amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Tue May 01, 2018 10:45 pm
'Any easy ways to do this...'
Already took the easy way out by not changing water pump, see what happened there............I would be now looking to do it right rather than quick.
You must remove the lower cover to see the crank sprocket and how the belt goes around it correctly.
Once a belt has come off you should be changing it as well, it may now well wander once stretched wonky to come off. May well have torn internal belt threads that hold it together, edge riding a belt often does that. You are begging for further trouble by not changing it.
I for one do not know if the motor is interference type or not, may have bent some valves already when belt came loose.
