Diamond was just reading back through this thread and saw this...they probably only wired 1 voice coil because the amp you were running had better rating (stable) with a higher resistance load. If you were running a bridged set-up...a lot run more stable at 4 ohms. Im betting each coil was 4 ohms and the difference in sound if you wired both would be minimal to none so they went the safe route rather than take the load to 8 or 2 ohms.DiamondWVU wrote:
yeah i know. I bought those subs, a different box, that amp, and a capacitor off my friend for $220. Too bad the shop only connected one of the voice coils when they installed them in the box.
But I went through a lot of trouble to get this particular sub. My previous ride had a single 12" Alpine Type-X and that just didn't sound as good as I wanted (though it got decently loud). Two subs will almost certainly hit louder though (with twice the cone area, they move twice the air). But I couldn't afford to sacrifice the whole trunk to put two twelves in (tens don't get deep enough for me personally). So I went with one insane 12. I'll probably never go back to a two sub setup, but part of that is because I don't think I'll ever have a car with an electrical system capable of powering two UL12s.DJBeasy wrote:does that single sub bang enough?
Same here, have a useless Power Wedge now. Theres actually a user on here who has the same box and they have pics of it in the AC trunk...or should I say what used to be the trunk.AppleBonker wrote:
Im actually going 2 12"s to 2 10"s with the Zenclosures box and completely new subs (CHEAP, budget is tight right now, almost embarassed to say what I bought)...I think Im going to regret it.AppleBonker wrote:
If you're making the move from two twelves to one, just be careful that you don't try to set the gain to high and blow the sub.
AppleBonker wrote:But I went through a lot of trouble to get this particular sub. My previous ride had a single 12" Alpine Type-X and that just didn't sound as good as I wanted (though it got decently loud). Two subs will almost certainly hit louder though (with twice the cone area, they move twice the air). But I couldn't afford to sacrifice the whole trunk to put two twelves in (tens don't get deep enough for me personally). So I went with one insane 12. I'll probably never go back to a two sub setup, but part of that is because I don't think I'll ever have a car with an electrical system capable of powering two UL12s.DJBeasy wrote:does that single sub bang enough?
If you're making the move from two twelves to one, just be careful that you don't try to set the gain to high and blow the sub. Or, just get a beast of a sub.
