SLE-PR »
https://forums.nicoclub.com/sle-pr-u191042.html
Sat Oct 29, 2011 11:22 am
In regards to the no starting at 70 degrees, I have the same issue with a '90 NA. I am baffled as to why it reacts like this. If I leave it in the shop at 70* and take it out on a cooler day of say, 30-40* F, the car seems to run rougher even though the engine is at operating temp.and running 91 octane fuel. I have also checked the sensor on the front but to no avail. I am in the midst of doing more tests. Leak down is next, hot compression test gives me lowest cylinder at 120 psi, highest being 180 and the other four are 160 + or -.
I have gone through as many connectors as I can, checking, cleaning and putting dielectric grease on them. All injectors check out at about 12 Ohms and click when engine is running. I put Iridium plugs in and made no difference from OEM recommended ones. I pulled the harnesses off of each coil, one at a time (and reconnected) and found no difference other than rough idle until reconnected and of course, code 55.
I have combed many forum sites to figure this out and not able to find a positive remedy to this. I had a '86 z31 2+2 that started and ran like a top even in the cold Canadian winters. I am getting frustrated, as I am currently spending 20k, having a 700 hp motor built at Z1 for my '92 Z32J and hoping this isn't going to happen to it. It seems like it should be a simple fix but I am trying to understand and learn about the z32's to be able to do most of my own tuning and maintenance to save garage labor costs, as I live close too 200 miles from the nearest Nissan dealer and unable to find any local guys who care to or want to work on them.
In closing, I am sure hoping someone will read this and be able to help me. Also, is a person able to buy his own "Consult" or other type of unit to get a little more in depth into the cars for tuning and diagnostics?
Thanks, Jim
