[Q] zenki to kouki converaion- bumper reinforcement
Mahoneys_Silvia
Car: s14
:mad: Okay so I am going to go kouki. Is the reinforcement /rebar a must have thing ? Can I modify the zenki one ? Also how do i know if one I'm buying is for a kouki and not a zenki? I attached pics of the one I might buy but need someone to help me verify that's its for a kouki. Thanks !Image
http://zilvia.net/f/showthread.php?t=593926
Last edited by Mahoneys_Silvia on Tue Feb 24, 2015 10:12 am, edited 2 times in total.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
When i converted my front end i had one for the Kouki but it turned out it was the same as the Zenki reinforcement .The crash foam is different of course.
Welcome to NICO!
sx moneypit
1986 Toyota MR2
Your images are not showing up to me.
Mahoneys_Silvia
Car: s14
Thanks and are you 100% sure there the same ? I heard there pretty much the same but using a zenki one will leave gaps. I edit my post and left a url for my zilvia post with pictures.
sx moneypit
1986 Toyota MR2
The only gaps will be because the crash foam is different.I didn't use the crash foam on mine because it was broken into pieces.
Mahoneys_Silvia
Car: s14
So buying the kouki reinforcement isn't necessary if i have a zenki one? I just need the kouki foam (or trim the zenki foam) and kouki retainer then ? i was also reading about the bumper brackets being different ?
sx moneypit
1986 Toyota MR2
Some of the smaller brackets on the sides of the bumper are a little different if i remember correctly ,but the reinforcement is the same.
Mahoneys_Silvia
Car: s14
I just ordered the brackets and retainer from nissan. thanks for your help. So i can re use my reinforcement then and just modify the impact absorber foam?
sx moneypit
1986 Toyota MR2
:yesnod Yes sir.
Mahoneys_Silvia
Car: s14
Thanks man i appreciate it ! once I'm done with the conversion i will post some pics up. :yesnod
Mahoneys_Silvia
Car: s14
sx moneypit wrote::yesnod Yes sir.
I was going to buy these JDM headlights kouki but there missing one of the gray plugs ,is that a big deal ?
