dave08902 wrote:The ambient temp sensor is only for the dash board. It shows the ambient temp and has nothing to do with the A/C system. It is an option for higher model vehicles, I also got the connector with no sensor and I don't have any readouts in dash for OAT and my A/C works
Thanks for the reply! It appears I wasted some good $$ on a sensor that I don't need. Unless I upgrade to the fancy mirror (I just might) in which case it isn't entirely wasted.
To answer your questions:
1. If the clutch did engage, what are your gauge readings?
Clutch did not engage.
2. Are the low pressure lines cool?
Hard to tell, but we did push the 1.1lbs of R134a in.
3. Did you pressurize with nitrogen for a leak check and did you apply a full vacuum before servicing.
We pulled a vacuum on it for over 1/2 an hour. We did not pressurize with nitrogen. However, I am very certain that the system is not leaking.
4. Does the compressor stay full on or does it cycle?
Compressor will not engage.
Did some more checking, and it appears that the Refrigerant Pressure Switch is damaged. I have ordered another one, and will change out. Hopefully that is what is keeping the compressor clutch from engaging.
I am troubled that I can't turn the compressor. Its brand new, and turned just fine before I installed it. As I mentioned above, we used the vacuum pump to push the right amount of R134a into the system, as we couldn't get the compressor to engage. When I checked my low side pressure a few days later, it was way in the red, over 140PSI. I bled off the pressure, but the only thing that came out of the port was air (no refrigerant). I found this to be kinda weird.
With regards to to compressor, I am theorizing that either of the following has occurred:
1. The pressure on the low and high side is far to high, and preventing me from turning the compressor by hand.
2. The Compressor is 'slugged' and full of oil, and can't turn.
3. There was contamination in the system, and the compressor is grenaded again. (dang)
What I plan to do is to do another evac on the system when I change the pressure switch. I will then check to see if the compressor is seized once it is evacced. If not seized, will refill and hopefully the compressor will engage which will allow me to fill the system properly.
If the compressor is seized, I guess I will have to get a new one (LT $200 rockauto) and I will also change the condensor (it was changed during the rebuild) along with the receiver dryer (again). Will also run a flush through the rest of the system.
Where is the expansion valve in this system? Under the dash?
Thoughts? Thanks for reading.
t
