Q45tech wrote:The MAF assembly alone has a restriction of 7" water column at redline so removing the screens will only add to inaccuracy and not help flow more than 3" which is 3/27.7 =0.108 psi or 0.7% x 320 HP or ~~ 2HP at BEST!
The screens are there to straighten the air flow and improve accuracy.
Umm, maybe you should read my post again. I did not state anyplace about taking out the screen. That meant I was open at that end, ie: no air box or filter of any type.
But hey, that was a great dissertation on the function of the maf and screen... Were you a nuke in the Navy?
BTW: Flowmeters on most Nissans are a type of hot wire (resistor) anemometer that is placed inside a known diameter tube thus giving the engineers a way to measure airflow. The screen does not straighten the air. Tubes in front of the anemometer straighten the airflow and that screen is just there to catch anything large comming it's way. It actually will create turbulance because behind each strand in the screen is a tiny vortex. Granted, it may not make too much difference in this application. There is actually a flowmeter that uses the measurement of vortices. If interested, feel free to look up the Von Karman theory of vortices.
Modified by zmech at 12:43 PM 5/15/2009
