480sx »
https://forums.nicoclub.com/480sx-u50548.html
Sun Nov 12, 2006 5:41 pm
First time posting, although iv spent many hours of the last 3 mounths here. I recently installed the baseline Zeitronix setup, without the LCD, boost or EGT. Im also running SAFC2. For some reason, the RPM imput on the Zeitronix is going nuts. It reads accuratly at low rpms, under low throttle situations. However, when i get into high throttle, high boost it will jump from its true reading all the way to 15000's and everywhere inbetween. At first i thought that sharing the RPM imput splice to the ECU with the SAFC2 could possibly cuase the false readings. I respliced the yellow wire with the red stripe(pin3, RPM imput) so that the safc2 and the zeitronix tapped it at differnt locations, no change. Has anyone had a similar experiance? Btw, thanks for the HUGE base of knowledge thats kept here.
