Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.html
Sat Aug 08, 2009 2:18 pm
Why would you ever want to limit extension?!Maybe I am wrong here, but you can't compare that to a sway bar...yes a sway bar is some what lifting the inside wheel, but that is the bad part of it, that is what you give up to increase roll stiffness with out increasing spring rate so that the suspension can still absorb bumps instead of bouncing over them....
Body roll is a function of spring rates, wheel base, cg location, roll axis inclination and height and track width. Limiting the extension of the inside wheel will not limit body roll, it will just put less pressure on that wheel giving it less grip.All your doing is helping lift the wheel off the ground, and putting more weight on the outside tire. The force produced by tires is not linear with the weight put on them. Loading a tire with and extra 10 pounds produces less grip then is lost by removing 10 pounds from the load, so there is always more grip when the load is shared as equally as possibly.
Since it would be foolish to trust me alone, let me take the words of a MUCH smarter man, Carroll SmithQuote »We want our springs to have length sufficient so that the spring will not become unloaded with suspension at full droop. The reason for this usually overlooked parameter is that, when the suspension is fully extended, the car is usually flying through the air. When it lands, we want the springs to begin their resistance to compression immediately. If the suspension has to move a finite distance before the spring begins to compress, then a greater amount of suspension travel will be required to absorb the force of landing and we will have to run our ride height higher then we would have to if the springs had be properly designed. Not Good![/quote]Slight variation here, as he is speaking about a spring that is shorter then the stroke of the shock, however while the case of a preloaded spring lifting off the ground is slightly better the principal still applies. the whole car doesn't have to be off the ground if your thinking of each tire individually, and you are still giving the mass of the car a "running start" at compressing the spring.
He continues on the subjectQuote »Another side of the same coin is the fact that we wish to be pushing each of our tires into the track with as much force as we can arrange at all times. If a spring is so short as to uncouple in some combination of droop and roll then that tire is unloaded at a time when the spring could have been loading it This can lead to such things as partial loss of traction at one end of he car and inside wheel spin.[/quote]These were taken from "Engineer to Win - Understanding Race Car Dynamics"
BMW may have less rebound travel then compression... But I think we can agree that not only do you not drive a BMW, you drive a Nissan truck with a different suspension set up and design up front, and an ENTIRELY different suspension set up in the rear.Apples and Oranges.
