nico240sx »
https://forums.nicoclub.com/nico240sx-u296967.html
Mon Jul 20, 2020 4:43 pm
Hi all,
I have a automatic 95 Zenki KA24DE with a blown head gasket. I have the head off and I am looking to replace the oil pump and the front oil seal both at the same time since the coolant mixed in with the oil when the head gasket blew and the front oil seal is leaky anyways. The issue is that I am trying to loosen the crank pulley bolt to get access to the lower timing cover BUT how can I lock up the crank pulley bolt without it turning over?
I searched the forums and it seems like there are 2 options:
1) Set the gears to 5th.(Can't do that on an automatic)
2) Start the car and have it turn over while the crank bolt is attached to a breaker bar(I have the head off so I can't do this method and the oil is mixed in with coolant inside the pump which will send the oil/coolant mixture back into the engine if I attempt with head back on)
Is there anything else I can do to loosen it?
Thanks.
