my 240sx ford 302 engine changes (lots of pics)
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
maik21
Car: 90 Nissan 240SX Coupe 5.0
Slidin sideways
Car: 1990 Nissan 240sx
What radiator did you use?
maik21
maik21
there are some work to do . maybe 90% of electrical wiring is done. battery to the trunk. some relays and msd box under dashboard.
maybe this week i wiring cluster and put the new f303 cam. engine runs again yesterday and runs very good. ( it was off since jan 1st.)
now it looks much better !! im very happy .
maik21
i wil do a little of work here, but this is all wiring on this s13 . lights, pop up lights, tail lights, all works fine.
540sx
Car: Nissan 240SX
wiring looks clean, you don't want to see the nightmare under my dash.
maik21
today i install f303 cam on my engine!! i dont test car yet because car is very noisy.
here is the video.
http://www.youtube.com/watch?v=DP5y_ZdoW6w
maik21
engine runs very fine. now, it revs up to 6100 without problems. i put some more gas on engine and test it again.
this is only what i have. yellow lights are from my car.
http://www.youtube.com/watch?v=SZy9boeABK0
WDRacing
Have you welded the diff? I can't remember, if not do so. Any new track times?
maik21
diff its welded since 1998.
i dont have any track time yet. maybe this month or next i will go to the track.
CJH
Car: S13
nookie2692000 wrote:ok so i been slackin a bit. lol got a little update. not much for now. but i should have my motor in, within the next few weeks.
Holy s***! thats awsome. Im just surfing the web and I came across my car with its previous owner. lol, small world.
Edit: I guess the pic didnt copy in the quote but its the pic by nookie on page 2.
maik21
12.77 ET
113.xx mph .... 183kmph trap speed.
2 step was set to 2700 because poor track conditions. car has a crapy launch. i think car can do a 12.50 with no problems in a better track.
videos comming soon !!
maik21
240sx .... "02"
[youtube]http://www.youtube.com/watch?v=5QWrRPX_5cA[/youtube]
maik21
i have this to test my carburator
maik21
me and some friends. im the one with white tshirt.
maik21
some new items for my nissan !!
i dont know when i will install this. maybe next week.
maik21
holley commander start. isnt tuned yet.
http://www.youtube.com/watch?v=KIi2vsyEE_c
maik21
maik21
both cars on street tires.
i was testing the holley commander 950
sentra 1992 is a turbo setup. t28 @7psi.
240sx 13.6 et and sentra 14.3 et
[youtube]http://www.youtube.com/watch?v=yUQQduCcQ9c[/youtube]
[youtube]http://www.youtube.com/watch?v=FgXG_r-rWQY[/youtube]
commander needs more tune but i dont get wideband yet. i was doing some datalogin and change parameters.
maik21
some friends at the back of my car and taurus sho friend´s car.
maik21
i found why my car seems to be a little underpower.
i will add more fuel throught 2000 to 6500 rpm. i go back to track maybe on 2011 and test it.
maik21
240sx incar cam vs sentra turbo t28 @7psi
[youtube]http://www.youtube.com/watch?v=_egLzUX1Ap0[/youtube]
this video its the complement of the past video.
maik21
finally i got my wideband. its a kit so i need to assembly.
this kit dont come with lcd or 7 seg display, so i need to see O2 values on laptop or datalog.
:gapteeth:
maik21
wideband done 100% .
i test yesterday at night and car is running to rich at wot. afr was 10.9 - 11.2 from 4000-6200 rpm.
i set afr to 15.0 at cruise and under 3000rpms and under 50% of load.
Speckid4
Car: 1995 240sx
1993 240sx
You must know quite a bit about electronics, not sure I would tear them apart like that, too afraid too make a mistake and destroy an investment. I'm not usually a downer, but you could have saved a lot of time by saving and doing it all at once, but you obviously have lots of time to tear down and rebuild multiple times so all and all its not that bad. Keep up the good work. DIY rules.
Speckid :bigthumb:
maik21
finally it runs better.
i went to the track and it did 12.4 on 1/4 mile. car maybe can run a little more faster but they close drag track early.
pictures ftw.
in this video i was driving and then my brother drive.
[youtube]http://www.youtube.com/watch?v=tU_ytyYjtW8[/youtube]
in this video, car was on slicks and i was driving.
[youtube]http://www.youtube.com/watch?v=W5Wh_EYHkO8[/youtube]
and here are the pictures
Chingon
Car: 1991 and 1992 hatchbacks
It's been a while since I remember you throwing the swap idea around. It's good to see it come this far. Proud of you paisano...
maik21
thank you!!
maik21
well, i have some things for my 240.
its a t4 rotary(or something like this) . fd3s..
ic + extras
Al tube.
and this is what i have right now.
and this is the co-pilot manifold.
yeah, it looks ugly and i sucks with flux core welder !!
i only want some extra power in the 3rd and 4th gear. f303 cam its used with forced induction.
wastegate is set for 4psi and maybe i will run 7psi. i have a new map sensor(2 bar) for turbo setup.
maik21
Return to “Hybrids”
