andre1038 »
https://forums.nicoclub.com/andre1038-u91543.html
Wed Jan 02, 2013 11:53 pm
Hi guys i don't post much here on the 240sx forum since i have Z32 and not a 240sx, anyway i wanted to share an interesting find that im not sure anybody knows... here we go
My coworker/buddy has an RB20det in his s13 and he doesn't have power steering ...the car didn't come with a P/S pump when he got it anyway he started to look what kind of pump he can use or where he can locate an RB20det pump for his car for okay money but nothing, so we started thinking and researching i found somewhere the Z32 pump and the RB20DET pump use the same rebuild kit so i was like hmmm my Z32 twin turbo engine is still on the engine stand (upgrading the motor and maintenance) so to help him out, i said lets try and see if a Z32 can work so i took the pump off my engine (HICAS pump) and see if it fitted in his bracket and guess what i believe me and him may have found a shocking discovery for the rb20det P/S shortage pump dilemma. That thing fit right in snug (maybe we have to add 1 washer we are still test fitting) only thing is pump is reversed (like flipped in a mirror since now the pump sits on the driver side of the engine instead of the passenger side where it sits in a Z32) anyway i gave him my hicas pump in return for an NA pump, bracket and some other stuff to delete my Hicas in my car. So the other day we test fitted the pump in the car and bam it bolted up, the only thing so far we see as being an issue is that the banjo bolt is on the bottom facing down and the line does not reach, we are gonna see if we can mod the line by taking the car to a place that does custom hoses for P/S lines to coolant hoses. Will let you know what happens next Gonna take pics of the DIY once he gives me what i want as a trade for my pump lol
Also since its a Hicas pump you have to also weld that part that you would normally do if it was a hicas rb20det pump going in a non hicas car with a RB20det
andre1038 on Fri Feb 01, 2013 9:22 pm, edited 1 time in total.
