
Power Steering belt "4pk840 HICAS" / "3pk840 Non-HICAS"
- 5040330 "Advance Auto Parts" 4 rib / 5030330 "3 rib"
- 4040330 "Goodyear Gatorback" 4rib / 4030330 "3 rib"
- 330k4 "Autozone" 4 rib / 330k3 "3 rib"
- 040330 "NAPA" 4 rib / 030330 "3 rib"
*4 rib belts for Hicas and 3 rib belts for Non-Hicas
NISMO motor mounts-11210-RS520 & 11220-RS520(IDK which is left or right, but whichever is shorter goes on the exhaust side of the motor.)11320-RS541 (trans mount)
Oxygen Sensor CA18ET 200sx Bosch 13276 $47.99
Spark Plugs CA18ET 200sx NGK PFR6A-11Other Spark Plug Options:PFR6/BCPR6's for standard (gap of 1.1mm) PFR7/BCPR7's for lightly modded (gap of 0.8-10mm - see what works for you) BCR8's for high boost applications. (gap 0.6-0.8 dependant on boost level) 22401-58S16 (PFR6A11, CA18) Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm)
PCV Valve CA18DE Pulsar NX Bosch PCV142 $2.99
Thermostat CA18DE Pulsar NX 491-180 $4.99Thermostat 21200-V0201 (CA18 all) 82.0 C Thermostat 21200-V0206 (CA18 all) 88.0 C
Thermo Gasket CA18DE Pulsar NX Felpro 35228 $0.89
Water Pump** CA18ET ???Part Number anyone???
Upper Rad. Hose KA24DE 240SX L-564 $7.99
Lower Rad. Hose KA24DE 240SX M-563 $7.39
Oil Filter CA18DE Pulsar NX Bosch 3400 $5.49
Oil filter 15208-H8911 Ryco Z386 or Ryco Z145A
Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate pieces
Intake manifold gasket 14035-D5710 (CA18 all) Injector rail to cylinder head
Intake manifold gasket 14035-D5711 (CA18 all) Injector rail to intake runner
Turbo inlet flange gasket 14415-75F10 (200SX) or 14415-17M00 (S13 all) The Aust 200SX one fits.
Turbo outlet flange gasket 14445-26E00 (S13 all)
Engine front oil seal 13042-42L00 (CA18 all)
Engine rear oil seal 12279-18V00 (CA18 all)
Oil pan seal front 11121-01F10 (CA18 all)
Oil pan seal rear 11121-01F15 (CA18 all)
Head gasket 11044-51E00 (CA18 all) Engine gasket kit 10101-51E25 (CA18D) Engine rebuild gasket kits Engine gasket kit 10101-56E25 (CA18DET)
Valve grind gasket kit 11042-51E25 (CA18 all)
The following have proved problematic.Water pump 21010-V5528 (CA18) until 8/90 Water pump 21010-V5529 (CA18) from 8/90"]Use a CA18ET waterpump from an S12
Radiator cap 21430-01F01
IDK if these are good #'s in the US;
Radiator hose - upper 21501-35F10 (CA18 all) Radiator hose - lower 21503-35F00 (CA18 all)
Radius rods (Tension rods) 54468-35F20 (S13 all) includes bush Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ).
Fuel filter 16400-F5100 (CA18 and SR20) RYCO Z202 or Z201
Crank angle sensor 23731-85M10 (CA18 all)
Coolant temp sensor 25080-89903 (S13 all)
Cam shaft timing belt 13028-51E25
Cam belt idler bearing 30BD219DWAX
Cam belt tenioner bearing. 35BD219DWAX
S13 Main Handbook (English) Nissan Publication SM9E-OS13G0 $230 tax ex.
RS13 Service Manual, Main Issue (Japanese) Nissan A008009 $143 Tax Ex
crank sprocket - 13021-D4200 - $29.26
woodruff key - 00926-51900 - $1.02
crankshaft plate (behind sprocket) - 13022-42L00 - $1.78
Turbo Manifold gaskets -> head: 14036-D4201 (x2)14036-D4202 (x2)
Camshaft SealsBCA-National (Federal-Mogul) 224052
KA24 and CA18 use the same radiators (Unlike the SR) with both ports on the USDM passenger side
Knock Sensor - Part number OEM # 22060-56S10
Starter-Can use direct drive starter from an S12 CA18ET
Feel free to add any part numbers or prices, or to correct any of the above prices/numbers. This list was created awhile ago, and some stuff might not still be valid.
Sean
Dattebayo
NeedCAforS13 wrote:Water Pump** CA18ET ???Part Number anyone???
Bosch Part Number #96060
Nowhere
Car: Suzuki x-90, samurai
The current part number on the air filter is 16546-0z000
biosehnsucht
Belt info here.
Modified by biosehnsucht at 9:15 PM 2/15/2008
Dattebayo
A bit late, but I ordered a oil pump Nissan of North America via Midway, and the part number is:
15010-35F01
From a 1988 Pulsar CA18DE.If anyone cares, Cheers!
tattman77
Car: 92 240sx coupe w/ca18det swap top mount 20G and s13 silvia front end
ignition coils
http://www.partsamerica.com/Pr...set=A
These are the prices from advance auto parts website
Niehoff # WA2100 $70.00Borg Warner # E710 $94.00
this one is not available online (in store only) GP Sorenson # 24-5259 $101.00
I just installed the gp sorenson coil. It is a nissan reman part, so it is the exact same housing as factory. It did not come with the boot or the part that touches the plug (looks like a big flint for a lighter). Save those parts from yours.Work great so far
Modified by tattman77 at 1:48 PM 1/25/2007
mbmbmb23
FYI, according to http://www.everythingnissan.com says part number 12279-18V00(CA18de rear main seal) is replaced by part number 12279-AD205
(Front main seal) part 13042-42L00 replaced with; 13042-16V00
-m
mbmbmb23
Nissan T25/28 turbo compressor outlet flange (3 hole)
14465-40P03
silvia_ca18det
Car: 350whp ca18det drift silvia
ca18det valve seals
13207-D4201
these are the same on the CA18DE and the GA16 aswell
float_6969
ARP Main Stud Info (CA w/main bearing cap)zerothread/256288
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
NeedCAforS13 wrote:ARP FLYWHEEL BOLTS-Same as a pinto. 6 in a package. 151-2801
Will these work on the CA as well? I notice this has SR as well as CA parts listed. I need flywheel bolts anyway, and may as well get some good ones!!
float_6969
Yea, they work just fine for the CA. You'll have to get 2 packs though as the CA18DE(T) is an 8 bolt crank.
mazdaman
Car: 90 S13 CA hatch
Coils... Niehoff (from Advance Auto Parts) Part # WA2100 $68.99
johngriff
Car: 240sx
IMC has the rod bearings, but no main bearings, and my dealer has a set of Mains, but fast is saying "US. ONLY". Any one want to chime in on some mains for me?
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
anyone got an ARP # for ROD BOLTS?
Woods Crasher
Vetal wrote:http://www.everythingnissan.com just told me that Nissan does not supply anymore:
water pump((
I just ordered a S12 ca18et water pump...it's superceeded to part number 21010-50VY5. confirmed 3 in stock in my NY PDC. 11 in greenvile
RS12Turbo
Just get one for a '84-'86 s12 ca18et from any local auto parts store
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Can anybody confirm or deny that the power steering pump is the same for S13 CA18DET as it is for 88 Nissan Pulsar NX SE CA18DET?? I need to get one (motor is quite nearly finished) and will probably look at ordering from Advance or Autozone or something similar.
MeanGreenS13
http://www.greenline.jp/catalo...ke=FI
performance CA parts can be found here aswell if no one has found it. i foudn this al ong time when building my old RB20
mbmbmb23
Here is a link to Garrett turbo part numbers, the site is in Spain, but if you click on the correct turbo (has CA, SR/GTiR, RB, VG applications) you can get Garrett part numbers for each individual peice of the turbo.
http://www.turbomaster.info/en...issan
biosehnsucht
Nismo mounts L/R part #'s (above it isn't sure which is which) here
11210-RS520 is RH11220-RS520 is LH
jdznutz
Car: 1989 240sx Hatch
Engine gasket kit just came in today from Nissan Motorsports
A0101-56E2E
Will be getting water pump and oil pump with actual part numbers as well in the near future.
jdznutz
mbmbmb23 wrote:FYI, according to http://www.everythingnissan.com says part number 12279-18V00(CA18de rear main seal) is replaced by part number 12279-AD205
-m
CA18DET front main = VG30DE(TT) Cam SealCA18DET Rear Main = VG30DE(TT) Rear Main
same part numbers
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
anybody know if a CA18DE alternator will work on the CA18DET?
ard
Car: 1989 200sx ca18det
MeanGreenS13 wrote:anyone got an ARP # for ROD BOLTS?
did you find the part # ?can't find anywhere
yeatheshortbus
Car: s13 ca18det
anyone know anything (part number) about the maf or if the usdm ca18de will work for me
sjbsuperman1425
CA18DET
ok, question, where can i get the timing belt tensioner and idlers?
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
should be the same as the CA18DE
s13_ono
Hey, Ive searched, but no luck. Is the starter the same from the pulsar as well?
KEMP
Car: 1990 240sx CA18DET
i do not believe so, but i think the KA24 starter may be the same...i might be wrong..
