Hogg wrote:Wow thanks a lot for the help,
So I think I should order a Z32TT transmission, and a Z32 NA Differential?
Its a heap of info, Im just bad at concluding lol
you should get a Z32 transmission either TT or NA, it won't really matter. only difference is going to be the 240mm clutch for NA or the 250mm clutch for TT. the internals will be able to handle the same power, which is a whole lot, but you'll have more aftermarket options with the TT clutch. so TT is preferable, but its not a necessity.
Z32 NA differential will work, but its weaker, they may not be able to reliably handle the power you may want to be putting down with the VH, however you could probably get them pretty cheap. It has been known to snap axles with power upwards of 450hp. It will be nice and quick though. If you can afford it go with the TT differential and if you are aiming for top speed, keep the stock final drive, if you are aiming for acceleration, get the LeaderGears.com final drive gear kit to supplement the TT differential.
again the NA transmission is perfectly fine, its just that theres more aftermarket clutches available for the TT.
warning: SHAMELESS PLUG
I do have an NA Z32 transmission for sale in case anyone wants one.
I don't know too much of its history unfortunately, but this is what i do know. The transmission got a rebuild and then the car was either abandoned or sold to the shop that was working on it, Concept Z Performance, which was a fairly well known z32 shop in northern california. The car was parted out and one of the mechanics at Concept Z ended up with the transmission. the mechanic has since sold his Z32 and didn't need the transmission anymore and sold it to me. I have not used the transmission, and to my knowledge no one has. I've had it looked at by Nissan Doctor Autocare, another prominent Z shop in Northern California and they said it looks good and it turns very quiet.
but i'm looking for something around $700 USD OBO
