Chezedik wrote:The FSM won't give info on the consult port?
Nope, FSM doesn't tell me WHAT pin transmits the RPM signal....
The thing is, there's only 5 wires going to the connector on the blitz unit, yet it reads 20+ parameters...and 2 of those wires are for power and ground. So 3 of the wires are controlling quite a bit.
What the FSM does say isn't very useful for me:
One is "SCIRX," One is "SCITX"One is "SCICL"
Not to mention, the Zeitronix instructions says that the RPM input is a 0-12 volt square wave, whereas the FSM says that the tach signal wire is approximately 0.9 volts...
The main problem is that the Zeitronix is made to be universal...
However, it can run without the tach signal; I just want the signal for when I eventually data log (and eventually drive the damn car! weather's been horrible here and will be for the next week )
