BigTDogg (MA) wrote:300zxttzman, were your compression numbers taken on a hot, warm or cold engine?
Hard to say i didnt actually do it my self the shop did it (not a shade tree shop)
i would guess it was warm
Yea your right but the kit rebuild kit comes with all that i think. But as for the fuel pump i have the one out of my parts carvulcanrush wrote:i love parents too.300ZXttZMAN wrote:yea i know but i have my own money also that will take care of labor my dad is willing to loan me 6k for what ever i may need to complete this stage of the build
quote from my dad: "I want to see that beautiful car run"
gotta love dads
but in parts alone, 2k (rebuild kit), new fuel injectors (1,400), 120k pack (i can't believe you didn't mention this ---- 550), gaskets (300), efi wiring harness (400), that leaves you about 1500 for turbos.
i didn't mention possible maintenance items like a new tt fuel pump if the old one is worn out, knock sensor if the engine is out of the car, new fuel hoses, an electronic boost controller maybe?
you're right, it comes with the nissan oem gasket kit and a water pump and a timing belt, so instead of 1,500, that leaves you 2,000 for the turbos.300ZXttZMAN wrote:
Yea your right but the kit rebuild kit comes with all that. But as for the fuel pump i have the one out of my parts car
Yea i already new hose kit freshly installed, 2 brand new oem o2 sensors already installed, plenty of tps sensors... Im going with a manuel boost controller till my moneys not funny.. But yes i have a hard on for the sport 700's so thats what im getting if i have to sell the bed that i sleep on to be able to afford it ill do itvulcanrush wrote:you're right, it comes with the nissan oem gasket kit and a water pump and a timing belt, so instead of 1,500, that leaves you 2,000 for the turbos.300ZXttZMAN wrote:
knock sensor, ptu, tps, o2 sensors, motor/engine mounts, hoses can eat that up fast.
and a good ebc, like a blitz, is easily 550 bucks+.
so maybe jwt sport530's, etc, are more suitable for you budget. but you seem to have your heart set on sport700's.
Shouldn't need to replace those first 3 things unless they're bad. The O2 and mounts I agree with. Same with hoses, though using SAE J30R7 hose for coolant hoses will save some money. Silicone for all vacuum lines. Do it once, do it right.vulcanrush wrote:knock sensor, ptu, tps, o2 sensors, motor/engine mounts, hoses can eat that up fast.
300ZXttZMAN wrote:Im going with a manuel boost controller till my moneys not funny.. But yes i have a hard on for the sport 700's so thats what im getting if i have to sell the bed that i sleep on to be able to afford it ill do it
DO NOT USE A MANUAL BOOST CONTROLLER!!!!
They are bad, lead to boost spikes, and make your engine go boom. Do it once, do it right.
NolimitZ32 wrote:You can run big turbos with stock breather hardware but you shouldn't boost them too high (i am by no means an expert on this) but physics and flow dynamics dictate that the harder it is for them to breathe the harder they will push the more internal wear will result. Now what degree this will be to I cannot speculate but better safe then sorry.
the power won't be the same, but it'll be more driveable.300ZXttZMAN wrote:it sucks because
1. the power wont be near the same as sport 700's
2. Im going to have to pull the motor again! when its time for upgrading*sighs*
Tony said it'll be laggier, you won't be doing any damage (with a good tune).300ZXttZMAN wrote:well im not going to be able to go that route im going to have to roll with the stockies i wanna make sure that it does not damage anything being that it will be short on air
Sentences please.300ZXttZMAN wrote:well im not going to be able to go that route im going to have to roll with the stockies i wanna make sure that it does not damage anything being that it will be short on air
BigTDogg (MA) wrote:Sentences please. Fixed300ZXttZMAN wrote:Well im not going to be able to go that route im going to have to roll with the stockies. I wanna make sure that it does not damage anything, being that it will be short on air.
I have no idea what you're trying to say here.There's nothing wrong with stock turbos and breather mods. You'll get a reliable, incredibly responsive 420+RWHP on pump gas. Plus you'll save about $2k versus the Sport700s. If you just get new CHRAs for your stockers it's about $600 for the pair.
IMHO, you need to breathe, then begin the removal and teardown of your engine, and determine the root cause of your low compression. Do your own compression check as well. It's a very easy test to do, and if the shop did it cold, all this fuss could be about nothing. Was your car running like cacapoo before you brought it to the shop?
If it turns out your rings are shot, find a good machine shop near you to do the torque plate honing work, maybe even refresh the heads a bit and take it from there. The IC pipes can be installed with the engine in. The 3" exhaust can be done with the engine in. The only things that need to be done with the engine out are the manifolds, compressor inlets and turbos. Everything else can wait.
BigTDogg (MA) wrote:Apparently neither has anyone developing Z32 turbo applicationsAce2cool wrote: Just for the record, my head just exploded. I would have never thought of anything like that.They would be amazing to have on our cars, providing the best of both worlds with stupid fast spool and freight train pulling ability.
300ZXttZMAN wrote:hmm well im deffinately getting new turbos (that our upgraded) with my motor build
Could i go with sport 700's i like the way they look and the price is not bad could still run stock injectors and only would need a tune??740s would be a good start, but IMHO, if you're looking for big HP, I'd seriously consider the BDE top-feed rail with the 1000cc/min ID injectors. Easier to swap out, huge flow capacity and lower relative cost.NolimitZ32 wrote:No stock injectors on anything bigger than the 530s, even 530s I wouldn't run stock injectors on, if you get 700s you need min 740cc NISMO injectors.
You would need every kind of flow mod there is. Built internals, headwork, bigger turbos than you would need with a race gas tune. Race gas allows you to push the engine to it's absolute limit without the fear of detonation. Pump gas you don't have that luxury. With the saftey margins required for PG tuning, you lose some potential for the sake of safety. I'd be shocked it the GT28RS could hit 600RWHP with a safe tune on 93 octane fuel. Not saying it can't be done, but I'd be surprised for sure. Bigger than that and you're looking at Z1's GT800 kit, or SZ's EXP-90, both of which bring serious lag with them.Khiem wrote:What are the main things that would make a pump gas car with 600rwhp so $$$$?
People often toss around 600RWHP or 700RWHP without knowing what that power brings. Not specifically targeting you OP, just saying in general. 700RWHP is where you start having manual transmission issues. Autos need to be upgraded long before that. Then you neet to worry about half shafts if you're drag racing. The safe limit for the OEM TT fuel pump is somewhere between 650 and 700RWHP.
IMHO, when approaching a build, it's always good to have goals. But rather than having a number as a goal, I like to think of what the car is intended to be used for. If you want a car that is super responsive and an absolute blast on the street, then I'd get the full 3" SZ stuff, 2.5" IC and inlet pipes, Sport 550s and call it a day. Maybe get Leader Gears if you can find a set. Then you'll have less lag than stock with a reliable 500RWHP all day long. If you want to built a drag monster, I'd get a built SZ auto transmission, EXP-90 turbo kit, all the aforementioned breather stuff, 1000cc/min ID injectors and BDE rail. That'll get you mid to low 10's all day with a decent driver.
More data (if you need it): my old 91TTZ with the 3.69 TT rear end with 320RWHP and 355RWTQ had a best 0-60mph time of 4.43 seconds in 55°F air. I haven't run my new car yet, but with 110+ more peak HP and TQ, and equal torque 1000RPM sooner, I expect very low 4s, high 3 second 0-60 runs. See below:
Long story short, there's a lot more to a build than a peak HP number.
6 of one, half dozen of the other.300ZXttZMAN wrote:yea thats definately interesting but im going to be going with sport 700's my mind is set
DO NOT USE SILICONE lines for any oil application. I don't care what they claim, they will still sweat oil. Slotted OEM drain tubes do the job just fine.Forget slotted oil drain lines, spacers, and leaks. All Z1 GTBB turbo kits now include the Z1 silicone turbo oil return line kit.
fitment is the issue (manifolds, etc.), the "best" turbos at the moment seem to the the precision turbos with billet wheels.NolimitZ32 wrote: I'd do a custom twin S256 setup (Borg Warner FTW).
The Sport700's can be ordered with either turbine housing. When they were first offered, they were only .86, but for the last few years you can order them in the .64NolimitZ32 wrote:More info I dug up:
Z1 GT675RS - GT2860RS with .64 A/R Housing
JWT Sport700BB - GT2860RS with .86 A/R Housing
VNT > *.* If you're going to go custom, why not go superballercustomsweettits!!!NolimitZ32 wrote:custom twin S256 setup (Borg Warner FTW). But if you are looking for top end power than stick with the 700s
