1) All the guide pictures are old vs. new. The old guides are the brown bakelite looking material. Not not sure which side was driver vs. passenger in the side-by-side pictures. I guess it doesn't matter as the parts guys will know. There were some posts from a member named Subtle_driver where he shows the bagged part numbers. I will try to find the link for ya.
2) I took a breaker bar and socket for the crankshaft pulley then tapped the started with the fuel pump fuse removed. I had to leave a couple of inches of travel for the started to move the crankshaft or having the bar rest on a concrete floor won't be moved by the started. It is kind of dangerous for a first timer...
3) The crank doesn't matter for removal. Just be sure the crank pulley puller doesn't hook on to something you don't want to pull when you start pulling..
4) While it doesn't matter is is a good reference point to find Top Dead Center with the silver and gold link lineup like I have in the picture before you start working with guides. Just in case the chain should slip you can reposition it without too much hassle. Just take some white touch-up paint and touch the chain and the positions to have as a perfectly timed reference point before you start.
5) I'll post a picture of re torquing the crank pulley bolt and how I used a chain wrench to tighten it. Posted below..
Here's a link to a post with other links (including Q45.org) about guide jobs.
timing-chain-guide-t384145.html?hilit=guide#p4210698
