ZENKI headlight wiring dilemma !!! PLEASE HELP!
Fbomb19
Car: 1989 hatch
1996 zenki
1993 se hatch
1998 silver moss kouki
1992 base hatch
1990 hatch - CURRENT
Long story short.
I bought my 96 zenki with head lights working fine. Low beam alone worked fine and then when turn on high beam both low beam and high beam turn on.
Well after some time idk what happen and only my high beam on my right side worked and my low beam on my left side worked. So i got down to business and i looked around. Wiring harness plugs was a bit busted. So i got a bunch of harness plugs from nissans at the junk yard. Rewired them and all and i fixed it some what. Low beam worked fine. and when i turned on high beam on the high beam would come on and the low beam would cut off. I DIDNT MIND THAT AT ALL. And then today i buffed out my headlights and clear coated them (looks amazing btw) and i replaced the passenger side low beam plug cuz i never got the chance to do that one. and sooooo idk what is up -.- ,but now when i turn on my low beams only the passenger side goes on. And when i high beam my driver side high and low turn on but on the passenger side the high beam turns on but the low beam cuts off.
Its super frustrating. the harness appears to be fine. I sprayed it with the electrical cleaner and all. who else had this problem????? help me out and tell me what to do pls! :mad:
