crackler »
https://forums.nicoclub.com/crackler-u26495.html
Mon Sep 22, 2008 4:53 pm
The steam wasn't from the fluid, unless you had brake fluid spraying out. It was from the pads and or rotors over heating, which caused the fluid to boil, which caused the pedal to sink to the floor.
Was this on all 4 corners, or just one? And what do you mean by the pedal locked up? If it was all four corners that locked up at once, I would start at the master cylinder / pedal assembly. Basically anything that controls all four corners of the brakes at once. If it was just one corner, or the front or rear, then it could be separate issues all together.
Like SR said, pull the calipers loose, make sure they move freely, and completely flush out all of the old brake fluid with new fluid, and bleed everything out really good. You might also check and make sure all off the pistons can be compressed. The fronts should be able to be compressed in with a C-clamp or similar compressing tool. The rears need to be "screwed" in. Get the funny looking cube deal from the parts stor for the rear. Also check the rotors, pads, and seals; make sure they haven't been damaged from the excessive heat build up.
