Mettler wrote:The other thing he mentioned was that the oil has a bit of a mazelike pathway from the filter housing all the way to the back of the block and up to the middle rail where it feeds the mains.
They don't bother with this, and plumb a line from the filter straight into the front of this rail in the front of the block (under the water pump) using a modified -12 fitting.
I found some awesome pics of a VH45 teardown here:
http://www.turbo-infiniti.com/...be7b1
Specifically, these:
Mettler, could you or your superstock builder point out where the feed for that rail is? The black opening immediately below the water pump looks like it has a hex-head fastener sealing it up. The smaller silver opening below that one looks like a mount point for a timing chain guide, so that's not it. I also wonder about the 2 larger discs with hex-head sockets.
Edit: I was going to be lazy and hope someone would figure out what I was talking about in my description, but I pulled up The Gimp and circled the objects in blue/cyan:
Can someone with a torn-down VH try removing those fasteners/seals and show us what's inside?
Edit: I'm too impatient to wait for a reply so I'm doing my own analysis with the pictures available. The black fastener below the water pump appears to be positioned directly over the crank:
There is a round hump at the top of the crank case that goes the length of the block, positioned directly over the main bearings; note the hole for an oil feed in each main bearing... right over the hump. I'm guessing that the hump is the main oil gallery; this fits with the illustrations in the 1994 Q45 Factory Service Manual.
There isn't a picture that has both the gallery hump and that black fastener/seal under the water pump in view, so I don't know if they are in line with each other. But I bet that black seal is some kind of port/access to the main gallery for drainage during maintenance; that's probably the location Mettler's stockcar builder tapped for an oil feed.
Modified by koukimatt at 12:20 AM 5/1/2009
