I found this site while extensively searching for some of the issues I am experiencing with our 2009 Rogue SL's A/C system. Here is where I am at. We've got 116,000 miles on it, keep it regularly maintenanced, and have had no major issues up until now (replaced the EVAP valve a few months ago because it was stuck closed)
-A/C quit working in our Rogue on Saturday. Drove to in-laws to use the pool, A/C was fine, car sat about an hour, drove back and about halfway through the trip, the A/C started blowing hot air.
*Compressor does not run when Max/AC mode is on (A/C light is on)
*Blowers are running fine.
*Pulled the connector off the compressor to test for voltage, no power when A/C light is turned on.
*Opened the IPDM Module and tested the A/C fuse and the supply from the battery, both rang out as working fine.
I think we have it narrowed down to either the A/C relay going bad or the Refrigerant pressure switch is bad.
My question is, how do we bypass the pressure switch to see if we can get the compressor running to determine if it is the switch or the relay? Looking at the schematic, those look to be data lines that the pressure switch just communicates back to the relay to kick compressor on or off. (I attached the schematic) I thought about buying a new valve, and and using nitrogen to introduce a pressure chance to get the compressor to kick on, but I'd rather not spend $70 on a part that I won't be able to return to the dealer. There are 3 prongs on the female end of the switch, and I don't want to jump the wrong to prongs and risk shorting it out. I just need to know which ones to attach the jumper to.
Also, if the compressor does not kick on with the bypass, we can basically pinpoint the relay as the issue, and from what I have found, you can't just replace the relay, you have to replace the whole board? Is that correct?
Any help would be great, thanks guys.
