duceynash »
https://forums.nicoclub.com/duceynash-u146796.html
Thu Nov 05, 2009 7:29 pm
Alrighty, here are some night pics. Its easier to see how bright they are.
Ok....Here are the steps. If you get stuck, just shoot me a message and I'll help you as much as I can. The site that I got my lights from is ijdmtoy.com. They are like $26 for a pair, and they get to your house in like 4 days max. You can also get HID upgrades etc from that site. Start to finish, it took me about an 1 1/2 hrs. I would suggest, however, that when you put these in, you go ahead and upgrade the Headlights (if you want), I upgraded to 6000k, and also go ahead and upgrade your foglights to HID's as well. Doing it all at once is soo much easier.
1. Get yourself a good jack, and a good set of jackstands. You can get jackstands at any autoparts store for like $25.2. Jack up one side of the front end, and remove the wheel. This is soo much easier with the front wheels removed.3. Unscrew all of the front screws that hold in the plastic wheel well covers, and pop out all of the black rivet thingy's?? Only the front part needs to be removed, not the top or the back.4. Next, place your Jackstand on the side you just removed everything on, and move over to the other side. 5. Repeat the same process.6. Now there should only be about three screws on each side of the bumper cover that lay pretty much under the Headlight assembly. Take all three of these screws out on both sides. The bumper should pretty much become loose. 7. Pop the hood, and remove the grill and then there should be two more of those black plastic rivet thingys?? Ha!! Holding the top of the bumper on. 8. After that, the bumper should slide off very easily.9. Wire up your strip of lights into the parking lights using red butt connectors. The parking light wires should be right up front, and very easy to get to. At least they are on mine. The silver wire on the strip of lights is positive, and the bronze one is Neg.10. Once you have them wired, clean the under part of your headlight with alcohol so the 3m tape on the back of the lights will stick very well.11. Very carefully stick your lights under the headlight assembly, and trim the strip wherever you like. Be very careful tho, because you can only trim the strip every three LED's. There is actually a little mark on the strip showing you where to cut.12. Put the bumper back, as well as everything else, and your all set.
It sucks to have to take the bumper off, but based on my research, removing the headlight assembly requires that you take the bumper off anyways. And once you have the bumper off, there isn't any need to remove the assembly, cause you already have access to the bottom of the headlight.
Anyways, it was really easy, and it will be for you if you just take your time. Let me know if you have any questions.
