Nowhere »
https://forums.nicoclub.com/nowhere-u31342.html
Fri Sep 09, 2005 4:22 pm
Take the gauge out of the pod/wherever it's mounted.Have a hot wire, ground DIRECTLY to the battery, an engine ground, and the sensor lead. Test the pressure on the side of the car (outside, have the gauge in your hand). Have the engine/sensor ground tied in with the battery ground, wire up the +12v and re take your measurements.
You're probably floating a ground and are getting inaccurate readings.
A failsafe, use/try a mechanical gauge..
