Part Numbers / Crossover Parts between USDM and JDM CA18's
float_6969
S12 starter. CA20E or CA18ET.
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
Dorman Cup Type Expansion Plugs / Freeze plugs
Set of nine for the block
Part No. 555-100
Four on each side of block plus one inside the bell housing
EXPANSION PLUG; 30.25mm Steel Cup
For the freeze plugs on the head
Part No. 555-106
EXPANSION PLUG; 12.1mm Steel Cup
Reference: US 1988 Nissan/Datsun 200SX 2.0L 1974CC L4 FI VIN: CA20E
Purchased mine at Advance Auto Parts
http://shop.advanceautoparts.c...ug___
Nunook
can some one fix the arp part number for exhaust manifold studs. I just spent 100 bucks and they dont fit. the arp 400-8012 are too small.
trevr
Couldn't find Oxygen Sensor for CA18ET 200sx Bosch 13276, so instead used Bosch 13091 for 1992 300zx TT VG30DETT Exact Fit; 3 Wire; Heated Sensor.
Although terminals snap together, sensor wire is in a conflicting position. You will need to swap the sensor wire (blue) from the outside to the center position of the terminal on the engine harness side.
btm88
Car: 1993 S13 Convertible
Starter motor Brand: Beck/Arnley Vehicle found in: 1989 Nissan Pulsar NX SE Motor: CA18DE/TPart Number: 1870376Number of teeth: 10
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
autozone and advance auto:
Felpro Valve Stem Seals -70157
sjbsuperman1425
CA18DET
Autozone or Advance Auto Parts:
Duralast Dayco Timing Belt (151 teeth) - 95137
mbmbmb23
http://nissan4u.com/parts/200sx/el_s13/1991_7/type_1/
^^^ EUDM CA18DET part numbers with nice detailed diagrams
CA18DET crank pulley bolt 12309-D4200
CA18DET crank pulley lock washer for bolt 12308-42L00
mbmbmb23
NeedCAforS13 wrote:If you are looking for parts, tell the autoparts store that you have an 88' Nissan Pulsar NX SE. It will be the correct part 99% of the time!
Please note: Nissan NA is no longer making many of the gaskets,pumps, ect, for the CA18DE that was in the Pulsar. They should all still be able to be purchased from a parts store though (Advance Auto, O'Reilly,ect)
ARP part numbers The Intake manifold and Rod Bolts are available through Erics Performance Parts on eBay. He doesn't list part numbers and I can't find any. I believe he has found hardware for different applications and is just re-boxing them for the CA.
400-8012 Exhaust Studs
165-5402 Main Stud Kit
151-2801 Flywheel Bolts - Same as a pinto. 6 in a package (The CA needs 8, so you'll have to buy 2 packages and you'll have 4 extra)
202-4702 - UK CA18DET Head Stud Kit
202-4302 - US/JDM CA18DE(T) Head Stud Kit
Head Studs
-Tightening Procedure;Torque in THREE stages: 30 ft-lbs, then 55 ft-lbs, then 80 ft-lbs (using their moly grease).loosen and re-torque THREE MORE times!Heat cycle the studs (start and run to NOT).Let the engine cool down, thoroughly check torque on studs, and tighten as necessary
-NOTE! The head stud above the water pump will sit higher than the other studs. The hole isn't as deep due to clearance issues with the pump housing in the block. How much seems to vary from motor to motor. Because of this you need to add an extra washer to this stud so the nut will not bottom out on the stud. Simpy re-use one of the stock washers.
Part numbers for belts thanks to anumeric!zerothread/284332
Alternator belt "4pk855" - 5040340 "Advance Auto Parts" - 4040340 "Goodyear Gatorback" - 340k4 "Autozone" - 040340 "NAPA"
AC belt "4pk840" - 5040335 "Advance Auto Parts" 4 rib / 5030335 "3 rib" - 4040335 "Goodyear Gatorback" 4 rib / 4030335 "3 rib" - 335k4 "Autozone" 4 rib / 335k3 "3 rib" - 040335 "NAPA" 4 rib / 030335 "3 rib"
*the 3 rib parts numbers are for those of you who are running the AC with a staggered belt setup.
Power Steering belt "4pk845 Hicas" / "3pk845 Non-Hicas" - 5040335 "Advance Auto Parts" 4 rib / 5030335 "3 rib" - 4040335 "Goodyear Gatorback" 4rib / 4030335 "3 rib" - 335k4 "Autozone" 4 rib / 335k3 "3 rib" - 040335 "NAPA" 4 rib / 030335 "3 rib"
*4 rib belts for Hicas and 3 rib belts for Non-Hicas
NISMO motor mounts-11210-RS52011220-RS520(IDK which is left or right, but which ever is shorter goes on the exhaust side of the motor.)11320-RS541 (trans mount)
Oxygen Sensor CA18ET 200sx Bosch 13276 $47.99
Spark Plugs CA18ET 200sx NGK PFR6A-11Other Spark Plug Options:PFR6/BCPR6's for standard (gap of 1.1mm) PFR7/BCPR7's for lightly modded (gap of 0.8-10mm - see what works for you) BCR8's for high boost applications. (gap 0.6-0.8 dependant on boost level) 22401-58S16 (PFR6A11, CA18) Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm)
PCV Valve CA18DE Pulsar NX Bosch PCV142 $2.99
Thermostat CA18DE Pulsar NX 491-180 $4.99Thermostat 21200-V0201 (CA18 all) 82.0 C Thermostat 21200-V0206 (CA18 all) 88.0 C
Thermo Gasket CA18DE Pulsar NX Felpro 35228 $0.89
Water Pump** CA18ET ???Part Number anyone???
Upper Rad. Hose KA24DE 240SX L-564 $7.99
Lower Rad. Hose KA24DE 240SX M-563 $7.39
Oil Filter CA18DE Pulsar NX Bosch 3400 $5.49
Oil filter 15208-H8911 Ryco Z386 or Ryco Z145A
Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate pieces
Intake manifold gasket 14035-D5710 (CA18 all) Injector rail to cylinder head
Intake manifold gasket 14035-D5711 (CA18 all) Injector rail to intake runner
Turbo inlet flange gasket 14415-75F10 (200SX) or 14415-17M00 (S13 all) The Aust 200SX one fits.
Turbo outlet flange gasket 14445-26E00 (S13 all)
Engine front oil seal 13042-42L00 (CA18 all)
Engine rear oil seal 12279-18V00 (CA18 all)
Oil pan seal front 11121-01F10 (CA18 all)
Oil pan seal rear 11121-01F15 (CA18 all)
Head gasket 11044-51E00 (CA18 all) Engine gasket kit 10101-51E25 (CA18D) Engine rebuild gasket kits Engine gasket kit 10101-56E25 (CA18DET)
Valve grind gasket kit 11042-51E25 (CA18 all)
The following have proved problematic.Water pump 21010-V5528 (CA18) until 8/90 Water pump 21010-V5529 (CA18) from 8/90"]Use a CA18ET waterpump from an S12
Radiator cap 21430-01F01
IDK if these are good #'s in the USRadiator hose - upper 21501-35F10 (CA18 all) Radiator hose - lower 21503-35F00 (CA18 all)
Radius rods (Tension rods) 54468-35F20 (S13 all) includes bush Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ).
Fuel filter 16400-F5100 (CA18 and SR20) RYCO Z202 or Z201
Crank angle sensor 23731-85M10 (CA18 all)
Coolant temp sensor 25080-89903 (S13 all)
Cam shaft timing belt 13028-51E25
Cam belt idler bearing 30BD219DWAX
Cam belt tenioner bearing. 35BD219DWAX
S13 Main Handbook (English) Nissan Publication SM9E-OS13G0 $230 tax ex.
RS13 Service Manual, Main Issue (Japanese) Nissan A008009 $143 Tax Ex
crank sprocket - 13021-D4200 - $29.26
woodruff key - 00926-51900 - $1.02
crankshaft plate (behind sprocket) - 13022-42L00 - $1.78
Turbo Manifold gaskets -> head: 14036-D4201 (x2)14036-D4202 (x2)
Camshaft SealsBCA-National (Federal-Mogul) 224052
KA24 and CA18 use the same radiators (Unlike the SR) with both ports on the USDM passenger side
Feel free to add any part numbers or prices, or to correct any of the above prices/numbers. This list was created awhile ago, and some stuff might not still be valid.
Sean
Someone needs to fix this in the sticky. In front of me I have a 4pk840 (5040330) and a 4pk845 (5040333). Above it shows 5040335 for both the 4pk840 AND 4pk845.
Here:http://web2.impactblue.org/content/disp ... search=117
it shows the;
4pk840 is the PS belt (hicas)
4pk845 is the AC compressor
Searching the web the only nissan listed for the 5040335 is 2.4L Altima A/C compressor belt.
float_6969
Ok, I think I got it all fixed. Thanks for the info.
sjbsuperman1425
CA18DET
Well since power steering stuff is hard to come by, and I wanted power steering back, I did some research and found the part numbers for all the parts and everything you should need. Here is what I found. (source is www.nissan4u.com)
Power Steering Bracket (to block) - 11940-35F10
Bracket to block bolt (1) - 08081-0451A
Bracket to block bolt (2) - 08081-0651A
P/S Tensioner Bracket - 11941-35F05 [1986 Nissan 200sx CA18ET]
P/S Tensioner Bolt (2) - 08126-8201G [1991 Nissan 240sx KA24DE]
Tensioner "Eye bolt" - 11942-W4410 [1986 Nissan 200sx CA18ET]
Tensioner "Eye bolt" washer- 08915-5361A [1988 Nissan Pulsar NX CA16DE]
Tensioner "Eybe bolt" nut - 08912-7081A [1990 Nissan Hardbody] **ONLY COME IN A PACK OF 10 NUTS**
Also, everyone knows the KA24DE pump works on the CA18DET.
sjbsuperman1425
CA18DET
Injector Dropping Resistor - MD172146
It's a Mitsubishi Part number but crosses over to the Plymouth Laser and Eagle Talon as well.
Paogasm
Car: 1987 Nissan Pulsar Nx Se 1.6
1989 Nissan Pao 1.2
What about an intake manifold gasket (to head) for a first generation ca18det is that possible to get? 4 of those ports are oblong.
float_6969
Good luck. That's an OLD engine, and they didn't use very many of them. We never got them in the US and I don't think Canada did either. That's going to be something that comes from Japan, or MAYBE Europe. I don't know for sure if even Europe got that first generation CA18DET.
