So its been a while since ive been on nico.
Since that time. the car saw its first real track time.
Took the car out to night moves down at english town and did some drifting.
The car felt pretty good for the first few runs then out of no where the clutch started to slip as soon as I hit boost.
I dont know what it is but my car has always had clutch problems.
I of the things I can think of is that the its a combination of the aluminum flywheel not being able to take the heat and the master cylinder s*** out....
When the clutch griped it felt pretty good and the track layout was pretty fun and basic.
It had been raining all week and all day but it ended up drying up. Not to many people came out which was okay cause i was able to get alot of seat time.
THe day after I brought the car to my buddy steve over at kova built to finally work on these yamato garage arms.
These things went in with no problems and I am very impressed with them.
here are some picks
Front traction arms ( caster) just over stock at 7*
The rears
GLITTER TOWN USA
We also Started on the rear 300zx brakes.
Let me tell you. These are a b****.
Ive had so many problems with these little f*** makes me wish i just stayed stock.
Well if you dont run 300zx hubs in the rear the ebrake mounting piece wont sit right and allow the brake pads for the drum to sit right. easily fixed to the right clearance via 2 3/4 spacers.
great everything in dandy now right?
nope
Calipers wont clear the brake shield..... ok trimmed and fix
ok well lets work on the cables. I was told to run 300zx 2+2 cables because they where supposedly the only ones long enough.
I dont know whats going on but they are too long. Has anyone else had this problem?
Well lets put the steel lines in. ok never mind the brake line just snapped....
Well anyways the brakes are pretty much done
just need to fit the brake line and find out why my e brake cable is too long...
well until next time
