Zach's S13 Build Thread!! LOTS OF PICS! VH45 SWAP!
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
I'll take all the drill and pt they want to do, but this uniform inspection every freaking day crap is just annoying...
scir16v
Hate to be a bearer of bad news, but that keyway thing that you made for the oil pump. The keyway slot in the drive gear for the pump is only for you to be able to slide it over the main engine pulley key. The reasoning for the torque spec on the main pulley is for a friction fit to the oil drive gear. I wondered the same thing too, as to why the oil drive gear had a keyway, but no key. q45tech on these boards explained the reasoning for the friction fit of that drive gear. It has to do with cold engine starting and thick oil.
Here is the thread in question
vh45de-oil-pump-drive-gear-question-t22 ... y#p2321100
And the reasoning
oil-pump-crank-gear-does-it-use-a-key-t ... p#p1699995
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
That's cool, not bad news at all. I can remove it easy enough, the crankshaft isn't torqued down yet... Need a strong enough torque wrench. Thanks for that input; I tried finding it myself. Hooah!
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
scir16v wrote:Hate to be a bearer of bad news, but that keyway thing that you made for the oil pump. The keyway slot in the drive gear for the pump is only for you to be able to slide it over the main engine pulley key. The reasoning for the torque spec on the main pulley is for a friction fit to the oil drive gear. I wondered the same thing too, as to why the oil drive gear had a keyway, but no key. q45tech on these boards explained the reasoning for the friction fit of that drive gear. It has to do with cold engine starting and thick oil.
And the reasoning
speedeast wrote:That's cool, not bad news at all. I can remove it easy enough, the crankshaft isn't torqued down yet... Need a strong enough torque wrench. Thanks for that input; I tried finding it myself. Hooah!
Where did you see this. Just trying to see fully what your referring to as I think I missed it.
speedeast
If you look back a few pages, one of my updates outlines the creation and installation of a tiny little key that I used to lock the oil pump sprocket in place. I can yank it back out Saturday night when I get back out there; it doesn't even have to come out of the car.
DRFTBLD
91 S13 Tester
08 Ford Focus
Oh yeah... my bad!! saw that part and wondered about it but thought I just didn't know what was going on! :)
speedeast
It's cool. Look for another update on Sunday, guys. I'm almost done with my training here @ Drum.
Chris28
Car: 92 s13 KA-T
Just saw the tub related question, but I meant tub the front end, as in make new wheel wells. It allows you to run a wider tire and not have it rub the inside of the wheel well at full lock. People usually do it if they plan on drifting the car, but your fab skills seem up to par and you had the engine out so I figured it'd be a good thing to do. A friend of mine rubs the inner wheel well at full lock with 225 50's on a x8 0 offset wheel, and that's not even a wide tire.
speedeast
Honestly, I didn't want to sacrifice an inch of space under the hood. I'll run a lower profile tire if I must. I appreciate the heads up and the compliments. I might consider tubbing the next one. I'm not sure if I mentioned it in this thread, but it's all coming back out next year for upgraded internals and forced induction. If I find a sister shell and engine, then this car will stay as is. I've seen some successfully tubbed S14s; I think I'll be ok though.
1 more day of Ft. Drum!!!
speedeast
Well guys, I'm back from Fort Drum and have begun throwing things together. Even though most of what I'm doing now is to accommodate the trip to Virginia, I wanted to share with you guys.
Time for the rear suspension!
I needed to put the wiring in the car in order to put the fenders on and make it trailer-able. "Here ya go Russ!"
And she's getting her s*** together...
I'm am going back out to the garage here shortly, but will probably hang on to those pictures until tomorrow.
AShort
wow. awesome build man, i love it.
I might be acquiring a 240sx in the near future and have been thinking of a vh45. good luck wit the build, i'll def. be one of the followers haha :dblthumb:
S14Kouki10
Car: 1997 240sx
speedeast wrote: Image
corvette?
DRFTBLD
91 S13 Tester
08 Ford Focus
corvette?
:confused:
speedeast
I don't have any more pictures or time to put them up, but I installed the driveshaft and wheels all the way around. I was able to then set her down. She's on a trailer with most of the contents of my garage right now. I'm hitting the open road here in about an hour.
TOO.PHOR.TEE
Car: '89 240SX Hatch.
So Im new to the forum and this is the first thread i came across. And i must say this is the sickest s*** ive seen. I have a whole parts car sitting in my backyard that i feel that im gonna start working with. This thread is Pure Motivation. Thanx man.
DRFTBLD
91 S13 Tester
08 Ford Focus
^^^^ Agreed! :)
DRFTBLD
91 S13 Tester
08 Ford Focus
speedeast wrote:I don't have any more pictures or time to put them up, but I installed the driveshaft and wheels all the way around. I was able to then set her down. She's on a trailer with most of the contents of my garage right now. I'm hitting the open road here in about an hour.
Good luck with the move! Hope all goes well!
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Car is coming along nicely man ... :yesnod
speedeast
Thanks guys for all the awesome comments! The car is now at home in VA! WooT!
PyR0NiAk
speedeast wrote:Thanks guys for all the awesome comments! The car is now at home in VA! WooT!
Great! :dblthumb:
speedeast
I suppose I need to start looking for a place to work on her at.
I am questioning the paint options. I haven't yet 100% decided on a color. I was stuck on Gloss Black for a long time, but the closer I get to painting it, the more I am still up in the air.
What do you guys think? Interior will remain black regardless. I don't want anything too flashy. I like darker colors. The two tone: color bottom, black top is also on the shelf...
Please share.
DRFTBLD
91 S13 Tester
08 Ford Focus
What about a two tone Wine with black combo.
Of fade from front to back deep red to black.
I'm personally a fan or dark metallic blue's
speedeast
I can see a fade paint job costing me a fortune. I like the idea. I also like dark metallic blues. I am a big fan of British Racing Green.
Skyline_BNR34
Car: 2003 Nissan Sentra SE-R Spec-V
Do a very dark metallic blue.
DRFTBLD
91 S13 Tester
08 Ford Focus
speedeast wrote:I can see a fade paint job costing me a fortune. I like the idea. I also like dark metallic blues. I am a big fan of British Racing Green.
I think you could do it yourself but you can also go to a local place and it shouldn't cost you that much. It should be similar price to a full car paint job and cheaper than a two ton as they only have to mark/tap it off once not first do the upper then do the lower... From my experience.
But personally I think the blue would look tits on this car! :)
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Check the metallic blue on the 2010 Mazda 3. It's Puuuurfect and will be the color I paint mine when it's ready.
speedeast
^If you're going to paint your car that color, would you really want mine to be the same? I have been debating using the color from my 2006 Mazda 6:
Skyline_BNR34
Do it, or make it a midnight blue.
I just love dark colors.
speedeast
^So do I, that's why I was stuck on black for the longest time.
DRFTBLD
91 S13 Tester
08 Ford Focus
Black sucks though... To many out there. You need a car like yours to stand out!!
