Zomg can't turn off caps lock
NODOZ22
Car: 89 NISSAN 240SX COUPE
I HAVE 89 240SX COUPE JUST GOT XXR 006 WHEELS AND THE FRONT ARE 18X8.5 W/ 35 OFFSET AND I HAVE 245/40 TIRES AND IN THE REAR 18X9.5 W/ 35 OFFSET AND HAVE 274/40s WILL I NEED SPACERS IN THE FRONT OR REAR AND IF I DO WHAT SIZE SPACER THANKS EVERYONE
BrianHarte
Car: 180sx
There are a lot of things that could make the answer yes or make the answer no.
Ride HeightStock or Aftermarket wide fendersTire BrandSuspension set upCamber settingetc.
I don't know how to answer your question.
zeedakay
Car: s13
DO YOU HAVE A LOWERED APPARATUS? IF SO JUST PUT THEM ON THEM MAKE IT FIT. 274/40 MUST BE A HARD SIZE TO GET HOLD OF
Dittoz7
Car: 1997 2f0WtY SE!
WHY ARE WE YELLING?
NODOZ22
WELL ITS NOT LOWERED YET AND ABOUT TO ORDER CUSCO COILOVERS BEFORE I TRY TO PUT THEM ON. AND MY TIRES ARE BFGOODRICH G-FORCE SUPER SPORTS A/S ASLO WILL BE PUTTING 30MM FENDER FLARES IN THE FRONT AND 50MM IN THE REAR
ashibah83
Car: 93 SUPA BLACK COUPE
Dittoz7 wrote:WHY ARE WE YELLING?
WHY???? LOUD NOISES!!!!!!!!!!!!!!!
NODOZ22
NODOZ22
WELL ITS NOT LOWERED YET AND ABOUT TO ORDER CUSCO COILOVERS BEFORE I TRY TO PUT THEM ON. AND MY TIRES ARE BFGOODRICH G-FORCE SUPER SPORTS A/S ASLO WILL BE PUTTING 30MM FENDER FLARES IN THE FRONT AND 50MM IN THE REAR. ALSO WHY IS IT HARD TO GET A HOLD OF 275/40 JUST WONDERING
Jdmstyles
Car: My S13 took a crap on me.
Err your questions are too broad to answer. If you're going with fender flares, then of course you'll need spacers to make it flush. Do you want the flushed look? Then again I can't see who wouldn't want it. The offsets on the 006's are too high, so you'll need spacers. And I think you'll also need spacers in the front to clear your coilovers.
And if you're going to run fender flares, my suggestion is to not run these wheels at all. They have bad offset, and I'm sure you'll need a friggen 50+ mm spacer to adequately pull off flares.
I'm confusing myself trying to answer your question.
AZ89two4Tsx
MAYBE YOU SHOULD JUST TEST FIT THEM FIRST TO SEE IF THEY WILL CLEAR. IT'S REALLY NOT THAT DIFFICULT. IF THEY CLEAR THEY CLEAR, IF THEY DON'T, THEY DON'T. IF THE FRONTS DO IN FACT NEED SPACERS, IT WILL BE MINIMAL, NOTHING OVER 5MM PROBABLY. THE REARS WON'T NEED A SPACER AT ALL.
Jdmstyles
^ Boom headshot
cbt240sx
Car: 1990 Nissan 240sx
Have you even tried to test fit? Pics?
21nemesis
Car: 1993 240SX SE
I had to use 5mm spacers with the 8.5"ers up front.
ZOMG.SR20
Car: 1990 s13
STFU!!!!!!
and cusco is out of business BTW....
ronnie_angel
Car: 1993 240sx
AZ89two4Tsx wrote:MAYBE YOU SHOULD JUST TEST FIT THEM FIRST TO SEE IF THEY WILL CLEAR. IT'S REALLY NOT THAT DIFFICULT. IF THEY CLEAR THEY CLEAR, IF THEY DON'T, THEY DON'T. IF THE FRONTS DO IN FACT NEED SPACERS, IT WILL BE MINIMAL, NOTHING OVER 5MM PROBABLY. THE REARS WON'T NEED A SPACER AT ALL.
HA!
King Ranzo
Car: 15 Ford Focus ST
OP, see that caps lock button? Press it.
SupahTyTeTwoFowty_y0
Car: at least 15 but no more than 2
240tunerguy
Car: s13
did somebody turn the volume up in here?
zeedakay
Car: s13
I HAVE 17X9 FRONT WHEELS WITH NO SPACERS NEEDED. RESULTS MAY VARY
killernoodle
Car: My daily: 2005 Cadillac CTS-V - pretty much stock
Brother's S13 project car: SR20det, wilwoods, suspension, q45 diff/axles, 315s out back
I FIND THAT 17X9 WHEELS WITH AROUND A +25 OFFSET YIELDS THE IDEAL WHEEL FITMENT FOR AN S13 FRONT. NOT ONLY IS IT PERFECTLY SPACED TO GIVE THE COILOVER CLEARANCE, THERE IS JUST ENOUGH "STICK OUT" TO CLEAR STOCK FENDERS WITH A LITTLE ROLL.
sil80_chris
Car: 1991 Nissan 240sx
Oh good times good times...
zeedakay
Car: s13
killernoodle wrote:I FIND THAT 17X9 WHEELS WITH AROUND A +25 OFFSET YIELDS THE IDEAL WHEEL FITMENT FOR AN S13 FRONT. NOT ONLY IS IT PERFECTLY SPACED TO GIVE THE COILOVER CLEARANCE, THERE IS JUST ENOUGH "STICK OUT" TO CLEAR STOCK FENDERS WITH A LITTLE ROLL.
YOU SIR ARE CORRECT. MY 17X9'S HAVE ARE +15. I THINK I'LL GO BACK TO MY KNITTING NOW
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
Jdmstyles wrote:^ Boom headshot
ZootedS13
Car: 1990 240sx se
BrianHarte
Car: 180sx
Do people ACTUALLY get upset if somebody types in all caps?
If so, sounds like you need to get outside and step into the real world for a minute. I assure you there are a lot more things to be worried about.
thornberry
Car: 92 s13 vert.
ZootedS13 wrote:
and you sir, WIN!
NODOZ22
YA U SAID IT BRO THATS WHAT HAPPENDS WHEN U GOT KNOW LIFE AND U WORRY ABOUT SOMEBODYS CAPS LOCK IS ON. AND YA 275/40/18 35 OFFSET JUST FIT PERFECT VERY SICK AND NOW ORDERING CUSCO COILOVERS TO SEE IF THE FRONT TIRES FIT RIGHT
Nali
Car: Datsun Nissan 280ZX
BrianHarte wrote:Do people ACTUALLY get upset if somebody types in all caps?If so, sounds like you need to get outside and step into the real world for a minute. I assure you there are a lot more things to be worried about.
Its just a little annoying to read all caps, and yeah after i went outside and got some fresh air, i realized how shallow it was of me to be getting annoyed at something as simple as all caps
But its cool, im sure the OP wont do it again.
NODOZ22 wrote:YA U SAID IT BRO THATS WHAT HAPPENDS WHEN U GOT KNOW LIFE AND U WORRY ABOUT SOMEBODYS CAPS LOCK IS ON. AND YA 275/40/18 35 OFFSET JUST FIT PERFECT VERY SICK AND NOW ORDERING CUSCO COILOVERS TO SEE IF THE FRONT TIRES FIT RIGHT
FFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUU!!!!!!
White Comet
Car: fc, s13 and mazda6, Sierra
between spelling, grammar, punctuation and caps lock you type worse then an 8 year old
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
