RicerX »
https://forums.nicoclub.com/ricerx-u125542.html
Thu May 27, 2010 12:32 pm
If you have a manual, do it, if your buddy is actually credible with putting that sort of thing together, as those systems usually require modification to the intake manifold and throttle body. Your engine is a bit more manageable bc it's a 2.5, so you have more room to work.
If you have a CVT, I would spend your money elsewhere, as these systems are usually set up to trigger nitrous delivery at WOT, so anytime you plug it, you spray, and the power gains possible with this will create problems for your transmission at some point - it's just a matter of when. The CVT is ok with a few bolt on mods, but FI and N20 are just not good ideas with this thing yet - it just can't handle that much of a dramatic power increase.
