I made this thread because I think its helpful.
It started from this
zerothread?id=202517 and I'm elaborating it to what you see now.
Credit goes to MyeeS13I used some of your photos without your permission.I hope thats cool, im doing this for eveyone's benefit
Difficulty. ***Time: 25mins - 2hours. (the first time it takes longer)You'll need: 8mm, 10mm, 12mm socketflathead,engine grease, ( for lubrication )engine cleaner ( for sludge and grime )and Lastly a SOHC 89-90 KA STARTER VERSION: HITACHI!!
________
Preface: The only parts, you'll replace are the brushes at the bottom of your SR starter, and the solenoid. Clean the rest, and your starter is good as new.
1: "Getting Started" dont open you're SR starter until you've completely disassembled your KA SOHC starter. that way you'll be familiar with all the parts. work in an open space.
2: "Disassembling The Starter" remove the two long 10mm bolts from the SR starter, and 2 from your solenoid. Spray and clean the Black housing section with the green sticker. Over time it accumulates grime that hinders your motor's spinning.
"The Starter Head" - The head should face down,because it has 4 gears that are unfastened, but they're easy to put back on. clean them with degreaser and liberally apply engine grease.
this is the KA head, that you wont be using.
3:"Replacing the Brushes" - the base of the copper core. for the eletric motor, is clamped in by brushes. when starters dont spin, its because these brushes have worn out.
EDIT:: the brushes are 4 small copper bars that press against the bottom of copper core. When you turn the key they send lots of current and spin the motor. throughout the life of the starter they burn away and shorten, until they aren't long enough. there's a spring behind them to push them outward as they shorten but eventually its not enough.
replace them to give your starter renewed factory life.their plate is attached by two small phillips screws from underneath.
4: "Assembling the Motor w/ New Brushes" - Assemble the motor first, then replace the solenoid. The main housing of the starter, wont seal up and close properly if something isnt aligned, so check everything before you tighten. I snapped a bolt by mistake this way. The starter housing should seal up nicely if everything is aligned and in place. it will take a few tries to feel this out, but once things fil, you'll know.
5. "Attaching the solenoid" slide the pin into the new solenoid's head. This pin is what ejects the gears out the starter and fires it up. when pushing the solenoid into its housing... make sure it snaps in, and lines up with the inset holes. once its on tighten quickly.
If your starter spins, and doesn't initiate the motor and flywheel its because the solenoid is dead.
This was my starter after a rebuild, you can see the new solenoid, and new bottom cap with fresh brushes. Im very pelased with it, and its nice to know your starter will last for another 6-10 years.
It just requires patience.
feel free to ask questions. or post any additional suggestions.
- Malik
Modified by Kalypso at 8:59 AM 6/23/2009
